2010 2011 BMW 5 Series Forum F10 KWv3 with 295/30/20 rears rubbing |
05-16-2021, 08:30 PM | #1 |
Rep 2,591
Anyone else experience this issue? Installed v3's for xDrive cars and the rears are rubbing now on deep-ish dips, even when above KW's recommended Distance A (distance from nearest bolt to top of lower spring perch). 95% of the time it's not rubbing, but I can hear the dreaded squeal on those dips. I'm guessing I'm just running too wide a tire with too much offset, rears are 343M (20x10 ET 34) with 295/30/20 tires.
Any potential suggestions? Not against going down to a 285 but would like to explore other options as well.
2015 BMW 535xi
05-16-2021, 09:54 PM | #2 |
Rep 965
Happened to me on my RWD. Running 343s on Megan Coilovers. Running 285/30/20. I originally ran Hankooks but switched to Michelin A/S 3+ which has a really square profile. Had to raise the car 1/2inch almost
Blue Angel1026.00 |
05-16-2021, 10:01 PM | #3 |
Rep 2,591
You rubbed with 285's as well?
2015 BMW 535xi
05-16-2021, 10:52 PM | #5 |
Rep 2,591
Dang. Maybe some very minor fender pulling is in my future.
2015 BMW 535xi
05-16-2021, 11:23 PM | #6 |
Rep 965
05-16-2021, 11:48 PM | #7 |
Rep 2,591
Yea, I'll talk to my alignment/suspension guy and get his input.
2015 BMW 535xi
05-17-2021, 06:20 AM | #8 |
Rep 1,049
Thanks for posting, guys. I've been looking into wheels for some time and I don't get how the 343m can work on an F10 with 295's even though some claim they do. Seeing they rub even with a fat 285 confirms my suspicions. This has saved me a trip to go look at a set!
05-17-2021, 07:48 AM | #9 | |
Rep 2,591
2015 BMW 535xi
05-17-2021, 03:28 PM | #11 |
Rep 2,591
I'm at like 3 fingers already and it's still rubbing :/
2015 BMW 535xi
Bootmod3 Stage 2 | ER charge pipe | ER Catted DP | Remus Exhaust | Gplus FMIC | KW V3 | Turner Monoball thrust arm bushings | Wallet regrets ISTA VM Setup/Tutorial Last edited by Unspec; 05-17-2021 at 08:50 PM.. |
05-19-2021, 05:38 AM | #12 |
Rep 1,049
Wow, sounds like the Silvers were a much stiffer setup than the V3's! Remind me, you had the off-the-shelf 12k/8k rates and no Swift upgrade, correct?
05-19-2021, 08:57 AM | #13 |
Rep 2,591
Yep, I stayed at the default spring rates. I'm not sure what the rates were, but 12k and 8k sounds about right. I think the real problem in this story is the 343M's offset - ET34 is just a tad bit too aggressive for KW's/softer spring rates
2015 BMW 535xi
Blue Angel1026.00 |
05-19-2021, 11:34 AM | #14 |
Rep 965
Megan's are 10k and 4.5k....... There has to be something wrong here. I am running 1 finger.
05-19-2021, 04:48 PM | #15 | |
Rep 2,591
Mine might be closer to 2 fingers actually.
2015 BMW 535xi
05-20-2021, 11:46 AM | #17 |
Rep 2,591
I already have the 650i rear sway anyhow. I'll see if going up a click will help.
2015 BMW 535xi
05-20-2021, 02:00 PM | #19 |
Rep 2,591
Steel fender, rubbing half way down the tire sidewall. Will post pictures later
2015 BMW 535xi
05-20-2021, 03:54 PM | #20 |
Rep 14,521
KWv1's sitting on 21x11 -38mm 295/25r21 no rubbing!
