2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum 760Li/Alpina Brake upgrade rattling pads
      12-14-2021, 01:15 PM   #1
socalengineer
Drives: 640i F13 Alpine White
Hi All,
I upgraded to the 760Li/Alpina calipers with 374mm rotors and I like the better braking, however the pads are clicking on one side. The other side doesn't click.
I attribute it to maybe installer error? Should I go back to the shop?
Or is this a known issue? Thanks
I used Textar/Genuine BMW pads
      12-14-2021, 04:34 PM   #2
Hoa
You might have to clean some brake dust. Mines made a slight clunk sound when you initially tap on the brake at low speed. I disassembled everything and cleaned all dust and noise went away
      12-14-2021, 06:22 PM   #3
spielnicht
Petrolhead
spielnicht's Avatar
440
Drives: 24 X3 M40i/14 550i/08 Z4 3.0si
Are these off of the G11?
Originally Posted by socalengineer View Post
Hi All,
2024 X3 M40i
2014 550i
2008 Z4 3.0si 6MT
2011 Z4 35si (sold)
      12-14-2021, 11:58 PM   #4
addy27
Drives: F10 550i
I had an issue with this setup but it was my own fault. I had a shop powder coat the calipers but they coated the area where the seal actually sits. So the surface was too smooth and the dust seal was coming off, allowing little particle to go in and make weird sounds when Piston would move in/out. Once I cleaned the area and roughened up the area around the seal, they worked just fine without any noise. Could be your issue too if you had them coated before putting them on.
Here is a link to noise I was hearing, hoping its the same issue so easily fixable:
      12-15-2021, 12:34 AM   #5
socalengineer
Nope mine was a rattling noise from the pads being loose in the caliper. I didn't paint my calipers...
Hopefully it's just an install error. I won't let the shop do it this time, and DIY. If you want something done right, I guess you have to do it yourself
      12-15-2021, 12:35 AM   #6
socalengineer
Off of the F01
      12-15-2021, 12:37 AM   #7
addy27
Drives: F10 550i
Pads being lose in the caliper is surprising as the big outside clip is supposed to ensure pads are sitting tight. Surprised how that would be missed but glad it's resolved
      12-21-2021, 08:03 PM   #8
socalengineer
Just checked... the shop didn't install this. I had it on the stock calipers, but I didn't buy the new one for the Alpina calipers so I guess the shop just installed it without them.
I looked on realoem, and apparently the guide screws are different too. So I just bought the whole set and will install myself. Surprised they didn't notice the clip was missing.
