2010 2011 BMW 5 Series Forum F10 Why would I want to change down? |
07-31-2011, 01:36 PM | #1 |
Rep 371
Just driven the boys home from the park in my less than a week old 520d. Doing 30 mph on the flat on the speed limiter, in 5th (6mt) and the shift indicator is asking me to drop to 4th.I
I'm doing the legal speed limit, at 1,000 rpm and the engine is returning 60 mpg on the economy gauge. Why would I want to change down?
Had: E91 320d ES Titanium Silver
Now: F10 520d SE Alpine White, Cinnamon Brown leather, Business speakers |
07-31-2011, 03:02 PM | #2 |
Rep 15,858
BMW have decided 1,000 rpm is too low for the 2.0d engine, driving at a constant speed.
I'd suggest at that rpm you could load the crank/con rod bearing oil film quite hard, without knowing it. Seeing as there appears to be crankshaft issues with the 2.0d engine, I'm not surprised the indicator is showing the need for a down change. BTW, BMW autos down change at something like 1,100 rpm on the lightest throttle/loadings. HighlandPete |
07-31-2011, 03:21 PM | #3 |
Rep 371
With the Limiter on the engine was basically trundling along on tickover with momentum pulling me along. If there was any load issue with tickover it didn't feel like it!
And I do short spells at tickover - my street is 15mph 3rd gear foot covering the brake. I don't want someone running my kids down and I don't want to kill theirs either....!
08-01-2011, 07:43 AM | #4 |
Occasionally frequent poster
3000
Rep 2,744
A slow speed in a high gear like you describe puts a load on the engine and is not good for it. With a petrol engine you'd be hearing noises. A diesel makes so much noise already that you probably can't tell. I'd suggest that you will damage the engine if you keep doing this.
I think it's a good idea that you drive slowly and avoid running over kids, just do it in first or second gear...
Current inventory:
F22 & G05 Cadillac CT5-V Blackwing w/3 pedals Past: E24,E28(3),E34,E36,E37,E38(2),E39(4),E46,E89,E92 (obviously),F01,F06,F10,F30,F87,G12,G30(2),G82(2) |
08-01-2011, 09:45 AM | #5 |
Rep 322
With mine, I have noticed that as a guide, it runs well when I run my car at (minimum) 10 times the gear selector position, so 20mph = 2nd gear, 30mph = 3rd gear and 40mph = 4th gear and so on. It normally leaves it around the 1500 -2000 rpm range.
As above posters have noted, you will do damage to your engine by driving it at too high a gear for the speed. Apart from other engine interactions, the pistons are being worked so hard that they are no longer running true to the bore, but at an angle to the axis of the bore. Just my 2 pence... |
