2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications F10 550xi Meth 60-130 10.859
      07-30-2014, 12:42 AM   #1
badblack550xi
badblack550xi's Avatar
F10 550xi Meth 60-130 10.859 Seems slow... i had a passenger that's about 220lbs... need to hit 1/4 see if my car actually still runs well...
2011 550i RWD 60-130 7.35
      08-01-2014, 08:23 PM   #2
scott135i
scott135i's Avatar
Drives: 2020 X5 M50i
207lbs you over estimating prick.
      08-01-2014, 08:24 PM   #3
badblack550xi
Oh forgot you're short
      08-01-2014, 11:28 PM   #4
ARC550
Drives: M3, X5, 720s, X5, 750xi
Scott's 207.. Damn bro. The deeper into marriage you fall the heavier you shall get! Lol
10.8 with passenger in car is fuckin fast!
      08-01-2014, 11:29 PM   #5
badblack550xi
You're faster
      08-01-2014, 11:54 PM   #6
Sum1.
Addict
Drives: '14 550iX M-sport
Think you'll appreciate it more at the track. Cooler temps should keep it from pulling timing up high and make more power.
'14 550iX M-Sport | BMS Tune | M5 Exhaust & Diffuser | 20" 601's | Beltronic STi+ | L.I. Quad | Color Matched Everything...Carbon Black |
      08-02-2014, 10:42 AM   #7
badblack550xi
we did a lot of pulls last night... most i was able to put on Arch was 1.5 cars.. that TU car is strong!
      08-03-2014, 09:04 AM   #8
Sum1.
Addict
No Shit? You need more boost!
OR
I'll donate the NO2 kit I have and you can hook up a couple 25# nozzles...and hold on tight!
      08-03-2014, 01:15 PM   #9
badblack550xi
OR
Need to hit track and find optimal boost setting.. I tried all the way to 6psi when racing arch and once again best was +4 just like on race gas.
      08-06-2014, 04:03 PM   #10
Sum1.
Addict
Been thinking... If you can't add more timing (which I don't think you can) then you're max'd out with dialing your boost in. Maybe head work would net some ponies but unless you can get more air into those cylinders; raise compression; cams; customize your tune...you've tapped it.
Question: Are you able to change the tables/tune w software on your ECU or are your black boxes (like my '14) flashed and that's it?
      08-24-2018, 12:47 AM   #11
535_BiTurbo
Drives: 2012 550I - BMS Stg 1 & CAI
what were your mods? Archs mods?
