2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions 2011 550i (N63) Spark Plug DIY
      05-08-2017, 05:17 PM   #1
m3gasm
m3gasm's Avatar
122
Drives: 09'M3, 16'M3, 11'550i, 17'X5
2009 BMW M3  [0.00]
2009 Grigio Telesto M3 DCT. ESS 700, BPM Tuned, GTS Tune w/ Euro MDM, Catless custom exhaust, TE37SL/Rays G07EX, Amuse Ericsson Bumper, CSL Carbon Trunk
2016 M3. JB4, VRSF Downpipes, Custom exhaust, Cornfed
2011 550i. Dinan Stage 3, JB4 Piggyback, Catless Downpipes, Custom Exhaust
2017 X5 35i. STOCK, boring, and sold!
AlexL4.50
      05-10-2017, 03:52 PM   #2
EL Jeffe 5
EL Jeffe 5's Avatar
Drives: CBR1000RR
Thanks for posting my warranty is expiring in June and I have 3k to go before BMW will replace sparkplugs. No worries even if they don't replace I can do this its simple.
      05-10-2017, 09:46 PM   #3
m3gasm
m3gasm's Avatar
122
2009 BMW M3  [0.00]
Haha yea, It's the easiest spark plug change i've done... EVER
Kyngofpop676.00
      05-11-2017, 09:36 AM   #4
EL Jeffe 5
EL Jeffe 5's Avatar
Drives: CBR1000RR
what spark plugs did you use OEM or aftermarket?
      05-11-2017, 08:03 PM   #5
m3gasm
m3gasm's Avatar
122
2009 BMW M3  [0.00]
I went 2 steps colder.. Since I have JB4 and Catless DP I was getting an engine malfunction at full boost. So i did the OEM equivalent replacement for the S55 (F80 M3) Plugs. No more Engine Malfunctions!
      05-25-2017, 07:35 PM   #6
hmd5859
Drives: 535I
What is torque spec for the plugs? Also did you use any anti seize on the new plugs?
      06-05-2017, 06:23 PM   #7
m3gasm
m3gasm's Avatar
122
2009 BMW M3  [0.00]
23nm, I used barely any on each
      06-06-2017, 10:29 PM   #8
535_BiTurbo
Drives: 2012 550I - BMS Stg 1 & CAI
F80 M3 plugs work on the F10 550??
      06-07-2017, 01:03 PM   #9
m3gasm
m3gasm's Avatar
122
2009 BMW M3  [0.00]
Yea but no point using them unless ur needing colder plugs. I was going into limp mode because catless downpipes and jb4 map 2.
      06-07-2017, 03:54 PM   #10
535_BiTurbo
F80 or F10?
      06-14-2017, 08:21 PM   #11
m3gasm
m3gasm's Avatar
122
2009 BMW M3  [0.00]
F80 or F10?
I used F80 M3 spark plugs
      07-19-2017, 12:41 PM   #12
MavRick
MavRick's Avatar
688
Drives: My Wife's M
How does the Dinan work in conjunction with the JB4? i've got Stage 2 on my 2012 N63 and have thought about adding a JB4. didnt know if it worked in conjunction with the Dinan flash.
oh....and thanx for posting this vid. i'm changing my plugs, this weekend.
      08-16-2018, 08:39 AM   #13
135i_vs_
135i_vs_'s Avatar
Drives: M5, 135i, 335d, F10 550xi
Do you have the part # for these plugs? I just can't seem to find it. I also need 2 step colder plugs now, since I am tuned.
      08-25-2018, 08:48 PM   #14
m3gasm
m3gasm's Avatar
122
2009 BMW M3  [0.00]
NGK Laser 97506
      06-07-2019, 03:32 PM   #15
taylorpetie
taylorpetie's Avatar
Drives: G80 M3CX, F10 550i X-Drive
@m3gasm. I'm attempting to replace the spark plugs myself next weekend when i get back from my travels for my 2011 550xi, but would like to know if 6 of the 8 spark plug locations are easily accessible (except for the 2 you've identified in the video)?
Thanks.
      06-07-2019, 03:37 PM   #16
m3gasm
m3gasm's Avatar
122
2009 BMW M3  [0.00]
Thanks.
Everything is very easy accessible. Spark plugs take less than 30 min
      06-07-2019, 03:45 PM   #17
taylorpetie
Awesome, thank you...
      06-11-2019, 05:47 PM   #18
535_BiTurbo
Did the colder plugs solve the limp mode issue?
      06-12-2019, 09:17 PM   #19
m3gasm
m3gasm's Avatar
122
2009 BMW M3  [0.00]
Sure did
      03-24-2021, 03:43 PM   #20
F10_GT
Drives: 2012 BMW 550i XDrive
m3gasm I'm have the same mods as you and keep getting drivetrain Malfunction on full boost. I'm planning on doing the NGK 97506, what did you gap the spark plug to? Anyone have any recommendations on what gap to put on the NGK 97506?
Thanks!
      03-26-2021, 12:06 AM   #21
550bye
550bye's Avatar
Drives: 2011 550i
2011 BMW 550i  [5.67]
Thanks!
I have seen some say 0.018 and 0.020 but I have always kept mine at 0.022.
2011 550i (N63)
Upgraded 51mm turbos, Heatsync Stage 3 Flash, JB4 stacked, BMS WMI, Arm Charge Pipes, Heatsync Catless DPs, X-Pipe, Res Muffler Delete, xHP Stage 3 Trans Flash, Turbosmart Diverter Valves, 3.5 TMAPs, Oil Cooler, Heatsync Front Mounted Max Cool Intakes, Walbro LPFP and e40 mix rollin on Stance SF07 9x20 w/Toyo Extensa and 10.5x20 w/Toyo R888R.
      03-26-2021, 12:21 AM   #22
AnotherM
Cole
Drives: 2016 m5 CP
Thanks!
I have my ngk plugs at .025, but plan to drop to .022 soon
