2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Problem with N63 BMS stage 2 after "customer care package" campaign service
      04-02-2015, 01:41 PM   #1
hooolala
Drives: 2011 BMW 550i
I just got my 2011 550i back from the "customer care package" campaign service, and after I reinstall my BMS stage 2 back onto my car, i try to start the car, but end up getting the "drivetrain malfunction" error and the car won't start at all.
i shut off the car completely and check all the connection to make sure i install it correctly (when i do that, i can hear the liquid inside the intercooler running), after checking and trying to start the car several time with no luck, i decide to take the BMS off, then my car went back to normal (except the check engine light was on for about an hour)
so does anybody else with BMS stage 2 has the same problem after the service campaign? thanks
      04-02-2015, 02:09 PM   #2
badblack550xi
badblack550xi's Avatar
i had the same issue.. terry had to send me a new version because i have one of the first versions. Now it works perfect.
2011 550i RWD 60-130 7.35
      04-02-2015, 02:58 PM   #3
hooolala
Thanks for your info,
i will contact Terry and see if i can get a new version of the stage 2.
      04-30-2015, 09:42 AM   #4
SteveMD
SteveMD's Avatar
193
Drives: 2016 F10 535i MSport
I have the same issue. Did you get a new version and did it remedy the situation?
2006 E90 330i (retired)
2009 E90 335i (retired)
2012 E70 X5 50i M Sport (retired)
2016 F10 535i M Sport
      04-30-2015, 09:55 AM   #5
///M5Driver
Drives: gaggle of BMW's
Good info.. is the version just firmware you flashed?
      04-30-2015, 10:29 AM   #6
badblack550xi
I had a new box sent to me... ill have a thread on this a bit later.
      04-30-2015, 10:38 AM   #7
///M5Driver
Wonder if I should mess with my Stage 2 I just purchased or get on the phone with BMS.
      04-30-2015, 10:44 AM   #8
badblack550xi
Means you have latest... my board was a Beta i was 2nd car after Terrys to run it, everyone else got the new one.
      04-30-2015, 11:08 AM   #9
///M5Driver
Solid thanks again
      05-07-2015, 08:04 AM   #10
///M5Driver
For what it's worth I installed stage 2 last night after my care package and everything works great!
      05-13-2015, 09:15 PM   #11
iLikeCoolTech
Drives: 2011 550i Loaded with Badass
I had the same errors. I attempted to install after the recall updates. I previously only had stage 1 installed before the service.
