07-24-2017, 10:18 AM | #1 |
Rep 186
Hi All I am planning on swapping my runflats for Michelin Crossclimate non-runflats . I have the standard 17 inch 225/55 set . Does anyone have any experience of these tyres as I believe they are fairly new . I couldn't find them anywhere in a runflats version so am going to go non-runflat , I must say tentatively !
The crossclimates will be going on the rear axle - does anyone know if having a mixed set causes MOT failure |
07-24-2017, 11:30 AM | #2 |
Rep 364
Michelin crossclimates are great!
I'd suggest using the same tires all around I had a set on my golf previously, a set on an A6 estate and I have a set waiting to go on in a months time for my F10 Great tires - have breakdown cover which covers tires |
07-24-2017, 12:34 PM | #3 |
Rep 605
If you are the kind of person who does tentative, I wouldn't consider mixing RFT and non-RFT. An MOT failure could be the least of your worries.
Car and tyre manufacturers say you mustn't do it. There are people on the forums who say it is no problem. Guess who your insurance company will side with if bad things happen? |
07-24-2017, 03:34 PM | #4 |
Rep 15,858
Mixing run flat with non run flat, is definitely not recommended in the motor, tyre and safety related industries. Neither is mixing tyre types.
Plus you can't really evaluate a tyre if only fitted to one axle. Need to be a full set to really know how they work on a car. You could fit them on one axle and find the car is now very skittish, chassis unbalanced, and blame the new tyres. Whereas a complete set may be perfectly suited and have no negatives at all. |
Im119.00 |
07-24-2017, 04:14 PM | #5 |
Rep 186
Ok many thanks for all the replies. I am getting the idea it's all 4 or nothing . Any advice on the tyre mobility kit to buy would be much appreciated. My main concern now is whether the foam would damage the TPMS and how expensive this could be to replace
07-24-2017, 05:21 PM | #6 |
Rep 3,216
The foam will probably wreck TPMS valves - or at least, you should assume so. Having said that, 17 inch wheels with high-profile sturdy tyres ... far less likely to get a puncture than running 19s with sports tyres.
You can buy new TPMS valves if you did wreck one. I believe they can be got for less than £50 per. As others have said. Don't mix tyres - all or nothing. |
Im119.00 |
07-25-2017, 04:46 AM | #7 |
Rep 186
Looking forward to getting all 4 replaced . Has anyone had experience of swapping to non runflats with such a large profile tyre -225/55 17
I am all for comfort and quietness so am quite happy to trade compromise on smooth road handling however was wondering if anyone had any comments particularly wrt steering feel |
07-25-2017, 06:11 AM | #8 |
Rep 334
You could consider the Goodyear Eagle LS-2 all-season runflats as an alternative
http://www.blackcircles.com/tyres/br...year/eagle-ls2 Listed as BMW original fitment |
Im119.00 |
07-25-2017, 06:13 AM | #9 | |
Rep 15,858
What would be different on non run-flats, is less change in how the tyres feel across the working ambient temperature range. My own case, I find the 17" in winter temperatures feel very similar to the 18" in summer temperatures. Comfort does change a little as temperatures change. Notice it more at typical summer/winter change over temperatures. I'm on Adaptive Drive, but I don't think that will make much difference to how the tyres feel when comparing. May be a little more evident on the other suspensions. BTW, I have changed from RFTs to non RFT on a 3-series. Both sizes were 17", running a 45 aspect ratio. Very little change in steering feel, but back in E9x days much better comfort levels. In fact the chassis was much more fluid and predictable. So in some ways better steering, as it was constant, rather than the strange steering characteristics which afflicted some E9x cars, including mine. Those characteristics don't exist in my F11 on run-flats, running optimum tyre pressures. |
Im119.00 |
07-25-2017, 10:14 AM | #10 | |
Rep 186
07-25-2017, 11:59 AM | #11 |
Rep 582
I don't think it does either, really - perhaps they are comparing it against the lesser summer tyres but most summer tyres available for the F10 are the UHP variants of which the Cross Climate gets nowhere near.
Current: 2021 M340i xDrive, 2001 530i Sport
Previous: 2015 530d M Sport, 2010 530d SE, 2008 335i M Sport |
07-26-2017, 05:33 AM | #12 |
Rep 605
When I looked into them they are basically way better than summer tyres in winter and better than winter tyres in summer. However a lot of the reviews I read were flawed because they were comparing the CCs to using summer tyres all year (fair enough) but also to using winter tyres all year (which is nonsense). Also more than one review said that their benefits were likely to be reduced on "heavier and more powerful vehicles". I would suggest an F10 falls into this category.
07-26-2017, 07:54 AM | #13 | |
Rep 186
07-26-2017, 07:59 AM | #14 |
Rep 186
Thanks I have thankfully never had a roadside problem and need some advice - In the event of tyre failure what do they do - do they come and fit a spare wheel if they can't solve with foam or load onto a truck ?
