2010 2011 BMW 5 Series Forum F10 Pure Stage 2 Turbo Install is about to go down. |
08-06-2017, 11:02 AM | #177 | |
Rep 1,214
http://s1279.photobucket.com/user/JS...?sort=3&page=1 |
08-06-2017, 01:13 PM | #178 |
Dream crusher
984
Rep 2,421
I dont think Stuck is fraud. That's pretty harsh man. In any case Pure sent him a faulty turbo and he did post all the steps of what he did before concluding Pure turbo was at fault. I believe he's struggling with Pure and trying real hard not to bash them. Which is really nice of Stuck because that can quickly become a hateful post. There's no logs to post from a bad turbo. Pure needs to make things right posthaste.
Side note there's videos from ModBargin on instagram that posts a brand new M3 showing off their exhaust systems with smoke pouring out the exhaust. There's one on Pure showing a Camaro racing a Pure turbo M3 and at WOT smoke dumps out the back of the F80 M3. Thats a sign of early turbo damage. Because of that it is very probable he got a faulty turbo. Remember upgrading wheels and not compensating housing or thrust bearings is going to cause faster wear. The smoke you'll see in these videos is because the bearing can't hang with 100k plus RPMs. You have to upgrade all turbo internals. https://instagram.com/p/BW8I1qvBmbW/
IG: @bmwdoubles |
08-06-2017, 02:45 PM | #179 | |
Rep 1,128
08-06-2017, 04:10 PM | #181 |
Dream crusher
984
Rep 2,421
You think turbos are supposed to smoke? You guys are high. The more your turbo smokes the more power you make? You think that brand new M3 in that link I shared was supposed to dump a cloud of smoke on WOT? Your nuts.
You might be thinking of diesel turbos lol. Tech tip for the day: Smoke out of the exhaust of a BMW is usually oil being burned in the intake. The oil gets in there from a bad turbo. The other is coolant, but option B is less likely.
IG: @bmwdoubles |
08-06-2017, 06:36 PM | #182 |
Rep 436
Likewise, bashing is not a good policy, however, I am a firm believer upgraded turbos should always be to next higher OEM levels (if available, as I did on Alpina turbos with larger compressor section/exducer design and full internal upgrade). Fabrication shops do not necessarily have R/D tools or resources like Garrett Honeywell facilities.
Just an opinion. Good luck to all |
08-06-2017, 08:00 PM | #183 |
Rep 1,214
Well I hope everyone has had as much fun today and I have.
I took the fabricated inlet over to my friends place on the other side of town to TIG it together, got it back home and cleaned up the interior of the tubing where the puddle poked through. Here is one especially for Dollar Bill. Inlet installed from the top: Again but from the bottom: Packaging constraints are an absolute nightmare, this job was nothing short of miserable. 18 hours over the course of 2 days in a 90 degree garage sweating balls. $200 in parts/supplies/materials/welding. One large laceration in my palm. Oh, and I'll need another alignment as I had to drop the rack for access and now the wheel is off. and guess what Guess.... Nothing different than before performance wise, the only difference is now I have a god awful intake resonance under load that sounds like a slipping vbelt on an old jalopy. I guess that is why BMW uses plastic. |
08-07-2017, 01:12 AM | #184 |
Rep 332
Ouch, I was really hoping you would say this has solved the low boost problem. That bend in the inlet our cars take is definitely a restriction.
On my 2013, that part is metal, so I am surprised you are getting such an audible difference. On inlet you made, on the side away from the turbo, is there enough surface to cleanly clamp to? Below is pic of restriction in pipe from when I did my PS2 install, and the wrong inlet pipe I was sent that obviously did not work. I am interested in your progress.
2022 G82 M4 - Isle of Man Green w/Kyalami Carbon Bucket Seats - MST Intakes, SSR Downpipes, JB4, AWE Exhaust.
2013 F10 N55 (535i), Pure Stage 2, Fuel-It PI Platinum, Fuel-It Stage 2 LPFP, BootMod3, Custom Turbo Inlet, Custom Cary Jordan Tune, More.. SOLD! 1999 e36 M3 - Estoril Blue - Track Car - S54 Swapped |
08-07-2017, 01:20 AM | #186 | |
Rep 1,889
08-07-2017, 01:54 AM | #187 |
Rep 332
I can't say it isn't compatible, as I have told Stuck, Since installing my PS2, I haven't had the chance to fully troubleshoot why I don't feel I am getting the boost I would expect. I also live in AZ with very high IAT's right now, so this isn't the time of year to push for more boost.
I was thinking along the lines of having a boost leak or actuator not calibrated properly and I haven't ruled out those possibilities either. At 105 degrees ambient temp, I just have't brought myself to do this. I have only had a single quick conversation with Pure and they believe it could be a boost leak. Until I smoke/pressure test it I still have not ruled this out. As for results, my car FBO, prior to PS2, made 336HP on a Dyno Dynamics dyno. I will dyno it again once I feel it is making proper boost. Prior to PS2, my best ET was a 13.9 @ 102.9MPH. After PS2 I did a 13.1 @ 110.67. This is a significant upgrade, but I still think there is a lot more potential.
