2010 2011 BMW 5 Series Forum F10 Brake upgrades from other BMW models on F10 |
07-15-2020, 10:55 PM | #177 |
Rep 951
haha adding more confusion or clarity, whichever way you look at it, you should be able to install stock M5/M6 rear brake calipers/carriers with the 370x24 rear rotors from the F01, onto your F10s. Here is my latest fit check, have not swapped the setup yet since I maybe switching my DSC and didn't want to bleed the system twice..
07-29-2020, 07:01 AM | #178 |
Rep 1
As the title states I have begun to play around with retrofitting brakes from other BMW vehicles on my F10 535i xDrive in hopes of achieving cheaper options for an upgrade in brake performance. Hopefully this thread will be a nice source of information for others wishing to do the same and possibly help out with what fits and what doesn't.
So far from my online research and personal experience it seems that (7 Series ) F01 front brake calipers and rotors are a direct bolt on to our cars. Bigger caliper while still a single piston, uses a 374x36 Rotor. The stock F01 rear calipers do not fit as the F01 doesn't use the electronic brake on its caliper. It seems that E60 stuff may fit on the front as well based on online research but not entirely sure as I have not tried it personally. E60 M5 calipers are cheap and 2 pistons with a 374x36 rotor as well. G11 Brakes sadly did not fit. I was able to bolt them on my F10 and the front calipers themselves mount up to the carrier but will not work due several design changes of the cars. BMW went from 5x120 to 5x112 bolt pattern, therefore the brake pad of the G11 caliper interferes with the hub of the 5x120 rotor, it also was not centered on the rotor itself, but a washer or spacer could have fixed that. The rear G11 calipers did not fit at all. I am in the process of fitting the front brakes from an E70 X5M/X6M. These brakes are massive and are a Brembo caliper with four pistons. The rotors are also massive at 395x36. So far the X5M caliper bolts on to the stock carrier without an adapter and everything appears to line up. Still waiting on new brake pads and rotors I ordered to fit everything up and test them.
Complete guide about https://eta-govt.com/sri-lanka-on-arrival-visa-fee-for-indian/] sri lanka arrival visa fee for Indian[/url] is available.
07-30-2020, 02:28 AM | #179 | |
Rep 34
09-10-2020, 06:48 PM | #180 |
Rep 951
Sooo I was just looking and in Europe, the X5s and X6s also had another brake option (385x36) that "should" be a direct fit on the F10s:
This is the Caliper that is bigger than the 760i/750i (EUR) caliper but smaller than the X5m : https://www.realoem.com/bmw/enUS/sho...diagId=34_1584 And the corresponding rotor: https://www.realoem.com/bmw/enUS/sho...diagId=34_0976 This probably is the best non M upgrade that could be done..but someone will have to try it out..Wish it was available state side! |
09-17-2020, 12:16 PM | #181 |
Rep 46
Where did you find slotted and or drilled F01 374x36 rotors ? I followed the guide here and got the calipers but can find nicer looking rotors
09-17-2020, 11:11 PM | #182 | |
Rep 140
10-17-2020, 10:16 AM | #183 |
Rep 1,207
Anyone recommend better brake pads for a UK spec F10 535d?
Coming up for replacement... and wanted something better than BMW stock. Not keen on changing the whole brake setup; but is there a better pad compared to the stock ones? Thanks...
11-01-2020, 11:43 AM | #184 | |
Rep 3
Will 535i EU Caliapers fit on stock 18" wheels?
It appears caliper housing for the 535i EU and 550i EU are identical per the parts number listed above. Naturally the rotors are bigger for the 550i EU therefore different pads and carriers part no, wonder if the biggest rotors (550i EU) will fit mine (535i US), if not then I will have to order the 535i EU spec'd Rotors, carriers, pads. Nearly all ebay listing (used in US) come with both things caliper & carrier spec'd for the 550 EU version since they all from 7 series part outs. Thank you Last edited by MagaTrain45; 11-01-2020 at 11:50 AM.. Reason: clarifcation |
11-01-2020, 12:38 PM | #185 |
Rep 34
18" oem rims will fit the European F10 550i and the F01 760i callipers with 374 mm rotors
F10 550i 34116786817 34116786818 34116786829 F01 760i 34116786827 34116786828 34116786829 |
11-04-2020, 02:34 PM | #186 |
Rep 538
Since I don't have the time to roll through almost 10 pages...On my US Spec 535i, can I directly bolt-on US/EU Spec 550i brakes?
