2010 2011 BMW 5 Series Forum F10 Do you drive away immediately after cold engine start? |
08-27-2011, 03:41 AM | #1 |
Rep 68
Do you drive away immediately after a cold engine start?
especially for 535 and 550 turbo engines, is there a need for some time for the engine to warm up? and also, after maybe a long highway drive, do you let the engine to cool down by sitting idle in the parking lot? I heard that turbo engines need more time to warm and cool down, and allocating time to do that helps with the engine health. |
08-27-2011, 04:49 AM | #2 |
Rep 3,016
As per BMW recommendations, you should begin driving immediately starting. However, you should moderate the engine loading and keep the RPM within the lower range until the oil is at its normal operating temperature.
I also allow the engine to idle for 30-60 seconds after a hard thrash before switching off to allow the turbo temperature to stabilise, but if I've just been highway cruising, I tend to progressively slow down for the last mile or two and then shut down normally. What is really important is to follow the break-in procedure, otherwise you can end up with an oil burning engine. My 535d has 11k miles on the clock and the oil level is still exactly where it was on delivery - on the top notch on the dipstick. |
08-27-2011, 05:03 AM | #3 |
Rep 2,064
I'm with Jon D on this one.
I have noticed quite a big difference however when I compare my M3 to the 535d. The diesel's oil seems to be at operating temperature within a few miles but the (petrol) M3 takes at least 10 miles or 10 minutes to warm up properly. I keep an eye on the oil temp gauge all the time. In both cars I do not select sport mode (F10) or M-mode (M3) until the oil has warmed up.
2004 e87 118d (ret.), 2007 e92 330d (ret.), 2007 e87 130i M-sport (ret.), 2009 e92 M3 (ret.), 2010 f10 535d M-sport (ret.), 2015 f10 M5 CP (ret.), 2017 f82 M4 CP (ret.)
2022 g26 i4 M50 & 2009 e70 X5 35d Last edited by EdM5; 08-27-2011 at 05:11 AM.. |
08-27-2011, 05:50 AM | #4 |
Rep 966
I wait for the idle rpms to drop before driving away (maybe 20 seconds) then I don't go above 3000rpm until I reach the first tick on the oil temp gauge.
I tend not to be on boost within 2 or 3 miles of my house so I just turn her off when I pull into the garage. Also I believe our cars utilize an electric water pump and fan after the engine is turned off to continue to cool if necessary. |
08-27-2011, 06:05 AM | #5 |
Rep 61
True - however as the bearings in the turbo will be stationary once the engine is switched off, there is the risk, if the engine / turbo are still very hot, that the now stationary oil surrounding the hot bearings may cook and carbonise. So in the event that the engine and turbo have been running recently at high revs, or under heavy load, then it is still worth letting the oil circulate and cool for a minute or two with the engine running before switching off.
08-27-2011, 06:55 AM | #6 |
S0THPAW
8715
Rep 7,846
The first 15kms/10 miles or so I keep the revs around 2000/2500 max rpm until the oiltempgauge reaches about 85/90 degrees Celsius.
And after driven it hard, I let the engine/turbo cool down for about 1 minute. |
08-27-2011, 07:18 AM | #7 |
Rep 58
08-27-2011, 07:49 AM | #8 |
S0THPAW
8715
Rep 7,846
I guess so. I've had a few turbo-cars, like a Subaru GTT, Audi S3, some turbodiesels and a N54 335i. I always cooled the turbos like that after driving them hard. Never had any problems with those engines.
