02-06-2019, 04:53 PM | #23 |
Rep 11
Thanks a million.
This is what we ended up with. Medium aggressive look for winter setup with my VMR V710 Gunmetal 8.5x19" ET35 245/40 R19 and 5 mm spacer 9.5x19" ET45 275/35 R19 and 5 mm spacer I will also install Eibach pro-kit springs 30 mm in front and 20/25 mm in the rear via koding. I hope everything will work out and it will look good. Last edited by BMWway; 02-07-2019 at 10:16 AM.. |
02-07-2019, 10:14 AM | #25 |
Rep 11
Yes I will.
For my summer setup > BMW 312 ferric grey 20". I´m bit unsure about those spacers.. 8.5x20" ET33 245/35 and 5 mm spacer = ET28 9x20" ET44 275/30 and 10 - 12 - 15 mm spacer ? Rear: if 10 mm the rear will poke 0,4 mm more than front = flush. (ET34) If 12 mm the rear will poke 2,4 mm more than front. (ET32) if 15 mm the rear will poke 5,4 mm more than front. (ET29) What do you think? Last edited by BMWway; 02-10-2019 at 03:32 AM.. |
02-07-2019, 02:09 PM | #27 |
Rep 64
Hey gents!
Im looking into new wheels to purchase next month. I want a superflush look and i was hoping for your imput. I want a crazy convaced and flush look but im unsure about the offset. im looking at Rohana RC 10 in white and silver. I talked with a few buddies of mine and they reccomended 20x9 20 in the front with 245/35 tires and 20x10 25 in the back with 285/30 tires. i dont mind a tiny poke becouse i havent installed coils yet and i really dont want anything to do with spacers. any thoughts? |
02-10-2019, 03:53 AM | #28 | |
Rep 11
Original OEM rims is in the front are 8,5x20 ET33 and in rear 9x20 ET44 but that's not an aggressive stand. I'm having that setup but I will most likely use 5 mm spacer in the front and 10 mm in the rear for medio aggressive stands. To be honest I'm not sure about 9" 10" on an xdrive - seems too aggressive but I can't say for sure if it would work. Last edited by BMWway; 02-10-2019 at 04:01 AM.. |
03-03-2019, 04:15 PM | #31 |
Rep 11
Drives: BMW F11 LCI 520xdrive
Join Date: Feb 2019 Location: Denmark iTrader: (0) Hi guys So finally a picture. Really happy with the result (winter tire setup). Summer setup (20" oem) I think I will go for a bit more aggressive look. VMR V710 Gunmetal. Pirelli Sottozero 3 runflat with bmw star. 245/40 R19x8.5" ET35 and 5mm spacer. 275/35 R19x9.5" ET45 and 5 mm spacer. Also mounted Eibach 30 mm lowering springs in front and the 20 mm in then rear via coding. There's no loss in comfort at all I actually think the car feels as it should have felt from start. Better handling and looks. Bumps are less noticeable in the front. Seems that the Eibach springs are better tuned in for the car than the oem springs. Last edited by BMWway; 03-03-2019 at 04:24 PM.. |
03-08-2019, 01:12 AM | #32 | |
Rep 11
I was thinking for my summer set up, having 5 mm spacers on the front and 10 mm in the back for my OEM wheels. Do you think it will be too aggressive? 20x8.5 ET33 and 5 mm spacer = ET28 20x9.0 ET45 and 10 mm spacer = ET34 Last edited by BMWway; 03-29-2019 at 05:44 PM.. |
03-08-2019, 01:38 PM | #33 | ||
Rep 29,202
03-09-2019, 03:37 AM | #34 |
Rep 11
03-09-2019, 04:19 AM | #35 |
Rep 29,202
Not that aggressive, no rubbing. It's not an xDrive, but it's the same fitment.
