03-26-2019, 05:07 AM | #1 |
Rep 166
Drives: 2016 535I
Things to replace
So my buddy has a 135 N55 and he needs a new starter. I will be showing him how to do it and doing most of the work. since I will have to remove the intake manifold to get to the starter what else should be looked at/Replaced. He is at 76k Miles. Im sure its the original Valve cover and Gasket. I know he has done coils already.
03-26-2019, 02:30 PM | #2 |
Rep 743
Drives: '13 F13 M6, '94 JDM Supra
Oil Filter housing gasket is a common problem, chargepipe (no reason to change if it's fine), valve cover seepage is possible, other than that routine maintenance should be it. N55 is a pretty solid motor.
03-27-2019, 06:00 AM | #3 |
Rep 166
Drives: 2016 535I
Thanks. He has decided to do Starter, Water Pump, T-Stat, Valve cover & Gasket, Oil filter housing Gasket. He wants to get all the items that could fail at this mileage or soon doesn't since I'm doing the work and he doesn't have to pay dealership prices anymore.
03-29-2019, 10:04 PM | #4 | |
Rep 915
Instgram @burninja
Kwood-F10-535i54.00 |
04-01-2019, 01:00 PM | #5 |
Rep 21
04-01-2019, 06:26 PM | #6 | |
Rep 915
If you google Broken N55 Crankshaft, it will be a post on a website. It will explain there. User posts a comment from reddit which will talk a little about it too on that same website.
Instgram @burninja
