2010 2011 BMW 5 Series Forum F10 new wheels and tires HELP! |
04-22-2020, 08:23 PM | #1 |
Rep 10
Hey y’all,
I just put on some 245/35/19 on some 19x9.5 with 10mm spacers in the front and I put some 285/35/20 on some 20x10.5 on the rear both with 35mm offsets and I’m running into some error codes is this normal? Is there a way I can remove the error codes and tune my speedometer to cope with the staggered offsets ? These went on an F10 535I I’m not having any running issues in the front or rear. Thank y’all for any information y’all may have ! |
04-22-2020, 10:04 PM | #2 |
Rep 14,521
what codes are you getting? usually with xdrive if you're more than i think 1% rolling diameter you can get errors but on a RWD?
04-22-2020, 10:45 PM | #3 |
Rep 305
So you got 19" fronts and 20" rear, correct? If that is so your setup is messed up and that's why your car is throwing codes. Your speedo is off by 7.8% and recommend max diameter difference is plus or minus 2.5%. Yours is at 8.26%
Where did you get this setup from? Check your setup here if you want to see for yourself. Calculate errors https://www.errolstyres.co.za/odcalculator Tire size comparison https://tiresize.com/calculator/ Speed reading https://www.discounttire.com/learn/tire-size-calculator Last edited by top ramen; 04-22-2020 at 10:54 PM.. |
04-23-2020, 11:09 AM | #4 |
Rep 697
Drives: 2013 535xi
Yep, I was more polite on another thread, but this setup is indeed messed up. His tire overall diameter difference is 8% between front and back. I used wheel size.com calculator here:
WheelSize.com
2010 Z4 35i, Crimson Red, beige interior, 6sp manual, Adapative Suspension 2000 528i, Cosmo Black, beige interior, Sport package (retired) |
04-23-2020, 11:12 AM | #5 |
Rep 10
I don’t know the codes off the top of my head but I can surely get them later! I didn’t think I’d get any codes since everything I read on this site didn’t mention anything about staying within 1% of the original set up.
04-23-2020, 11:14 AM | #6 | |
Rep 10
04-23-2020, 11:21 AM | #7 | |
Rep 14,521
04-23-2020, 02:30 PM | #8 | |
Rep 5,399
https://www.1010tires.com/Tools/Tire-Size-Calculator Tire Size Min Max Diameter 235/30R20 8.00in 8.50in 25.55" -0.78% 285/25R20 10.00in 11.00in 25.61" -0.55% 245/30R20 8.00in 9.50in 25.79" 0.14% 295/25R20 10.00in 11.00in 25.81" 0.21% 185/40R20 - - 25.83" 0.29% 215/35R20 - - 25.93" 0.67% 305/25R20 10.50in 12.00in 26.00" 0.98% |
04-23-2020, 03:41 PM | #9 | |
Rep 10
04-23-2020, 03:56 PM | #10 | |
Rep 5,399
Here are a few; just plug in the factory size and then the new size you want... https://tiresize.com/calculator/ https://www.discounttire.com/learn/tire-size-calculator https://www.sizemytires.com/calculators/compare |
04-23-2020, 04:33 PM | #11 | |
Rep 10
For me to keep the wheels that I have I'll go with the same size for the fronts and for the rear I'll use 285/30/20R can one of yall double check to make sure this is right so I don't mess this up again XD Last edited by Cschules-535I; 04-23-2020 at 04:43 PM.. |
04-23-2020, 05:20 PM | #12 | |
Rep 5,399
If you are sure you have a 245/35/19 up front, you would need 295/25/20 (also a .15% difference). |
04-23-2020, 06:16 PM | #13 | |
Rep 10
04-23-2020, 06:20 PM | #14 |
Rep 235
04-23-2020, 06:48 PM | #15 |
Rep 10
04-23-2020, 06:56 PM | #17 |
Rep 10
04-23-2020, 09:19 PM | #18 | |
Rep 697
Drives: 2013 535xi
Cschules-535I, ezaircon4jc gave you good advice. You are messing around with tire sizes, and in particular, tire diameters, that are straying from what BMW intended. Every normal setup, whatever the wheel size and tread width, keeps roughly the same tire diameter, for both front and rear. If you mess around with that, particularly when you change the front from the rear, then you get issues with xDrive if the difference is more than 1%. Given your error codes, it also looks like you get issues with ABS & traction control if you stray a significant amount like you have done with an 8% difference between front and rear. As stated, go to a tire calculator, and look for equivalent tires to 245/45/18 (or 245/40/19 which is stock for the OEM 351M wheels your picture shows). Then go from there. 'Tuning' the tires as you've said elsewhere is just going to ignore a very real problem with improper tire sizes. As I said in the other thread you started, both your front and rear tires that you chose are not normal BMW-recommended diameters. The fronts are too small, and the rears are too large. Changing just one or the other will solve the front/rear differential problem, but then you still will have either undersized or oversized tires all around. As an aside, since it might be this that is causing you confusion (and you are not the only one), the '35' in a tire size (245/35/19 for example) is NOT a dimension. It is a ratio. It means that the sidewall height is 35% of the tread width. With the example of 245/35/19, it means the sidewall height is 35% of 245mm.
04-24-2020, 09:40 AM | #19 |
Rep 305
My recommendation is not trying to find the right tire size but to get the same size rim all around four corners. If you're trying to find the correct tire size to get it in spec and once you do find that setup it's going to look weird as hell. The rears are going to have a thinner sidewall and the fronts are going to have a thicker side walls.
So best decision is what do you want to stick with 20" or 19". |
cdmulders330.50 |
04-24-2020, 11:52 AM | #20 | |
Rep 5,399
04-29-2020, 05:37 PM | #21 |
Rep 1
Tire shopping for Houston roads
Houston roads had me shopping for Wranglers, but I'm not ready to part with my F10. I'm looking to put 295/45/20 for my rear tires, and 265/45/20 for my front Is that the thickest sidewall that will fit on the 2011 535i?