I've never done a brake job before and my rears are almost finished, so I figure I may as well upgrade everything. I was hoping to do a 550i upgrade if that's possible without crazy modification.
'07 Montego Blue/Saddle Brown E92 335i - 6spd. - SOLD
'16 Carbon Black Metallic F10 535i M-Sport - TOTALED 11/21/21 '13 Black Sapphire Metallic F30 335i M-Sport - unknown charge pipe, MSport Exhaust, 20" 405M wheels, $61k MSRP, CF M4 Mirror caps & Spoiler, NGK plugs, Dinan Coils, BMS intake |
12-03-2020, 01:36 AM | #187 | |
Rep 951
12-04-2020, 08:39 AM | #188 |
Rep 538
Perfect, that's what I thought. I'm assuming the 550 brakes are slightly larger, which would increase the stopping power on a 535. I'd upgrade the lines to SS braided as well.
12-09-2020, 01:22 PM | #189 | |
Rep 951
01-15-2021, 09:02 AM | #190 |
B1990BB
Rep 43
Latest Updates
Well, its my latest setup, but had quite a few problems :
I just found out that the rotor should be 355, but its being modified to 380mm and my right side is having a squak and vibration issues, its been back and forth to my friends workshop and he cant solve it at all. it vibrates I can feel it in my steering wheel when I brake from 100km. and squaks on low speed, or slow climbing of the car when traffic and happens all on the right side only.
01-18-2021, 04:21 AM | #191 |
Rep 112
I've been active on this thread nearly since its inception and I felt compelled to come full circle and share that I've actually applied the info here into my car! I've upgraded the brakes on my 530d to have X5M calipers in front and 550i calipers in the rear.
So as to not further clutter this thread, I've created a separate thread specifically for the upgrade that I did: https://f10.5post.com/forums/showthr...9#post27129469 A huge thanks to the usual suspects on this thread for all the info they shared about various brake upgrades for the F10, as I never would have done this if this thread didn't exist! I'll leave you with a few pics of the final output, but check out my separate post if you want the gory details of this mod. |
ezaircon4jc4551.50 superbogel4.50 |
01-20-2021, 07:19 AM | #192 | |
B1990BB
Rep 43
this looks badass!
Johnkwick24.00 |
01-26-2021, 02:55 AM | #193 |
Rep 112
01-28-2021, 10:02 AM | #194 |
Rep 64
Hi all, would the 750i caliper mod, coupled with 374mm rotors, work with the following aftermarket/non OEM 20 inch wheel?
front 20 x 9 ET35 rear 20 x 10.5 ET35 It's a concave setup, so should I be concerned about clearance between the 750i caliper when using these wheels, with this brake upgrade? |
01-28-2021, 10:24 AM | #195 | |
Rep 112
Do you have these wheels on your car now? If so, check how much clearance there is between the spokes and caliper now. |
01-28-2021, 12:52 PM | #196 |
Rep 64
Hi there Bozman.
Just had a look and measurements as follows: 3.7cm clearance rear 4.9cm clearance front These are the distances between the current stock caliper and the part of the inner alloy wheel, which is closest to the caliper, which happens to be the central hub part of the alloy if that makes sense. The spokes, are in excess of the above measurements, even at their respective points, whereby they curve towards the caliper. So distance between spokes and caliper is greater than the above measurements. Hope that makes sense? Last edited by Flying_Squad; 01-28-2021 at 01:00 PM.. |
01-28-2021, 02:47 PM | #197 |
Rep 112
I understand what you mean by those measurements. That's what I was trying to portray in my head, so we're on the same page. In my opinion, the 750/760i calipers will be 100% fine with the wheels. You have plenty of space, and like I said, there is no real difference in overall dimensions between the two calipers.
01-28-2021, 04:06 PM | #198 |
Rep 64
Many thanks Bozman, appreciate all your contribution and knowledge regarding this mod.
Were you able to source a supplier of drilled 374mm compatible discs for the 750i calipers in the end, here in the UK? I’ve seen some on eBay by Mtech, however not sure how reputable their discs are. |
