2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum recommendations for battery tender/charger
      12-01-2019, 10:26 AM   #1
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
So I don't drive my car during the winters really but always had to drive the car once in awhile to keep the battery charged. Deciding to buy a charger/tender but wanted to see what you guys would recommend? Which one's to stay away from or which one's you guys are currently using with no issues or with great results? Thanks fellow members!
      12-01-2019, 10:55 AM   #2
kohsin
Drives: 2013 F10 550ix
CTEK MUS 4.3 is what I have since 2015. Working great and no issues
      12-01-2019, 12:33 PM   #3
e4603
Drives: F10
I use Battery Tender Plus
      12-01-2019, 01:36 PM   #4
Qsilver7
Qsilver7's Avatar
Drives: F06 650ix GC / F15 X5 50i
The BMW branded ( made by CTEK) tenders seem to be excellent choices. I highly recommend either (the BMW branded or the CTEK)...I have one of the BMW branded tenders that was out prior to the latest design...and it works great...and I love the "tin" case it came in...hard to get lost when storing the tender when not in use:
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral.
      12-01-2019, 02:15 PM   #5
Surly73
My digging around led to me choosing the CTEK MXS 5.0 about a year ago. Almost identical to MUS 4.3 but adds a temperature sensor as an input into the charge plan. Seems like a good idea to me. Set for 12V automotive AGM and connect whenever you need to.
My typical weekday drives aren't all that long so I connect my F10 occasionally overnight (every 1-2 days during the most brutal deep freeze, every 1-2 weeks during summer) to top everything up to 100%.
Sometimes the normal "EfficientDynamics" charge plan leads to the battery requiring fast bulk charge rate for hours. Sometimes it's still on high charge (4-5A for this unit) in the morning, but that's the exception not the rule.
Remember to connect via the under hood terminals not directly to the battery.
      12-01-2019, 03:05 PM   #6
Same here. I installed the pigtails on the connections under the hood and bought the 25' extension cable. That way I can reach both my wife's and my car without having to relocate the charger. I also like the 80% charged indicator.
      12-01-2019, 03:09 PM   #7
lsturbointeg
Do you guys just play it in and forget it or are you not allowed or suppose to leave it charging all winter long?
      12-01-2019, 05:01 PM   #8
I, to quote a famous infomercial, set it and forget it. It's supposed to have intelligent charging and, IIRC, float the charge.
Also, if you're not driving it for months, I would put it up on jackstands to relieve the pressure on the tires.
      12-01-2019, 07:06 PM   #9
Jeffcharger
Drives: E60, F10 (535i)
I have used a battery tender (the small one) for keeping boat batteries alive during the winter. I believe that it's really prolonged their life. The theory is that you can just plug them in, and leave them. It's intelligent enough to manage the charging.
      12-01-2019, 07:23 PM   #10
Qsilver7
Qsilver7's Avatar
Ditto replies above...if you buy the "advanced" or "intelligent" chargers/maintainers...you can set it & forget it. The charger is designed to keep the battery charged without OVERCHARGING it.
      12-02-2019, 09:47 AM   #11
OrcaPod
Drives: 2011 BMW F10 528i N52 engine
I have CTEK 40-206 MXS 5.0-12 Volt Battery Charger.
Works as expected
      12-02-2019, 10:17 AM   #12
NGAAutoTV
Drives: ’14 535i M Sport & 2006 Z4M
I use the same charger and it works great. I do an overnight charge every 2-3 weeks on all my cars.
F10 535i ///M Sport
E85 ///M Roadster
YouTube: NGAAutoTv
Instagram: @NGAAutoTv
      12-02-2019, 07:19 PM   #13
lsturbointeg
What does that accomplish brother?
      12-02-2019, 07:20 PM   #14
lsturbointeg
Oh, I'm wondering if I can use the charger on my lawn tractor since it's also not gonna be used until next Spring?
      12-02-2019, 10:20 PM   #15
Keeps the tires (especially your low-profile's) from permanently flat-spotting. There's also this...
https://www.popularmechanics.com/car.../a115/1272486/
      12-03-2019, 06:45 AM   #16
Jeffcharger
This is essentially what I do with my boats. It keeps the batteries in good shape when sitting idle for a few months.
      12-03-2019, 07:28 AM   #17
Surly73
Consult the manual of the charger in question. It may specify a capacity (Ah) range for which it is recommended. Too small or too large a battery may confuse the multi-step charge/conditioning algorithm if you have this kind of charger.
As long as the battery is in the range, you're good. If outside the range, YMMV.
      12-03-2019, 08:32 AM   #18
lsturbointeg
Thanks for all the help guys!
      12-04-2019, 07:50 AM   #19
EL Jeffe 5
EL Jeffe 5's Avatar
Drives: CBR1000RR
I got my charger from Walmart for $15 been using it for three years no issues
