11-17-2010, 12:12 PM | #1 |
Rep 8,279
Euro Light Switch
On my E92 I was able to get the euro switch which gave me the rear fog option. I've seen post with members from Europe where the rear fog is standard on thier switch. Is it possible to order that for the stateside F10's?
Here's a link of what the switch looks like on nightcreature's thread. Look at his switch. http://f10.5post.com/forums/showthread.php?t=448447 |
11-17-2010, 01:05 PM | #2 | |
Rep 1,236
Don't you need to put in the wiring and the light itself? I would be interested too. I found this: http://www.realoem.com/bmw/showparts...75&hg=61&fg=35 |
11-17-2010, 01:48 PM | #4 | |
Rep 229
11-17-2010, 03:16 PM | #5 |
Rep 1,236
11-17-2010, 03:16 PM | #6 |
Rep 8,279
11-17-2010, 03:17 PM | #7 |
Rep 1,236
11-17-2010, 03:35 PM | #8 |
Rep 8,279
11-17-2010, 05:14 PM | #9 |
Rep 177
This conversion worked for most BMW's.
The US version lights are used for what I think is the "Assisted Braking" option where they light up on hard braking. Non-US versions use them for fog lights Unless something else has changed, you would only need to purchase the part pictured in the above posts, or the equivalent for the F10... |
11-17-2010, 05:24 PM | #10 |
Rep 1,236
But F10 no longer uses this "brake force" display. Instead, it is using a new "adaptive brake light" where the brake light would pulse rapidly on hard braking. This should be a lot more effective in warning the cars behind; the so called "brake force display" in older models is hardly noticeable. OTOH, it may mean uncertainties as to whether the rear fog wiring is in place or not.
11-17-2010, 05:28 PM | #11 | |
Rep 8,279
11-18-2010, 03:18 AM | #13 |
Rep 229
11-18-2010, 04:38 AM | #14 |
Rep 126
11-18-2010, 07:42 PM | #15 |
Rep 177
Guys here are links to what you can probably do. The E92 M3 guys found several solutions including buying a euro switch and exchange it with the one they had, or fiddle around with the original switch they had on their car to make it possible to switch the rear fogs. I have no idea if this works on F10's but I'm sure someone here would give it a shot and try.
Look at those links, there is more if u guys search for it... http://www.m3post.com/forums/showthr...o+light+switch http://www.e90post.com/forums/showthread.php?t=51749 http://www.e90post.com/forums/showth...light=rear+fog |
11-18-2010, 08:21 PM | #16 |
Rep 351
11-18-2010, 11:09 PM | #17 | |
Rep 8,279
I'll go with the the dealer this week to look into buying the switch and get back to you guys. |
11-19-2010, 06:37 AM | #18 | |
Occasionally frequent poster
3000
Rep 2,744
Looking forward to the Jimmy Bond rear facing machine gun option. Available in 2012 model year, I hear.
Current inventory:
F22 & G05 Cadillac CT5-V Blackwing w/3 pedals Past: E24,E28(3),E34,E36,E37,E38(2),E39(4),E46,E89,E92 (obviously),F01,F06,F10,F30,F87,G12,G30(2),G82(2) |
11-19-2010, 08:21 AM | #20 | |
Rep 8,279
11-19-2010, 08:33 AM | #21 |
S0THPAW
8717
Rep 7,846
