12-18-2013, 06:37 AM | #1 |
Rep 1
base HU output vs MS-8
Hi All,
I completed my upgrade from the UK 6 speaker setup back in march. But i cant handle the hiss at low levels so i'm changing a few things round: ive taken the amp and alpine DSP out and for now am running the focal vrs's and standard 6.5" underseat subs off the front channels and the vibe slick 40's off the rear channels. Actually it sounds pretty good, but the focals start popping at 3/4 volume. my intention was to do away with 2 units and stick an MS-8 in to DSP and power everything. But having been reading the specs of the standard head unit it states 25W per channel, 4 channels. obviously this means 25W is powering the focals and the underseat on the front but the MS-8 only states 18W per channel. my question is as follows, will be under powering the focals off an MS-8, or as I will be powering the underseats individually off separate MS-8 channels to the focals will it actually make things better? Or am i going to make things worse and need an amp after the MS-8, if this is the case. I really can't be bothered. |
12-20-2013, 12:21 PM | #3 | |
Rep 13,001
Just try the MS-8 as is, you may be surprised with the volume range of its internal amp.
