2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Downpipe Comparison
      11-29-2016, 01:27 PM   #1
The_M6
The_M6's Avatar
Drives: 2013 M6
Downpipe Comparison
With all the Black Friday/Cyber Monday sales going on I've been considering pulling the trigger on downpipes for my 550i. As I search, there are several different manufacturers with generic downpipes priced in the $200-300 range and then some more well known manufacturers ranging from $1200-1500.
The big question is, what makes one, regardless of price point, any better than the other? They're stainless, catted or not and the length and pipe diameters are all the same.
If you have a set, what made you go with the brand you chose?
Thanks!
Project Gamma Intakes / Project Gamma Catless Downpipes / Muffler Delete / DME Stage II Tune / H&R Springs
      11-30-2016, 08:39 AM   #2
SLVSRFR
SLVSRFR's Avatar
Guam
245
Drives: BMW 550i
What generic ones are you referring to? The ones on eBay will not fit.
      11-30-2016, 09:14 AM   #3
The_M6
The_M6's Avatar
Drives: 2013 M6
there are 2 vendors I found on Amazon while looking at exhaust/muffler options.
      11-30-2016, 11:28 AM   #4
SLVSRFR
SLVSRFR's Avatar
Guam
245
Drives: BMW 550i
There is someone here who tried generic DP's and they don't fit. I personally wouldn't gamble with potential boost leaks due to improper fitment. You could find a used set of one of the proven brand DP's.
      11-30-2016, 10:41 PM   #5
mike@x-ph.com
Joint Chiefs of Staff
mike@x-ph.com's Avatar
Thanks!
Which one did you get?
Our most popular is AR and Active Autowerke 550 dowpipe
https://x-ph.com/sale/
Phone number 702-494-9435
      11-30-2016, 10:45 PM   #6
The_M6
The_M6's Avatar
Drives: 2013 M6
Thanks!
Haven't pulled the trigger yet, we have emissions here in MD so I need to ensure the catted DPs will still ensure I can pass emissions testing.
      12-01-2016, 10:06 AM   #7
m5james
m5james's Avatar
Drives: '10 X5M Alpine White on Sakhir
You're going to want a software flash after installing them, so just make sure your tuner shuts off the CEL for the catless and you'll be fine.
'10 BMW X5///M - Alpine White on Sakhir Orange - JB4 w/ HCP Stage 2 BEF, NGK 97506 @ .20, SS tubing & BMC filters, gutted cats, AC Forged 312 22's, H&R 2"
'98 BMW 740iL - ///E39 M5 6spd swap, fully built engine (sleeved, P&P, cams), 3.46 LSD, H&R Stage 2/Bilstein HD, Magnaflow 14816's
'97 BMW 328ci - ///E36 M3 clutch & L/W flywheel, Z4///M 18's
      12-01-2016, 10:09 AM   #8
The_M6
The_M6's Avatar
Drives: 2013 M6
But don't I need catted to pass emissions testing?
      12-01-2016, 10:34 PM   #9
vivanapoli806
Drives: 2012 535i Xdrive Msport
You will pass emissions as long as you get a tune to put your monitors in ready State. As long as they don't visually look for cats your ok. Depends on the emissions laws by you.
m5james431.00
      12-02-2016, 07:56 AM   #10
The_M6
The_M6's Avatar
Drives: 2013 M6
In MD, they connect to the OBDII port to see if there are any faults and then sometimes stick the probe in the muffler tip to monitor gases. No visual inspection here.
      12-02-2016, 06:58 PM   #11
MattPro
MattPro's Avatar
Drives: '13 F10 550iX, '91 E30
He is non-LCI, he couldn't get a flash tune for that anyways. (no love for our N63 DMEs)
Thanks,
Matt
2013 F10 550iX Carbon Black/MSport
BMW Fault Code DB
      12-19-2016, 04:21 PM   #12
The_M6
The_M6's Avatar
Drives: 2013 M6
Thanks!
      12-19-2016, 05:29 PM   #13
badblack550xi
badblack550xi's Avatar
WHAT HE SAID. or wait for me to finish mine
2011 550i RWD 60-130 7.35
      12-19-2016, 11:16 PM   #14
Simple5
Drives: F90 M5 and E84 X1 Xdrive35i
Interesting to see you are developing your own dps. Since you are indie are you going to offer some type of cel defeat?
      12-19-2016, 11:47 PM   #15
badblack550xi
bungs with shield on the inside, should stop CEL codes.
