2010 2011 BMW 5 Series Forum F10 recommendations for battery tender/charger |
12-01-2019, 10:26 AM | #1 |
Rep 14,521
So I don't drive my car during the winters really but always had to drive the car once in awhile to keep the battery charged. Deciding to buy a charger/tender but wanted to see what you guys would recommend? Which one's to stay away from or which one's you guys are currently using with no issues or with great results? Thanks fellow members!
12-01-2019, 10:55 AM | #2 |
Rep 171
CTEK MUS 4.3 is what I have since 2015. Working great and no issues
lsturbointeg9158.50 FrannieMoral20176.00 |
12-01-2019, 12:33 PM | #3 |
Rep 50
I use Battery Tender Plus
12-01-2019, 01:36 PM | #4 |
Rep 7,489
The BMW branded ( made by CTEK) tenders seem to be excellent choices. I highly recommend either (the BMW branded or the CTEK)...I have one of the BMW branded tenders that was out prior to the latest design...and it works great...and I love the "tin" case it came in...hard to get lost when storing the tender when not in use:
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
lsturbointeg9158.50 FiatLux11.50 |
12-01-2019, 02:15 PM | #5 |
Rep 1,873
My digging around led to me choosing the CTEK MXS 5.0 about a year ago. Almost identical to MUS 4.3 but adds a temperature sensor as an input into the charge plan. Seems like a good idea to me. Set for 12V automotive AGM and connect whenever you need to.
My typical weekday drives aren't all that long so I connect my F10 occasionally overnight (every 1-2 days during the most brutal deep freeze, every 1-2 weeks during summer) to top everything up to 100%. Sometimes the normal "EfficientDynamics" charge plan leads to the battery requiring fast bulk charge rate for hours. Sometimes it's still on high charge (4-5A for this unit) in the morning, but that's the exception not the rule. Remember to connect via the under hood terminals not directly to the battery. |
12-01-2019, 03:05 PM | #6 | |
Rep 5,366
lsturbointeg9158.50 |
12-01-2019, 03:09 PM | #7 |
Rep 14,521
Do you guys just play it in and forget it or are you not allowed or suppose to leave it charging all winter long?
12-01-2019, 05:01 PM | #8 | |
Rep 5,366
Also, if you're not driving it for months, I would put it up on jackstands to relieve the pressure on the tires. |
12-01-2019, 07:06 PM | #9 |
Rep 49
I have used a battery tender (the small one) for keeping boat batteries alive during the winter. I believe that it's really prolonged their life. The theory is that you can just plug them in, and leave them. It's intelligent enough to manage the charging.
12-01-2019, 07:23 PM | #10 |
Rep 7,489
Ditto replies above...if you buy the "advanced" or "intelligent" chargers/maintainers...you can set it & forget it. The charger is designed to keep the battery charged without OVERCHARGING it.
12-02-2019, 09:47 AM | #11 |
Rep 168
I have CTEK 40-206 MXS 5.0-12 Volt Battery Charger.
Works as expected |
12-02-2019, 10:17 AM | #12 | |
Rep 20
F10 535i ///M Sport
E85 ///M Roadster YouTube: NGAAutoTv Instagram: @NGAAutoTv |
12-02-2019, 07:19 PM | #13 |
Rep 14,521
What does that accomplish brother?
12-02-2019, 07:20 PM | #14 |
Rep 14,521
Oh, I'm wondering if I can use the charger on my lawn tractor since it's also not gonna be used until next Spring?
12-02-2019, 10:20 PM | #15 |
Rep 5,366
Keeps the tires (especially your low-profile's) from permanently flat-spotting. There's also this...
https://www.popularmechanics.com/car.../a115/1272486/ |
12-03-2019, 06:45 AM | #16 |
Rep 49
12-03-2019, 07:28 AM | #17 | |
Rep 1,873
As long as the battery is in the range, you're good. If outside the range, YMMV. |
12-03-2019, 08:32 AM | #18 |
Rep 14,521
Thanks for all the help guys!
12-04-2019, 07:50 AM | #19 |
Rep 1,254
I got my charger from Walmart for $15 been using it for three years no issues
lsturbointeg9158.50 Bmw doubles983.50 |
