2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Thoughts on Tire Size (Comparisons)
      08-11-2011, 11:24 PM   #1
Sonnie
Bama Hillbilly
Drives: 2011 BMW 528i
I replaced my OEM wheels and tires on my previous 528i with the wheels and tires in the middle column below. As you can see, they were quite a bit wider and only slightly taller. They fit well with no issues.
I am probably going to use the same wheels on my new 528i that is on order now... or at least the same size wheel, but the tire I want to go with, the Michelin MXM4 is not offered in the previous size I had, so I plan to use the proposed 245/50/18, which will be narrower than the previous tire, but yet again a bit taller... nearly an inch taller than the OEM.
There appears to be plenty of clearance and they will probably look better filling up the wheel well more... and I like the idea of getting back close to the sidewall height of the OEM. I am not much on the railroad boxcar type wheels with a layer of rubber stretched over them. I like a little bit of rubber with my wheels. No offense intended to those who like that style... call me old fashioned.
Speedometer difference will be 2 mph faster at 60 mph, but I am not concerned about it. My truck has run bigger tires at 3 mph faster since I have owned it. I am a slow poke anyway... I am the guy leading the long train of cars you get behind.
Basically I want to make sure I am not missing anything and would appreciate any reassurances that I should be fine before I get my tire guy to order these for me.
Thanks!
      08-12-2011, 11:49 AM   #2
remmib
remmib's Avatar
Norway
1568
Drives: 2013 F10 520d M-Sport
Why not get them in the proper size of 245/45/18?
      08-12-2011, 12:28 PM   #3
Sonnie
Bama Hillbilly
They don't offer that size in this tire.
      08-12-2011, 02:08 PM   #4
remmib
remmib's Avatar
Norway
1568
But I find them in 245/45/18 on Tirerack.
http://www.tirerack.com/tires/TireSe...turer=Michelin
      08-12-2011, 02:20 PM   #5
Sonnie
Bama Hillbilly
OK... yeah... I remember seeing those now. They did not offer them at Discount. I did actually consider those, but the sidewall height is even less than my previous aftermarket 18's. I don't wanna go less, but would rather have more sidewall to compliment the comfort more. Plus they would be shorter than the stock tire, albeit only by a smidgen.
      08-13-2011, 09:33 AM   #6
remmib
remmib's Avatar
Norway
1568
But the stock 18" size is 245/45/18.
      08-13-2011, 09:40 AM   #7
Sonnie
Bama Hillbilly
Yep.... but the stock tire on my car is 17".
