2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Replaced all eight spark plugs
      10-01-2015, 11:46 PM   #67
Teddylongtooth
ZEROdoubleZERO
Teddylongtooth's Avatar
228
Drives: 2011 550i m sport
Well that's it, your only going to need a thin walled bmw plug socket, ratchet, extension and a flat blad screw driver. It took me 2 hours because I had to go buy a socket to grind down and the 30mins to grind it to fit in the head.
If any one has a question, just ask
      10-01-2015, 11:51 PM   #68
Teddylongtooth
ZEROdoubleZERO
228
O' and one more thing my twin brother auto buffoonery had me post this for him he's in trouble right now Lol!
      10-02-2015, 02:27 PM   #69
EL Jeffe 5
EL Jeffe 5's Avatar
Drives: CBR1000RR
Thanks a lot I didn't think spark plugs are up on top.
I always taught they are on the bottom hidden.
      10-06-2015, 01:18 AM   #70
Zer0Cool92
Drives: blue metallic
Originally Posted by Autobuffoonery
Originally Posted by Zer0Cool92 View Post
Ya I also have a very slight rough idle.. Keep us posted if changing the spark plugs makes a difference.
I'm looking to get mine swapped out as well. How hard is the install? Is it like changing spark plugs on any other car or is there some computer programming that bmw dealer has to do ?
I will definitely post back after the plug change. The SA from bmw told me the car feels fine and he didn't notice anything, my next option is to test drive a new 550 and see how it idles, I bought my car used with 51k on the clock so I don't know what It was like when new. My girlfriend has an e60 and always tells me her car doesn't idle like that and something is wrong, I tell her it's my "hard on" she's feeling when I get behind the wheel of this beast! She's a little jealous, but her car is what had me looking at bmw's in the first place.
Hey any update on your plug change ?
      10-06-2015, 01:33 AM   #71
Teddylongtooth
ZEROdoubleZERO
228
Lol! Yes read my post as teddylongtooth, we are one and the same
      10-06-2015, 01:40 AM   #72
Teddylongtooth
ZEROdoubleZERO
228
[QUOTE=Teddylongtooth;18672956]Ok guys, I did my plugs and had my car at the dealer for the fuel pump recall within the last 2 weeks. I first had the HPFP replaced under the recall, my SA said my car probably didn't need it and Im only maybe preventing a problem in the future. Well he was wrong, my car had a rough idle which bugged the crap out of me and my car had a crazy harmonic vibration under a long hard acceleration. I'm happy to report the vibration under acceleration is gone after the fuel pump replacement and it only slightly helped with the rough idle. This past Saturday my plugs showed up early and I put them in and my rough idle is gone, my car has 56k and the plugs had never been changed. So if your car falls under the HPFP recall get it to the dealer and get it done, even if your car runs good you may not know you have a problem till its replaced. I bought my car used and thought it was a worn drive shaft dampner causing the vibration and I thought it was injectors causing the rough idle, I was wrong on both. This may not be the case for everybodys car but it was only $76.66 for the plugs and the fuel pump was free and a little bit of my time for both, if your car has a rough idle this is where I would start.[/QUOTE
      10-08-2015, 10:14 AM   #73
550Reasons
550Reasons's Avatar
Drives: F10 550i
Originally Posted by Teddylongtooth View Post
This my not be the case for everybodys car but it was only $76.66 for the plugs and the fuel pump was free and a little bit of my time for both, if your car has a rough idle this is where I would start.
Where did you get them for 77$ ?
2011 550i
2013 M5
2014 M5 CP
2016 550i
      10-08-2015, 11:54 AM   #74
Teddylongtooth
ZEROdoubleZERO
228
rock auto . Com
      10-08-2015, 01:08 PM   #75
550Reasons
550Reasons's Avatar
Drives: F10 550i
browsing Ebay ... found someone selling a pack of 8 got 60$ shipped... =D
2011 550i
2013 M5
2014 M5 CP
2016 550i
      10-08-2015, 01:09 PM   #76
badblack550xi
badblack550xi's Avatar
wow thats a sick deal , and i though amazon deal was amazing HHAHAA
2011 550i RWD 60-130 7.35
      10-10-2015, 12:46 AM   #77
UA_civ_eng
Drives: '11 550i Past:'11 E92 M3
I did my change earlier today. The previous instructions made it a breeze. Somebody said at one point you need a 15 mm socket; as several others said, though, it is a 14 mm.