08-27-2011, 08:57 AM | #9 | |
Eight Bimmers and counting
35
Rep 761
(For those who might not know, the redline on the M3 starts out at about 6500 RPMs if the car is very cold and adjusts gradually to its 8400 RPM normal level.) I did the same with my E39 M5 based on the adjustable redline. With the turbos, I wish that bit of technology would trickle down to the non-M cars. My first turbo wes a 1985 Peugeot 505 Turbo (no intercooling, no cooling after the car is shut down), and my situation was like Alextremo -- the closest highway is about 6 miles away, so after any high-speed run, the time on the local roads provides for cool-down. And let's face it, for those of us in the US, any high-speed driving is going to be under 100 MPH, so we're not really stressing the engine/cooling system all that much anyway. Sigh. (I think the Euro Delivery has spoiled me.)
2014 F10 M5
Previously... Threes: '08 E90 M3, '07 E92 335i, Fives: '11 F10 550i, '02 E39 M5, '00 E39 540i/6, '97 E39 528i, '92 E34 525i Others: VW, MBz, Peugeot, Toyota, Olds |
08-27-2011, 09:02 AM | #10 |
Rep 2,064
And I used to think that Lt. Columbo was the only American ever to drive a Peugeot!
2022 g26 i4 M50 & 2009 e70 X5 35d |
08-27-2011, 01:46 PM | #11 |
Rep 3,016
Probably due to compression ratio difference; I don't know what the actual figures are, but I suspect that the diesel is significantly higher than the petrol unit, thereby generating more heat.
08-28-2011, 11:11 AM | #12 |
Rep 15,858
I'm a bit surprised by a diesel warming up faster than a petrol. Goes against the thermal efficiency of the diesel engine and less heat waste/loss. I know diesel's we use, take about 16 miles to get oil temperature up to normal range in winter time. Much slower than a petrol engine.
Certainly coolant warm up times are virtually double, with a diesel. I wonder if in the examples, the oil cooler is in open circuit on the petrol, and perhaps the work cycle is having some influence. HighlandPete |
08-28-2011, 11:20 AM | #13 | |
Rep 61
08-28-2011, 12:29 PM | #14 |
Rep 501
Drives: 2015 M4
This is an age old debate on the Porsche Turbo forums - I was advised to idle the engine on my 997 Turbo for about 2 minutes after an 'enthusiastic' drive - my rule of thumb - I don't punch it immediately (first mile or 2) after starting up and I 'go easy' for the last mile or 2...- been doing the same on past 335's and present 335 and 550.
2018 R8 V10+ - Ara Blue/Gray
2022 MS Plaid - Red/White (Daily) 2021 Alfa Stelvio - Red/Black 2013 135is - LeMans Blue/Gray 2003 M5 (56k miles) - CB/Black |
08-28-2011, 09:17 PM | #15 | |
Rep 68
I think Seattle335's routine is the one I'm gonna follow, not too time consuming or difficult and also seems to care the engine just about enough so that I am not uncomfortable |
08-29-2011, 12:53 AM | #16 | |
Rep 1,134
My first turbo was back in 88' I bought an 83' 280xz turbo and was advised by the owner not to drive off or shut down without allowing its turbos to "cool down" for 2 minutes. It always was irritating to me because I was in a rush usually but I did it, lol.
2014 550i M-sport
08-29-2011, 04:01 AM | #17 |
Rep 15,858
Just a reminder that EGT is different in petrol vs. diesel. Diesel being much lower and therefore not as critical for run down as the petrol motors.
But still sensible to give a few extra seconds, particularly on start up before driving off, to ensure oil is circulating well. Costs nothing to have good habits, both on start up and shut down. I have the luxury of living a 1/4 mile down a lane, so suits any engine when cold and hot. HighlandPete |
08-31-2011, 08:55 PM | #18 |
Rep 345
In warmer weather I drive off,slowly at first,pretty much immediately.In colser weather I let it idle for 30 seconds or so and then drive off...slowly for the first mile or so.
09-02-2011, 12:46 AM | #20 |
Rep 75
I think BMW recommends to always drive away right away, since the car will warm up faster that way. But not rev it until normal running temp has been achieved.
2011 F10 535i SE Sophisto Grey 2001 E39 525i M-Sport Titansilver(Retired) |
