2010 2011 BMW 5 Series Forum F10 535 m-sport begging for 20 inch rims |
04-03-2015, 10:15 AM | #1 |
Rep 2,008
So the car is just three days old and the jet black in M-sport guise is just begging for a 20 inch rim upgrade. Its odd because in silver the M-sport 19's looked fine, but the dark car looks under wheeled if there is such a term. I'm already committed to swapping out the run flats for a set of Michelin pilot super sport 2's, and now I'm wondering whether to stay OEM 20's or go with a BBS or other high quality after market rim. I need to make a decision on rims before changing the tires obviously.
Any suggestions? |
04-03-2015, 10:35 AM | #2 |
Rep 1,314
I see you are in CT and the roads there arent so bad. I suggest going with 20s and leave your 19s as-is and use it on a 'rainy day'.
BBS is nice but they are heavy. may i suggest spending the cash saved from not touching the GYs to get a more light and stronger forged wheels. |
04-03-2015, 09:25 PM | #4 |
Rep 494
Forgestar F14's
Or the OEM 20" 343m's that are stock on the M5. Keep in mind that your ride quality will be diminished by going with even lower profile tires on the 20" rims. The PSS's are great summer tires, but have pretty stiff sidewalls, so your ride will be a bit stiffer with those as well. |
04-03-2015, 10:27 PM | #5 |
Rep 93
OEM M5 Wheels style 343 20x9 20x10. Ride doesn't feel any worse, in fact it is better w/o the runflats. Steering feels a lot lighter due to lighter wheels/tiers
CURRENT: 2016 M3 Competition Package | Mineral White/Full SO | Executive Package | Driver Assist+ | Lighting Package | Parking Assist | Enhanced B/T | Carbon Fiber Mirror Caps | Stainless Steel Pedals | XPEL Ultimate
PAST: '13 BMW 535i, '13 Lexus RX350, '08 Lexus IS250, '06 Lexus IS350, '03 Lexus IS300, '99 Civic Si |
04-04-2015, 03:25 AM | #6 |
Rep 736
04-04-2015, 10:02 AM | #7 |
Rep 2,194
If you wanted to stick with an OEM wheel, here is another 20" option, Style 303's. 20x8.5 front, 20x10 rears.
Bake
04-04-2015, 02:50 PM | #8 |
Rep 93
04-04-2015, 04:00 PM | #10 |
Rep 93
265/35/20 295/30/20 Michelin pilot super sports.
Yes they rub under harsh hi speed dips, probably would also rub on full load. Haven't tested that yet. Normal driving, it's fine.
04-04-2015, 09:06 PM | #11 |
Rep 2,008
I have a question for you guys. If the rim gets larger doesn't the diameter of the tire remain the same? So what causes the rubbing? Is it the width increasing? If 20's are stock on an M5 and doesn't rub on that car which is essentially the same, why would it rub on a 535, assuming you are set up with the correct offset?
04-04-2015, 09:10 PM | #12 |
Rep 2,008
If I do get a set of 20's with summer tires i will keep the 19's with the all season rubber for the winter months. Also I lease my car so I need to return it with all the original equipment. I'm sure you can find a set of take offs either here or on ebay.
04-04-2015, 11:12 PM | #13 | |
Rep 1,363
The rear 295mm stock m5 tire is huge though. I think others have run 285s and that's solved the problem Here's an idea of black on black, if you're interested. Last edited by twelve535i; 04-04-2015 at 11:19 PM.. |
04-05-2015, 08:29 AM | #14 |
Rep 14,522
04-05-2015, 09:26 AM | #15 | |
Rep 29,202
04-05-2015, 11:34 AM | #16 |
Rep 1,363
Thanks. No drop at all. Car looks lower because of front lip. I think the black on black helps you see past the wheel gap.
Wheels might be up for sale soon. I really like them but have another set for summer...... |
04-07-2015, 10:41 AM | #17 | |
Rep 49
I'm also considering just painting the stock 19's gloss black but yours look sick.... |
04-07-2015, 06:59 PM | #18 | |
Rep 1,363
Front 20 x 9 wrapped in 245/35/20/ Rear 20 x 10 with 285/30/20 I have black M sport wheels for winter......after running the Forgestars, they look tiny. Shoot me a PM if you're interested in the wheels. |
