2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum white smoke from tailpipe
      04-17-2017, 07:07 AM   #1
trevor56
Drives: BMW 2011 550ix
So I was car shopping the other day & was planning on using my 2011 BMW 550ix as a trade-in. The estimator came in with a lowball price & said there was white smoke coming from both tail exhaust's. I said I have never seen any before so we went outside & he started the car while I stood behind it & after about 2 minutes of letting the car idle white puffs of smoke started coming from both exhaust pipes. He said that is a very expensive fix. The car runs perfect. Can anyone help me understand this? thanks
      04-17-2017, 08:06 AM   #2
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
white smoke is coolant/water...blue smoke is fuel usually...and gray or black smoke is oil. could be just condensation in your exhaust pipes tho?
      04-17-2017, 08:57 AM   #3
trevor56
Thanks for your reply Isturbointeg
So the coolant guess would make sense. About 2 weeks ago I got a message on the display to add to my coolant so I added 3/4 of a quart of anti-freeze. I then drove from Florida to Ontario, Canada & checked the anti-freeze level & it had dropped a little so I again topped it off.
      04-17-2017, 09:06 AM   #4
lsturbointeg
really?! if you're needing to add coolant than there's probably an issue. i know i've seen threads here regarding coolant issues but never read them. ususally if you're loosing coolant check all your coolant lines if there's a leak? if not and hopefully it isn't but usually a bad head gasket causing coolant to seap into the block causing the white smoke? check the coolant reservoir and see if it looks milky
      04-17-2017, 09:22 AM   #5
trevor56
I'm no mechanic so I wouldn't know a coolant line from a gas line lol. When adding the coolant I did not notice a milky look to the fluid. Is fixing a bad head gasket a big expensive job? On another forum I was asked if I had gotten the Customer Care Package done yet & I have not. Would that package help deal with this issue? thanks
      04-17-2017, 10:11 AM   #6
lsturbointeg
not sure what the customer care package is? i would look into it and see if that covers it. are you not covered under warranty anymore? if you're getting that white milky in your coolant that's oil. do you feel a loss of power when you step on the gas? sounds like you have a possible blown head gasket as you now have coolant mixing with the oil in the pistons.
      04-17-2017, 10:21 AM   #7
SLVSRFR
SLVSRFR's Avatar
Guam
245
Drives: BMW 550i
Just to clarify
White smoke = water/coolant
Black smoke = FUEL
Blue smoke = Oil
On another note, it's probably your turbo seals going out
      04-17-2017, 11:12 AM   #8
lsturbointeg
Originally Posted by SLVSRFR View Post
Just to clarify
Black smoke = FUEL
Blue smoke = Oil
i was thinking about the seals too on the turbo! i think you're right on the black and blue smoke now that i think about it. i know when i was running rich i thought blue smoke was the fuel? nevertheless he's got white smoke so we know it's water/coolant
      04-17-2017, 12:04 PM   #9
SLVSRFR
SLVSRFR's Avatar
Guam
245
Drives: BMW 550i
Yup, but it seems odd that it starts only on idle. That symptom right there would point to valve stem seals. OP, are you sure the smoke doesn't have a light blue tint to it?
      04-17-2017, 12:44 PM   #10
Teddylongtooth
ZEROdoubleZERO
Teddylongtooth's Avatar
228
Drives: 2011 550i m sport
Was this at a bmw dealership? If so they know what the problem is and you should have asked them why its smoking. If you really want to get rid of this car take it to a different dealer a few hours before closing and tell them your really wanting to get something new that night, they will bend over backwards to make a last sale and most likely miss the smoke and by the time they find out it will be too late. You might want use your own financing and not thiers so they cant back out of the deal if they spot the smoke. Trust me they wont have a problem selling a car like that and you shouldn't feel bad, dealers rip people off every day. Dump that piece on them like they did on you. This is exactly what im doing with mine when my warranty expires.
      04-17-2017, 07:47 PM   #11
5fix
Drives: 2020 X5 40i; 2018 m550i
It's probably your valve seals which means you are burning oil. Do you smell a burnt oil smell after idle? Have you had to add oil in between oil changes?
You can search other threads and see that white/gray smoke when revving engine after idling means valve seals failing.
Repair approx. $5k.
      04-17-2017, 08:30 PM   #12
SLVSRFR
SLVSRFR's Avatar
Guam
245
Drives: BMW 550i
if it does turn out to be valve seals, find a good Indy that has the AGA valve kit.
Shops here in SoCal charge 2,500 for the job since it can be done without removing the engine with the toolkit.
      04-18-2017, 08:40 AM   #13
trevor56
Thanks for all your input.
      04-19-2017, 07:28 AM   #14
trevor56
Been very busy at work lately & haven't had time to do any follow up on this issue. I will look for a good indy & see what they say. Still love the car & want to keep it around for a good long time.
      04-19-2017, 01:31 PM   #15
STR8-6IX
Drives: RWD 528i N52
mileage?
this estimator is a moron. trying to squeeze every last penny out of you. look elsewhere.
      04-19-2017, 02:35 PM   #16
trevor56
Originally Posted by STR8-6IX View Post
mileage?
$14,000 with 85,000 kilometers, not gonna happen though, I'll just keep it & enjoy the ride, for that price even if I spend some money on it I won't mind.
      04-19-2017, 02:37 PM   #17
STR8-6IX
keep it. dont lose all your money.
      04-22-2017, 03:27 PM   #18
visualguy
Drives: M5
Makes sense to keep it as long as it doesn't totally crap out on you, but I wouldn't spend much time/money/energy trying to fix it quite frankly...
      04-25-2017, 03:25 PM   #19
DriveTrainMalfunc
Drives: 2011 Bmw 550i
Bmw offered me 18k with 71500 2011 550xi. I just did it for shits & giggles though.