Two things I'd like to add for anybody about to do this job:
First, my coils needed cleaning on the insides pretty badly, where the metal contact the the plug is made. Damp Q-tips worked very well for this. Here is a before and after pic
And second, this tool makes grabbing the plugs out of the engine a breeze. I would highly recommend getting one of these, which has a claw on the end, or a magnetic one will work too.
      10-10-2015, 06:07 AM   #78
Teddylongtooth
ZEROdoubleZERO
228
If it's a 6 sided socket its a 15mm, if it's a multipoint socket its a 14mm. I forgot to mention the thing to grab the plugs from the head. Good call
      10-10-2015, 09:31 AM   #79
UA_civ_eng
How do I get these damned photos to work?
      10-10-2015, 12:15 PM   #80
Teddylongtooth
ZEROdoubleZERO
228
Maybe they need to be resized, for some reason I can only post 1 pic at a time. I wish some would tell us the secret to posting pics.
      10-11-2015, 02:50 PM   #81
badblack550xi
Anyone got good pricing for coils ?
      10-11-2015, 03:17 PM   #82
Zer0Cool92
Just ordered 8 Bosch ignition coils for $230 from rock auto .. $28.95 a pop. Saw them on other sites going for $40 each.
      10-12-2015, 02:40 PM   #83
peter91118
peter91118's Avatar
29
Drives: '01 325xit, '09 335i
The BavAuto performance coils are more expensive at $45 a piece but come with a 2 year warranty. If you drive more than 20k a year it might be worth it.
      10-12-2015, 03:09 PM   #84
Teddylongtooth
ZEROdoubleZERO
228
My slight rough idle is back and the harmonic vibration during long hard excelebration is also back and maybe never left. I did some research on the n63 engine and it appears that 2 cylinders on the same bank fire consecutively which some say is the cause for the slight rough idle.
This is the firing order 1-5-4-8-6-3-7-2
This is the how the cylinders are laid out (nevermind the m5 manifolds) the cylinder numbers are the same. If you follow the firing order cylinders 8 & 6 fire consecutive and then 2&1 at the end of the firing cycle which are on the same side of the engine. Most engines criss cross back and forth and don't fire 2 cylinders on the same side consecutively. This is probably what I'm feeling as a slight rough idle, the car runs good and has lots of power so I don't believe anything is wrong. This is probably how the engine is supposed to feel, I'm not saying any of your rough idle problems are the same as mine, you may have a real problem, I never had any check engine lights or what would be called a miss fire or a lack of power. If you replaced all your plugs, ignition coils, fuel pumps and you still have a slight rough idle with no check engine lights this is most likely what your experiencing.
Firing order 1-5-4-8-6-3-7-2
      10-20-2015, 12:45 AM   #85
mikekilpatrick
mikekilpatrick's Avatar
Only have 15,000 miles on mine but since I just did a Intake and Intercooler install, why not replace the plugs? www.rockauto.com has them for just over $8.00 a piece for Bosch ZR5TPP33 and shipping is like $6.00. So 70-80 bucks for 8 of them.
Dont be afraid on putting in plugs yourself. BMW cars are one of the easiest cars I have ever worked upon. Did all my own work on my 328xi and doing all my own work on my 550xi Msport.
Will do a little DIY for those who are a bit nervous. Takes less than an hour to do and 80 bucks plus and hour is a bit better that 500 at dealer.
I need to locate the torque on these plugs. Yes, you just "feel" it, but the easy access to plugs should due them justice to torque to specs.
Current coupon code Oct 2015 of 3690459B490384 takes another 5% off so shipping is almost free.
...Mike
      02-14-2016, 07:42 PM   #86
550Reasons
550Reasons's Avatar
Drives: F10 550i
Finally got around to installing the plugs after they been sitting on my desk. My car is currently at 42k miles.
I forgot to take photos of the plugs (I will tomorrow)
But they werent that bad, I cant remember but I know one side was replaced with the injectors around 17k ish miles, and the other side might have been replaced as well during the CCP at around 25k ish.
But now all are new and dont have to worry about them for a while, probably wont touch them again until 75k miles.
Very simple to do, the guide on pg. 3 helped me a bit, first side took me about 1 hour, then the second side took me like 20 minutes.
2011 550i
2013 M5
2014 M5 CP
2016 550i
      02-14-2016, 10:46 PM   #87
dadysev
dadysev's Avatar
Montenegro
169
Drives: Man
BMW is supposed to change plugs if any injectors are faulty and with the CCP i believe.
      02-15-2016, 12:00 AM   #88
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
Are you guys hand tightening or torquing to spec?
