2010 2011 BMW 5 Series Forum F10 BIMMERPOST Universal Forums Off-Topic Discussions Board Photography/Videography *OFFICIAL* general photography conversation thread
      04-29-2011, 04:06 PM   #177
The1
Drives: white 135
Originally Posted by Weebl View Post
http://www.creativelive.com/courses
right under where it says "Course Catalog"... unlimited downloads of course content.
Cool, i didn't see that. was on a different page with the purchases.
I think i'll have to buy it, so far it's been one of the better info things i've watched. Not sure i'll have time to watch it all tomorrow or sunday, so very worth it in my opinion.
      04-29-2011, 04:12 PM   #178
Weebl
Weebl wobbles but eats Pie
95
Drives: 2012 X5 d,2008 335i, 2000 740i
Originally Posted by The1 View Post
The auto focus on the 7D blows the 5DII out of the water, i've experienced what they were talking about with the 5D searching for a focus point a few times. It is anoying (i don't know if you were watching that segment or not) but it's not a make or break situation for me as it's what i learned on, so i know how to cope with it.
However, if i had the 7D first, i would find the 5D autofocus a killer.
The 7D takes a sharper image at 100% crop when at low ISO levels, but if you want still fairly sharp at high ISO, then the 5DII holds it's sharpness much better in higher ISOs
If you're shooting indoors lots, I might recommend the 5DII over the 7D just because of the ISO handling.
if you're doing mostly sporting, go with the 7D
Exactly where I am sitting now between the two
I can only hope they will give the 5DIII the AF out of the 7D or 1D. I don't plan on using either for video, so I am keeping that out of the equation. Just going to use it for theater,landscapes and jet planes. Buying both is just not going to happen.
Kevin Goto
2000 740i-Annalisa (sold 2018) 2008 335i-Weebl. Weebl may wobble but has DTC 2012 X5d in Sparkling Bronze ( The Ultimate Cat Carrying Machine)-RIP BMW buyback 2019:2017 A3, 2018 Audi SQ5
      04-29-2011, 04:21 PM   #179
The1
Drives: white 135
I picked up the 7D mainly because i was trying to do a lot of sport application with the 5DII and the auto focus just wasn't where i wanted it to be, but i learned tricks to avoid the problems, if the sports i was taking pictures of didn't have a predefined course, that might have been a different problem altogether as i was prefocusing before the subject reached it's mark. I also wanted it for the missed opportunities being recovered by the fast frames persecond, so if my timing was too early or too late, i had 2x as many shots to get the right one in rather then coming up with no shots at all.
but a good chunk of the time i ended up using the 5D anyhow because i had gotten so used to the trigger weight and the full frame with the lenses i already have.
so if i've been taking pictures of birds or stuff like that, i've been using the 7D mostly because of it's focus and the clarity and reach since i have so much more light to work with.
but walking around disney and such, i would use the 5D just because of the full frame sensor, and when going in buildings i had the better ISO handling.
They are both great cameras, the 7D addresses short commings of the 5DII.
I find the 7D doesn't handle changes in white balance as well, they tend to look a little off compared to the near perfect white balance on the 5D
it's a bitch adjusting from APS-C sensor to full frame when you're using the same lens on each camera... you get used to one focal length, and then it changes so much when you switch body.
I do like the natural vignetting that occurs with the 5DII and the extra DOF the full frame sensor allows you the use of.
hope these things help.
Dcstep shoots both the 5DII and 7D as well, so if you go on his flickr, you can kind of compare and contrast the pictures he's taken, and if he reads this he may have some input too.
      04-29-2011, 04:47 PM   #180
Chewy734
Drives: 2006 BMW 330i ZPP, ZSP
them talking about lunch is making me hungry!!!
haha... it gave me the opportunity to run home from work and not miss too much.
when you click the purchase, does it buy you a chance to sit in on the class? or let you buy the download after it's all finsihed?
i can't figure out what the purchase is for.
When you click purchase is lets you buy/download the entire workshop after it's finished.
