2010 2011 BMW 5 Series Forum F10 F10 550 night vision diy request |
11-15-2015, 11:27 PM | #1 |
Rep 1,085
Drives: 2013 BMW F10 550 Xdrive Msport
So, I just had my car coded by bimmertech yesterday and my self installed surround view works perfectly! Cost about 2 grand for all of the parts which I out together here on the forums and on eBay. Bought cables and coding from bimmertech and they provided me install instructions as well.
So, on to my next retrofit. Night vision! Has anyone acquired the retrofit guides for the install? Looking for all of the part numbers and the diy guide to start this project. Thanks in advance |
11-16-2015, 02:42 AM | #2 |
Rep 5,050
Sorry to go off topic so quickly, but I have a Bimmertech front camera to install on my 2015 F10, how difficult did you find it getting wires through the front firewall?
11-16-2015, 08:54 AM | #3 | |
Rep 1,085
Now, running the wires... Follow the factory wiring harness and clip the OEM zip ties that are mounted in the car. Run your cable and insert a new zip tie. See attached instructions. The drivers side (left) is easy and straight forward. Remove the kick panel on the drivers side (disconnect battery first to ensure no air bag deployment and prevent error code being thrown). Drill a hole in the rubber grommet and run your cable through. I removed the colored end connector before running the cable to reduce size of hole that was needed. Once cable is run, use a silicone gel to seal hole so no moisture gets through. Now, the Passenger side (right), THAT is a little more difficult. You will have to remove the top portion of the blower motor. Not really hard, just a little tedious. Again, remove passenger side kick panel and make sure battery is disconnected. Remove the screw that holds in the fuse box and set to one side. Go into engine compartment, remove right side plastic engine skirt. Take the 3 or 4 screws out of the top electrical box, disconnect red power wire and remove. There will be 4 more screws that hold the blower housing in place. Remove those and then remove the 3 screws holding blower motor in place. There are several electrical connections to disconnect, but all are pretty straight forward. Run you passenger side Camera cable in through the rubber grommet and into the blower motor area. Ensure you zip tie the cable against OEM wiring harness to make sure the blower motor does not rub against your camera cable. You will be able to see right into the passenger side floor board once you remove the blower motor so it will be common sense on how to run. Bring into passenger area and then make sure you run the cables up away from passenger feet so there is no damage to occur to wires. Run the two cables over to drivers area. ...mike |
11-16-2015, 01:29 PM | #4 |
Rep 5,050
Hi Mike, thanks for the detailed instructions which should come in very useful. The camera I'm installing is a single unit that faces forward and fits in the front centre lower grill. I have no idea how this comes off but it looks like I'll have to remove the bumper in order to remove the grill. From there I guess I’ll have a choice which way to route the cable, unfortunately all of the diagrams I’ve seen refer to LHD cars and I don't know whether the firewall is the same or mirrored in a RHD car, but from what you’ve said the drivers side (left) is easiest, so I’ll have a go at that first. Many thanks
11-16-2015, 05:36 PM | #5 |
Rep 1,085
I have some install instructions for night vision for the previous model. Will post later.
Her is the link for the E60 DIY. If anyone has the f 10 DIY, I would appreciate a post here. I have the night vision camera and now need a part list for the rest. http://www.bimmerfest.com/forums/att...2&d=1397910637 Camera part number for 04/2013 build is 66549203322 Last edited by mikekilpatrick; 11-22-2015 at 03:14 PM.. |
05-17-2016, 02:29 PM | #6 | |
Rep 158
05-18-2016, 01:39 PM | #7 | |
Rep 1,085
4 screws for top cover Make sure to disconnect battery in trunk Disconnect Red Power wire under cover in engine (the one with the 4 screws) Remove 2 more screws and then power assembly Remove screws for blower motor Remove blower motor You can now see into the passenger compartment Will look for pics. Mike |
05-18-2016, 10:52 PM | #8 | |
Rep 158
05-18-2016, 11:24 PM | #9 |
Rep 1,085
