2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications What spark plug/gap do I need to run for stage 2?
      03-27-2024, 11:26 AM   #1
f10_gavin
Drives: 2014 550i xDrive
Going stage 2 with bm3 soon and was wondering what plugs/gap i’ll need?
      04-10-2024, 02:23 PM   #2
95blkmax
Drives: '11 535 M-Sport
Nothing special about stage 2. Stock plug gap of 0.030" is just fine. As long as you have good clean sparkers and healthy coils (Eldor brand preferred but new Delphis would work just fine) you will be good.
EDIT- sorry, just realized you have a 550 (N63). I meant the above for the N55s. I hope someone with N63 knowledge can chime in and make a recommendation!!
11' M-sport- 371WHP - 478WTQ on stock PWG E50 TunedbyShoup // 386WHP - 429WTQ on Shuenk N55+ with ultra-conservative 91 Octane tune // Starting full-range flexfuel tuning in Spring '24
      04-11-2024, 12:49 AM   #3
Unspec
Unspec's Avatar
1303
Drives: 2015 BMW 535xi
Stock gap is usually fine. Do some logging, and if you notice misfires at high boost, it's too wide of a gap.
2015 BMW 535xi
ISTA VM Setup/Tutorial
      04-11-2024, 07:03 PM   #4
ctcarbonari
ctcarbonari's Avatar
Drives: 2015 BMW 535i M Sport
2015 BMW 535i  [0.00]
N55 Owner Here.
My ZR5TPP33S Plugs (yes, they had the 'S' designation) were gapped at 0.028"
Original plugs removed were gapped the same. It's my understanding that the Bosch plugs ZR5TPP33 (without the 'S') are gapped at 0.030".
Why Eldor brand on coils? Most of the time I see everyone recommending Delphi. I ask only because I replaced mine with Eldors during last plug change. They just seemed to have a better quality and "feel" to me, but I have no other empirical data or info to base my opinion on.
Apologies to the OP - not my intention to hijack the thread but the Eldor reference caught my eye and I did want to call out the factory gap difference on the Bosh "-s" vs "non -s" sparkplugs. (The '-s" plugs have a slightly higher resistance rating, btw)
      04-11-2024, 10:02 PM   #5
95blkmax
Originally Posted by ctcarbonari View Post
N55 Owner Here.
Thank you for sharing those details on the spark plug part numbers and their gap accordingly! That explains why I always saw conflicting information as to stock gap being .028" or .030". That clarifies it. As for the coils, this is the comparison video that was going around a while back about them
There was also actual testing of voltage output, resistance, and spark duration, that confirmed this on some obscure forum that I learned I am not allowed to share on here due to some beef between bimmerpost and this unmentioned other forum. But in summary... among the Nxx engine ignition coil= New Delphi is great, Eldor is better.
