2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Car Wonders/Moves Around a lot at Freeway Speeds
      01-05-2018, 11:51 PM   #1
KillerM5
Drives: F10 550i
Guys,
Ive owned my F10 550i for about 6 months and I cant seem to get over how much this car seems to wander/move around at hwy speed. My E60 M5 would catch the ruts in the freeway and move around but nothing compared to how bad this F10 does. It almost feels like there is a problem with the steering. Does anyone else experience this? Is there something I should have the dealership look at?
Thanks for your advice and help!!!
Mike
      01-06-2018, 12:42 AM   #2
zugellos
Drives: 535i M-Sport
From my own experience with my F10, times when I've notice a little wandering are when:
- Tires are balding or nearly bald
- Tires are NOT at the ideal pressures (even w/functioning TPMS)
I've never had actual mechanical issues that contributed to wandering.
      01-06-2018, 03:07 PM   #3
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
if tire pressures are fine than check for worn tie rods. that will give you that wandering feeling
      01-06-2018, 05:45 PM   #4
TJBentley
TJBentley's Avatar
Drives: '12 528xdrive
My car only gets that slightly unstable wobbly feeling when I'm on a bridge and it's extremely windy outside but regular highway speeds is always good
      01-06-2018, 08:26 PM   #5
Aaron@Autosource
Aaron@Autosource's Avatar
98
Drives: F110/F22
Tire pressure and/or alignment.
Recently fixed a slight toe mis-alignment up front and it made a world of difference.
F10 steering naturally is a bit on the light side though, IMO.
      01-07-2018, 06:15 PM   #6
darrylh
darrylh's Avatar
Drives: 2015 535i M Sport Carbon Black
2015 BMW 535i M Sport  [10.00]
2006 BMW 525i  [0.00]
2014 BMW X3  [10.00]
I drove across Pennsylvania yesterday in high winds. My F10 was rock solid. I'm on board with the tires or tire rod opinion. My E60 is scary to drive when the tires have outlived their usefulness.
      01-08-2018, 06:24 AM   #7
Surly73
Drives: '11 535xi 8AT KWv3 MPE MHD xHP
A few things as I read:
First - no, the F10 chassis is generally very stable.
- alignment would be the first thing to check
- worn tie rods and other ball joints are a possibility, but we haven't seen a lot of that on F10s yet - how many miles on the car?
- current wear level on the tires? Same brand/model? Tire pressures set to door sticker?
Since you've only had the car 6 months, this one may be tough to answer:
- were the tires always on THAT car, or possibly swapped around from another car by the seller/selling dealer?
- were the tires rotated since they were new? There's another thread where I told my story where I personally observed dodgy stability and handling when I have rotated tires on BMWs (which is against BMWs own recommendation). Again, a seller/dealer could have done a "tire rotation" because the rears were worn more than the fronts (normal) or because it's a normal thing to do on other car brands or whatever... If you DIY, and you think this is a possibility, you could always do a front/rear rotation and see if the problem goes away.
With a correct alignment, most BMWs will wear out rears before fronts - if you see the opposite wear pattern on your car take note - bad alignment or someone rotated the tires.
      01-08-2018, 07:06 AM   #8
Apples12
Drives: 520D LCI auto
Had the exact same issue although on my 520d
turned out to be alignment which was waaaaay out.
make sure you find someone who has the hunter 4 wheel alignment/KDS machine. it does make a difference.
car tracks true and no waving about on the motorway/'freeway'
that and make sure tyres are matched for pressure and tread pattern
good luck
      01-18-2018, 04:23 PM   #9
KillerM5
Drives: F10 550i
Guys,
Thanks for all your responses. I did replace the rear tires so they are different from the front. I think Im going to have the alignment checked, if thats good then Ill have them check the tie rods and then do the front tires. Im due for an oil change so timing will work out well for this service.
Thanks
      01-21-2018, 06:52 AM   #10
lsturbointeg
Keep in mind that after your tires have developed the wrong tire wear on them sometimes with an alignment the car may pull want to pull because of it
      01-25-2018, 05:44 PM   #11
Amini77
Drives: Alpine White '13 550i
2013 BMW 550i  [0.00]
You need down force, look into some wings.
In reality its probably your alignment.
