2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications AIR leak problem?
      01-13-2024, 02:42 PM   #1
Fabri
Fabri's Avatar
Drives: 535i
AIR leak problem?
So pretty much my car dies when the map sensor is connected. Noticed that the boost pipe is deformed. The charge pipe does some type of suction and after that the car dies. I replace the valve cover cuz I thought it was the pcv valve but the problem persist but when I unplug the map sensor the car idle smoothly no problems. Idk if it has a leak somewhere but I feels like is clogged and by taking that sensor off the car needs that air off too to stable itself idk xD.
I clean both vanos but they probably needed to be replaced
can it be the turbo solenoid?
Intercooler?
Turbo itself
Help me out pleaseeee I can send some videos if you guys want
Have some codes from bimmer link
I’m new to the forum.
      01-15-2024, 02:06 PM   #2
Nixer
Nixer's Avatar
14
Drives: E92, F10 LCI and F10 Pre-LCI
Clear the codes and see what comes back. The codes are on MAF sensor, MAP sensors and boost pressure solenoid etc. Also, check your charge pipe for cracks.
08 E92 335i 6MT / Montego Blue / Dinan Stage III
2014 535i M Sport
2011 535i
      01-15-2024, 02:12 PM   #3
Fabri
Fabri's Avatar
Drives: 535i
I checked the charge pipe no cracks but the boost pipe is deformed and everytime I plug back the map sensor the charge pipe kinda gets clogged and makes a suction and the car dies, feels like something is clogged inside 🥹
