2010 2011 BMW 5 Series Forum F10 Front mounted CAI vs Arizona Monsoons |
06-20-2021, 11:19 PM | #1 |
Rep 35
Hey everybody.
I installed the ARM front mounted CAI on my 14 550i. I live in Arizona and it's usually always sunny. But we are entering monsoon season soon and it will be raining, hard, everyday. This my daily driver to work so I am concerned about hydro locking the engine. I do have k&n hydroshield cover on each filter intake but I'm worried it's not enough. I'm not worried about puddles. More so the rain entering the kidney grills where the air filters are located. Anyone have any advice or any info, I'd be grateful for any insight. |
06-21-2021, 12:05 PM | #2 |
Rep 332
Think of it as free water/meth injection, even the monsoons here in AZ aren't enough to hydrolock your 550i. Last year I think we had a total of 1 monsoon storm with rain, it's not an everyday thing. Just get used to the heat, that won't stop until late October. Enjoy AZ.
2022 G82 M4 - Isle of Man Green w/Kyalami Carbon Bucket Seats - MST Intakes, SSR Downpipes, JB4, AWE Exhaust.
2013 F10 N55 (535i), Pure Stage 2, Fuel-It PI Platinum, Fuel-It Stage 2 LPFP, BootMod3, Custom Turbo Inlet, Custom Cary Jordan Tune, More.. SOLD! 1999 e36 M3 - Estoril Blue - Track Car - S54 Swapped |
06-26-2021, 10:00 PM | #3 | |
Rep 35
06-30-2021, 01:16 AM | #4 | ||
Rep 262
You could always get a good catch can system (don't buy the Amazon cheap ones, they don't work 100%, well enough but not like the expensive baffles should and do) which would serve 2 purposes, catching the oil and then the piece of mind for you rain/monsoon storms. We get some pretty wet winters up here so nothing to worry about. I installed the vapor shields for the winter/spring and I think that is prevention enough, overkill if anything.
2011 550i (N63)
Upgraded 51mm turbos, Heatsync Stage 3 Flash, JB4 stacked, BMS WMI, Arm Charge Pipes, Heatsync Catless DPs, X-Pipe, Res Muffler Delete, xHP Stage 3 Trans Flash, Turbosmart Diverter Valves, 3.5 TMAPs, Oil Cooler, Heatsync Front Mounted Max Cool Intakes, Walbro LPFP and e40 mix rollin on Stance SF07 9x20 w/Toyo Extensa and 10.5x20 w/Toyo R888R. |
07-03-2021, 07:36 PM | #5 |
Rep 191
As was already mentioned, it's essentially no different than water/meth injection. The old school trick to clean pistons etc was to dump water into a running engine at a medium to high rpm.
Same reason heads/pistons look like they've been steam cleaned when you blow a head gasket. So long as you don't suck in a significant amount of water (far more than the volume falling rain could produce) you've got nothing to worry about and its actually kind of a good thing (for your pistons).
IG: @derringerF10
2016 550i RWD N63TU 8AT | Catless Downpipes | BaskiSpeedworks STOCK TURBO RECORDS 1/4: 10.90@128 60-130: 7.43 |