08-07-2017, 10:06 AM | #188 | |
Rep 1,214
On the upper mounting point, it uses the same location and mounts securely with the stock rubber isolated washer. Last edited by Stück; 08-07-2017 at 10:28 AM.. |
08-07-2017, 11:00 AM | #189 |
Dream crusher
984
Rep 2,421
If you closely inspect the OEM inlet you'll see there's a divot that almost looks like someone pressed their thumb on it when the plastic was hot. I believe that's there to reduce noise. You'll see weird pattern designs on the air intake too also which I feel is there to help with induction noises. Cheaper cars in some cases use straight up snorkels like helm holtz approach for noise cancelation.
IG: @bmwdoubles |
08-07-2017, 12:35 PM | #191 |
Rep 332
Did you have any problems with fitment using your pipe without the tight bend that is in the factory inlet?
08-07-2017, 01:01 PM | #192 |
Rep 1,214
It *just* touches the thermostat casting nipple, which you should be able to see in the picture above. It doesn't push on or displace the thermostat so I don't expect an issue. I will be monitoring it over time for wear, at least I planned to, but I don't know wtf I'm doing now. I want to scream from the roof tops at this point, this entire turbo debacle is bs.
08-07-2017, 11:12 PM | #193 |
Rep 1,214
So I got to thinking today about the screeching noise, the increased turbo spool noise makes sense but that noise really doesn't. Charles @ Pure was thinking the same. I found some material online of others (on totally different cars) having similar noises with aluminum inlets finding just the right resonance... but generally not much.
I thought maybe even though I'd double and triple checked everything I left something loose or disconnected in my physically exhausted state Sunday night. I figured I would take the smoke machine home from work and pressurize the charge system again with smoke post inlet fab and see whats up. Almost immediately I had smoke wafting upwards on the hot side. I could not make out the source from the top so I dropped the splash pan to find this... Huh.. those were nice and tight last night. As I looked at them closer... well shit they are actually broken! I looked around the other side of the subframe and saw the silicone coupler on the hot side charge pipe just hanging out loosey goosey. Now I bet is where the noise is coming from. After taking the car out last night after the inlet fab I thought the car felt peppier while warming up but I was only leisurely tipping into it. I didn't go WOT until I was on a freeway feeder and dropped from 6th to 3rd as I hammered down. That is when the screeching noise first happened and I'm willing to bet when the worm clamps let go. I guess the worm clamps that come with the FTP Motorsport hot side charge pipe only like being tightened down the first time. The second time? Nah. The straps straight snapped the efff off. I replaced both of the janky worm clamps with some 2.5" t-bolt clamps I had in my tool box from charge pipe fab of my old E30 and took her out for a spin. The car felt quicker even in comfort mode. Once warmed back up (was only standing ~2hr so it did quickly) I came to a stop at a red light on a feeder road and waiting for the green. I held it in launch control anticipating the green and unleashed the beast when it turned. The car is much much faster than before, rolling off 1st to the point DSC steps in, and squealing the tires up into 2nd as it snaps neck on he uptake. After screwing around for a few minutes I ran home to grab the laptop to get some logs for Alex MissionPerformance but on my way back out it started to rain. I drove around for a bit trying to find dry ground, finally did but by the time I was situated as to make a pull the laptop died... le'sigh. Weather looks like 50% chance of rain for the rest of the week too :-( Laptop is charging and I'll just carry it with me back and forth to work incase I get a window. TLDR? Upsized inlet pipe brought forth many more boosts. Taiwan worm clamps not ready, such snap, much boost leak. |
Bmw doubles983.50 |
08-07-2017, 11:19 PM | #194 |
Rep 332
This is very encouraging! (Fingers crossed for you!)
08-08-2017, 07:27 PM | #195 |
Rep 1,214
Well... Joy was short lived. I managed to make a clean pull on the way home. While the car certainly feels better and is faster than it ever has been it is far from where it should be. Boost target and actual are still miles apart.
http://www.datazap.me/u/jsarette/40m...?log=0&data=14 3rd gear averages about 14psi to 6100, then drops to 9psi by redline. Upshift to 4th. 4th starts at 15psi and quickly drops to 8.5psi Upshift to 5th 5th manages to spike into 17.5psi, and quickly drops to 11psi. |
08-08-2017, 08:14 PM | #196 |
Dream crusher
984
Rep 2,421
You can see that delta in the request vs actual. wgdc is a value of 0. Is that representing a closed wastegate across the RPM band?
IG: @bmwdoubles |
08-08-2017, 08:17 PM | #197 |
Rep 1,214
WGDC is fluctuating between 60 and 97% if you follow its curve, you must be looking at the wrong data tab. Its all over the place.
Alex has already reviewed the log and didn't have any hopeful input, better yes, but still not good. |
08-09-2017, 03:25 AM | #198 |
Rep 77
Pure turbos
Man
This story is the only thing stopping me going pure turbos in my 535i. I'm not sure that anyone else does upgraded turbos for these things? |
