2010 2011 BMW 5 Series Forum F10 Need some advice on wheels |
05-26-2019, 03:15 PM | #1 |
Rep 12
Hi All,
Looking for some advice here... I have a 2016 528i M Sport package but want to put some nice wheels on instead of the stock 18 msport wheels that it came with. Im looking at some Niche Vosso 203 ? Wanted to understand from those who have gone to a 20 inch setup, the experience you have had: 1) Was there a significant difference in the ride quality? 2) Was performance impacted noticeably (e.g. acceleration, handling, etc)? For better or worse thanks for any advice |
05-26-2019, 04:47 PM | #2 | |
Rep 5,402
A heavier wheel will degrade ride quality. It will also negatively impact turn-in as well as during transitions. You may also lose significant sidewall impacting (no pun intended) the ride. That said, I've put many an aftermarket wheel on my cars and, IMHO, sticking with the manufacturers wheel, no matter the size, is the way to go. Suspensions are designed with the wheel/tire weight combo taken into consideration. |
05-26-2019, 06:52 PM | #3 |
Rep 14,521
if anything from pure aesthetics the 20" wheel will look nicer. Performance shoud be better since you won't have so much sidewall roll
05-26-2019, 07:26 PM | #4 |
Rep 697
Drives: 2013 535xi
I do believe that 528i (as well as 520d, etc, in Europe) also came with 18" M-Sport, listed as 350M style. Similar wheel design to the 351M wheel style that is for 535 & 550 F10s that are 19", but with seven double spokes. Check out this link for F10 OEM wheels.
2010 Z4 35i, Crimson Red, beige interior, 6sp manual, Adapative Suspension 2000 528i, Cosmo Black, beige interior, Sport package (retired) |
ezaircon4jc4550.00 |
05-26-2019, 10:38 PM | #6 |
Rep 342
Look at the wheel weight of what you have vs. what you want to buy... lighter is better. If you can't afford forged look at the flow formed/rotary forged wheels. Can get 19 -20" about 20lbs - 25lbs depending on diameter and width of wheels. Cast wheels are likely to be heavier. Also decide if you want a "square" setup with same size all around (allows you to rotate tires so they last longer) or a staggered setup with wider wheels/tires in the rear. Your choices will impact how your car handles and corners...
05-29-2019, 09:36 AM | #7 |
Rep 124
I happen to come across this site that shows a 528i M-sport with 20s. I was trying to look at black/gray wheels so came a cross this...thought maybe this would help you decide if 20s are too big (IMHO - 20s look perfect on an F10).
http://www.autofuturedesign.com.my/v...V-FF-105-9.jpg |
06-02-2019, 06:17 PM | #9 |
Rep 12
WahooSteeler i will let you know when i do the upgrade here soon ... and thank you all for the info ill upload some pics of my car here in sunny California
06-30-2019, 09:55 PM | #10 |
Rep 12
these came out good thanks for the help fellas
07-06-2019, 04:18 PM | #15 |
Rep 12
sweet !! looking car ... yes they are gloss black ... i like those OEM wheels .. but i deceided to do stagger offset makes it looks alittle more sporting .. your looks clean man ... the only thing i would like to do the chrome reflector to gloss back but some of these after market shops want stupid money. happy late 4th fellas
05-31-2020, 02:01 PM | #16 |
Rep 2
Help