      04-29-2011, 04:48 PM   #181
Chewy734
The1, if you buy it... mind sharing? I can recode and host
      04-29-2011, 04:48 PM   #182
The1
Drives: white 135
perfect, i bought it seeing that the price went up after may 1st trying to make education cheaper
      04-29-2011, 04:51 PM   #183
The1
Drives: white 135
sure.
i bought it mostly because he's covering so many subjects that at some point i'm going to get maxed out for what i retain.
and i'd still like to have a weekend where i can choose to do things since this will be the first sunny weekend in about 2 weeks.... it's rained almost every day.... I'm going stir crazy!!!
      04-29-2011, 04:53 PM   #184
Chewy734
thanks man. I wasn't able to take notes at work, and he's covering a lot now and am facing the same issue... can't remember it all
I'll PM you later this weekend and see if we can get it going.
      04-29-2011, 04:54 PM   #185
The1
Drives: white 135
sounds good, I think i'll learn more off of the stuff tomorrow and sunday, most of this stuff today is review, but it's nice to have the review and re-enforce previous learnings.
      04-29-2011, 04:56 PM   #186
Chewy734
yeah... but honestly, even though we might know this stuff, how often do you consider this stuff when buying a lens?
      04-29-2011, 04:58 PM   #187
The1
Drives: white 135
haha, me, usually...
I put a lot of time into my lens choices.
I still make mistakes though, but that's why i keep a close eye on the return policy.
and when i buy one, i make sure i go out shooting right away, or asap, and take a few hundred shots if time permits.
      04-29-2011, 04:58 PM   #188
Chewy734
that's smart.
      04-29-2011, 04:58 PM   #189
The1
Drives: white 135
that's how i decided against the 17-40mm F4L
I just wasn't satisfied with it.
      04-29-2011, 05:17 PM   #190
Chewy734
the comparisons he's showing are nice, because it's hard to sometimes find those direct comparisons on the internet.
      04-29-2011, 05:19 PM   #191
The1
Drives: white 135
the red headed one was pretty cute...
yeah, this is really cool see, I never put that much thought into lens selection....
makes so much sense though, I have a female model friend who is 6'1 and i was going to get her to help me get experience shooting, and it's making me think i should be using telephotos to shrink her down a little.
      04-29-2011, 05:20 PM   #192
scollins
Bootleggin' 'n Gunrunnin'
scollins's Avatar
137
Drives: 2024 X3 M40i
ZACK IS BACK! Awesome, free, live workshop happening right NOW.
http://www.creativelive.com/live
Thanks for the link! Been watching but will have to step away shortly.
I think I'll check into downloading/buying the workshop.
Scott
2024 G01 X3 M40i, Brooklyn Grey Metallic /// 2015 F15 X5 35i, Space Gray Metallic, 99K miles /// 2013 F30 320xi, Mojave Metallic, 112k miles
2019 Ford F450 STX, Oxford White
2013 Ducati Multistrada Touring S, Red
      04-29-2011, 05:21 PM   #193
The1
Drives: white 135
keep tabs, i purchased, so it will hopefully be up soon for me to download and I'll get chewy to host/encode it.
      04-29-2011, 05:23 PM   #194
Chewy734
It also depends on the perspective and the background too... the 135 f/2 is looking real nice now though.
Glad you're enjoying it. This guy's awesome. I have his one light dvd downloaded and it's great! Amazing what he does with a single strobe.
      04-29-2011, 05:25 PM   #195
The1
Drives: white 135
yeah, he's making me want the 7-200 2.8, which i have the F4, and it's an incredible lens.... but it just isn't a 2.8
yeah, i've been wanting to test out the 135 F2 for a little while. would be amaizing for some of the sport stuff i've been doing. especially with low light indoor.
      04-29-2011, 05:26 PM   #196
The1
Drives: white 135
this is also making me want to leave my 7-200 F4 on my camera more often
      04-29-2011, 05:30 PM   #197
The1
Drives: white 135
I love how he does a sum up after all his big conversations... He's a good teacher.
      04-29-2011, 05:31 PM   #198
Chewy734
^+1000
