2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum HVAC probs
      02-08-2014, 02:41 AM   #1
moldcad
moldcad's Avatar
Poland
262
Drives: M235i
HVAC probs
In this thread http://www.bimmerfest.com/forums/sho...d.php?t=750418 I mentioned some problems I'm having with the HVAC system in my F10, namely:
- the cold air from central vents is never really cold (even with the thumbwheel fully at the blue position)
- the air inside the car is humid
- I got the car brand new in January 2013, and in april 2013 I already started feeling the nasty smell, especially when first starting the car after several days in the garage
So I decided I just have to do something about it (BMW wants to charge me some sick money for it as they say its' not covered by warranty). I was already about to replace my microfilters (which are dirty and wettish), when I hesitated as I'm unsure whether the air pushed through it comes directly from the outside (in which case it might get wet from rain or alike), or is first cooled down and dried by the A/C in which case it should be completely dry, unless... unless my A/C developed some fault. If the latter is true, I should repair the A/C first, and replace the cabin filter only afterwards.
Please help me answer the above question (typed in bold); I looked for some diagrams but found nothing conclusive. A link to the BMW HVAC diagram would be helpful, too.
So, once again:
Does the air enter the microfilters directly from the outside, or is first cooled down and dried by the A/C?
TIA!
previous: 2003 E46 330i SMG
just sold: 2013 F10 528i xDrive
my AWD beater: 2015 Golf R mk7 DSG
my RWD pirate & long-distance cruiser: 2015 M235i AT8, LSD
      02-08-2014, 06:06 AM   #2
HighlandPete
Drives: BMW F11 535i Touring
So, once again:
TIA!
I assume you are using the full A/C function, even in colder weather, to dry the air?
The linked document should help you understand the system. It is for the F01 7-series, we have the very similar/common system in the F10/11, even if we don't have the 4-zone option.
http://www.kneb.net/bmw/F01-02/08_F0...%20Control.pdf
HighlandPete
      02-08-2014, 06:24 AM   #3
moldcad
moldcad's Avatar
Poland
262
Drives: M235i
Yes, of course i have the full A/C always on, also in winter. Thanks for the link!
      02-08-2014, 08:21 AM   #4
raleedy
Drives: 2016 228i 6-speed
1. Your Bimmerfest link above seems to be broken.
2. So does your a/c. The only other possibility that occurs to me is water intrusion somewhere. Is your car garaged?
      02-08-2014, 08:51 AM   #5
moldcad
moldcad's Avatar
Poland
262
Drives: M235i
Thanks - link fixed, car garaged and my BMW dealer says everything is OK (apart from the filters that require replacement - after just 17k km). May I know which part of my description makes you so positive my a/c is broken?
      02-08-2014, 11:06 AM   #6
raleedy
It sounds as if you have excess moisture inside your car. Genius that I am, I suspect that this is a result of either (a) too much moisture coming in, or (b) too little moisture being removed. The latter problem would indicate an A/C fault.
      02-08-2014, 09:37 PM   #7
ezmaass
ezmaass's Avatar
Drives: '17 650xi GC / '15 Audi R8 V10
I'm surprised BMW won't do anything about this? Given that the car isn't getting cold from the A/C and there's a moisture build-up, I'd suspect a problem with the A/C compressor. Air may still be blowing from the vents, but it doesn't sound like the A/C is working - if so, the air would be dry, cold, and "stink-free."
I would take it to another dealer if this one can't find a problem - A/C should be pretty basic to diagnose.
2017 BMW 650xi Gran Coupe | MSport | Exec Package | Driver Assist Plus | ACC Stop & Go | Adaptive Drive | B&O | Night Vision | Cold Weather | Active Seats
2015 Audi R8 V10 | Brilliant Red on Black | S-Tronic | Carbon Sideblades | Carbon Trim | Full Leather | Sport Exhaust | Illuminated Doorsills | I-Pod | Contrast Stitching
Previous: '14 550xi, '07 335i, '01 325i
      02-08-2014, 10:25 PM   #8
Mbbrewer
Mbbrewer's Avatar
150
Drives: 550i
