2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Calling all the wheel fitment experts..thanks in advance!
      09-23-2015, 02:42 PM   #1
labenzm5
Drives: E39 m5
Ok, here's my deal. I recently purchased a 2103 535I Xdrive M sport for my daily driver. The car is great, I love it so far.
I was shopping for a winter wheel/tire setup and then I remembered that I have a full set of 235/45/17 on Borbet wheels with Blizzaks from my E39 M5
the E39 M5 wheels have a 74.1 Bore with a 20mm offset
the 535 wheels have a 72.56 Bore with a 30 mm offset
I called tire rack and ordered hubcentric rings that take me from the 74.1 bore to the 72.56 bore, should be perfect.
my question is: do I need to be concerned with the offset difference of 10mm? I figured the offset on the 535 is greater and I should be OK
Are there any potential issues? I don't want to mess up my car this winter
Next up I need a set of black Weathertech floor liners.....anyone looking to sell?
thank you for all your help
      09-23-2015, 02:52 PM   #2
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
235/45-17 is over 5% shorter than OEM 17" tires for F10 (225/55-17).
The offset should be ok and will not cause any issues.
      09-23-2015, 02:57 PM   #3
labenzm5
Drives: E39 m5
will is mess up my wheel sensors? or throw off the speedo? and all the other computer stuff going on....
      09-23-2015, 05:23 PM   #4
ndinh
Drives: 640i GC, X5
The OD is 1.4" smaller than recommended stock size. Your speedo will show faster than your actual speed. Depending on the width of the wheel (~8") offset and wheel sensors should work, no problem.
      09-23-2015, 05:58 PM   #5
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
I wonder if that would throw a error code running that small of a diameter?
      09-23-2015, 11:57 PM   #6
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
It will not throw any error codes.
But since the speedo show higher speed than actual with OEM tires sizes (a few mph), it will be a lot with 5% shorter tires.
      09-24-2015, 10:36 AM   #7
remmib
remmib's Avatar
Norway
1568
Drives: 2013 F10 520d M-Sport
The tires are way too small, and would look weird on the car.
      09-25-2015, 10:42 AM   #8
M5Beast_NYC
Drives: 15 M5
aside from a smaller wheel diameter. just make sure the spokes will clear the brakes as well.
