2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes All 4 brakes get hot
      01-09-2019, 10:56 PM   #1
Eisbaer Lars
Eisbaer Lars's Avatar
Drives: E65 750i; F10 550ix sedan
Hi all,
bought last week a 2014 550i xDrive and realized that all 4 brakes get with normal driving in the city - meaning no high speeds and no hard braking - really hot.
I drove today 2 miles home from the city - arrived in the garage and the brakes where so hot that I could not touch them. ACC was not on the whole ride today.
I realized as well that the car slows unusually fast down as soon as I get of the pedal - not the normal rolling out feeling when you just go off the pedal - a feeling as either the transmission or the brakes slow the car down.
Has anybody else seen this on an F10?
Thanks for any ideas what that could be.
      01-09-2019, 11:12 PM   #2
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
are the brakes newly installed? i'm wondering if the tech forgot to spray down the rotors with brake cleaner as the rotors have a chemical on them to keep them from rusting while in stock? I had the same problem with my truck when I replaced all 4 rotors. totally glazed all the pads and had to replace them. didn't know about the chemical that's on the rotors.
      01-10-2019, 09:36 PM   #3
Eisbaer Lars
No they are not new - bought the car used and they seem to been a few 100 to about 1000 miles on the ride.
      01-11-2019, 11:09 AM   #4
cdmulders
cdmulders's Avatar
Drives: 2013 535xi
I've never experienced hot brakes, such as you describe, with my F10. Then again, I've only ever checked the wheel temperature after a long run on the highway, and never checked the actual temperature of the rotor. I still think that checking wheel temperature would give you an indication of overheated brakes.
When decelerating, there does seem to be a bit of increased drag due to the regenerative alternator cycle which is indicated by the blue bar in the instrument cluster when driving in normal / comfort mode. I don't think that that is what you are describing.
The only time I've actually felt the brakes bind was when it was -30C outside (-22F) or colder, and the brakes would take longer to release after a stop. This makes perfect sense given the likely thickening of the brake fluid at that temperature.
In my humble opinion, your experience is not normal and your brakes are not releasing fully when you are not braking.
2010 Z4 35i, Crimson Red, beige interior, 6sp manual, Adapative Suspension
2000 528i, Cosmo Black, beige interior, Sport package (retired)
      01-11-2019, 12:36 PM   #5
Originally Posted by cdmulders View Post
...In my humble opinion, your experience is not normal and your brakes are not releasing fully when you are not braking.
Agree. Your calipers are hanging-up.
Kyngofpop676.00
      01-11-2019, 11:49 PM   #6
lsturbointeg
sounds like the seals in the calipers are sticking. I don't know if the calipers can be rebuilt or they need to be replaced?
      01-13-2019, 06:42 AM   #7
TEF
Drives: 16 X3 28d/18 540d xdrive
2018 540d xdrive  [0.00]
2016 X3 28d  [0.00]
Hard to believe that all four calipers are suddenly sticking due to faulty seals. Perhaps one should focus on a problem in anti-lock braking system. That would have the potential of applying braking force to all wheels and hence the heat even if driving short distances.
      01-13-2019, 11:32 AM   #8
cdmulders
cdmulders's Avatar
Drives: 2013 535xi
I was thinking the same thing. Electronically - a faulty module. Mechanically - something sticking in the brake master cylinder. Maybe it's time for a brake fluid flush if water has gotten in and caused some contamination.
      01-13-2019, 08:12 PM   #9
socale39
Drives: 04 545i SMG
I guess I’ll be the one to ask. Do you use one or two feet to drive?
      01-13-2019, 09:29 PM   #10
windowmaker
Drives: 2013 550i M Sport 6MT
I mean when I was still using stock pads I was feeling a lot of heat emanating from the wheel wells when walking by, after typical commute daily driving. No doubt you shouldn't touch the brakes after driving, they are expected to be scalding. Consider that your car is over 4k pounds and the only way your car is able to stop is via medal against metal friction.
The one thing that's suspicious is
It could be a seized caliper or something else that's been suggested by others but watch out since shops will love to replace parts that don't need replacing in order to help you "narrow down the issue".
Edit: You could try to use a laser IR temperature reader and compare temperatures between each wheel and see if there is any significant difference between left and right for either of the front/rear pairs.
https://www.amazon.com/s/ref=nb_sb_n...s=laser+ir+gun
https://www.aliexpress.com/premium/i...d=0&isViewCP=y
      01-15-2019, 08:48 AM   #11
Surly73
Drives: '11 535xi 8AT KWv3 MPE MHD xHP
I've been wondering if there's any real problem here either.
The OP says the brakes were too hot to touch, and a lot of the follow up responses were responding as if he said the wheels are too hot to touch.
The brake discs are going to be too hot to touch, even from pretty minor braking. Don't do that.
Look for differences side to side. Look for a difference in brake dust build up (quantity or colour). Hit the highway for a few miles then get out and look for a smell or intense heat radiating away from one wheel different than the others. Listen for noises.
      01-15-2019, 08:02 PM   #12
Originally Posted by Surly73 View Post
The brake discs are going to be too hot to touch, even from pretty minor braking. Don't do that....
Don't know about that. I drove Pikes Peak (Colorado, 14,110' driving summit) about 16 years ago. I stayed off the brakes as much as I could, but had to use them occasionally on the way down and at the brake temperature check station. The ranger couldn't believe the rotor temperature (taken with a temp gun). It was around 100º, IIRC. He asked me if I used my brakes at all and I said pretty much only to stop at his station. If the rotors had been too hot (I don't remember the exact temp) they make people stop for a minimum of something like 15 minutes to allow cooling.
I guess it all depends on what the OP considers "really hot." The OP also hasn't been back here since yesterday morning...
      02-13-2019, 03:06 AM   #13
Eisbaer Lars
Thanks all for your contribution - lots of good advice here which I have to check - will be back with my findings.
