2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes wheel offsets
      02-06-2019, 04:53 PM   #23
BMWway
Denmark
Drives: BMW F11 LCI 520xdrive
Thanks a million.
This is what we ended up with. Medium aggressive look for winter setup with my VMR V710 Gunmetal
8.5x19" ET35 245/40 R19 and 5 mm spacer
9.5x19" ET45 275/35 R19 and 5 mm spacer
I will also install Eibach pro-kit springs 30 mm in front and 20/25 mm in the rear via koding.
I hope everything will work out and it will look good.
      02-07-2019, 02:43 AM   #24
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
That's a great winter setup!
Post some photos when you have got the wheels mounted.
      02-07-2019, 10:14 AM   #25
BMWway
Denmark
Yes I will.
For my summer setup > BMW 312 ferric grey 20".
I´m bit unsure about those spacers..
8.5x20" ET33 245/35 and 5 mm spacer = ET28
9x20" ET44 275/30 and 10 - 12 - 15 mm spacer ?
Rear:
if 10 mm the rear will poke 0,4 mm more than front = flush. (ET34)
If 12 mm the rear will poke 2,4 mm more than front. (ET32)
if 15 mm the rear will poke 5,4 mm more than front. (ET29)
What do you think?
      02-07-2019, 12:33 PM   #26
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
I use rear wheels that are 5mm more aggressive than the fronts on my F11.
I think it looks good!
      02-07-2019, 02:09 PM   #27
Flyguyin23
Flyguyin23's Avatar
46
Drives: 15' M sport 528i dark blue
Hey gents!
Im looking into new wheels to purchase next month. I want a superflush look and i was hoping for your imput. I want a crazy convaced and flush look but im unsure about the offset.
im looking at Rohana RC 10 in white and silver.
I talked with a few buddies of mine and they reccomended 20x9 20 in the front with 245/35 tires and 20x10 25 in the back with 285/30 tires.
i dont mind a tiny poke becouse i havent installed coils yet and i really dont want anything to do with spacers.
any thoughts?
      02-10-2019, 03:53 AM   #28
BMWway
Denmark
Originally Posted by Flyguyin23 View Post
Hey gents!
any thoughts?
Your tire setup needs to be under 1% in diameter if its an xdrive. Your mentioned tire setup is 0.52% and should be fine but my "tire guy" told me - max 275 on an xdrive.
Original OEM rims is in the front are 8,5x20 ET33 and in rear 9x20 ET44 but that's not an aggressive stand. I'm having that setup but I will most likely use 5 mm spacer in the front and 10 mm in the rear for medio aggressive stands.
To be honest I'm not sure about 9" 10" on an xdrive - seems too aggressive but I can't say for sure if it would work.
      02-12-2019, 03:07 AM   #29
garlap
Drives: BMW F11
8.5x19" ET20 245/40 R19
9.5x19" ET25 275/35 R19
Will it rub against?
      02-14-2019, 05:16 AM   #30
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
Fronts will fit.
The rears are aggressive though. I'm not sure if those will fit without rubbing.
      03-03-2019, 04:15 PM   #31
BMWway
Denmark
Hi guys
So finally a picture. Really happy with the result (winter tire setup). Summer setup (20" oem) I think I will go for a bit more aggressive look.
VMR V710 Gunmetal.
Pirelli Sottozero 3 runflat with bmw star.
245/40 R19x8.5" ET35 and 5mm spacer.
275/35 R19x9.5" ET45 and 5 mm spacer.
Also mounted Eibach 30 mm lowering springs in front and the 20 mm in then rear via coding. There's no loss in comfort at all I actually think the car feels as it should have felt from start. Better handling and looks. Bumps are less noticeable in the front. Seems that the Eibach springs are better tuned in for the car than the oem springs.
      03-08-2019, 01:12 AM   #32
BMWway
Denmark
Originally Posted by .BMW. View Post
Fronts will fit.
Hi, did you see the pictures?
I was thinking for my summer set up, having 5 mm spacers on the front and 10 mm in the back for my OEM wheels.
Do you think it will be too aggressive?
20x8.5 ET33 and 5 mm spacer = ET28
20x9.0 ET45 and 10 mm spacer = ET34
      03-08-2019, 01:38 PM   #33
remmib
remmib's Avatar
Norway
1569
Drives: 2013 F10 520d M-Sport
Fronts will fit.
20x9.0 ET55 and 10 mm spacer = ET34
Not a problem, I've actually got 12mm front and 18mm spacers with my 19'' OEM wheels that I use as a winter set up.
      03-09-2019, 03:37 AM   #34
BMWway
Denmark
Sounds aggressive :-)
Also an xdrive?
      03-09-2019, 04:19 AM   #35
remmib
remmib's Avatar
Norway
1569
Also an xdrive?
Not that aggressive, no rubbing. It's not an xDrive, but it's the same fitment.
