2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding nbt usb video playback resolution where to convert?
      03-30-2014, 09:48 PM   #1
AlpineWhiteM3
Drives: 2011 m3
i like playing music videos but they never fit the screen i read that correct resolution is 1920x720 but if i convert to that resolution i get alot of black on sides anyone can help?
      04-01-2014, 04:10 AM   #2
CyberJudas
CyberJudas's Avatar
Drives: G30
I had exactly the same question in mind... Everytime i 'force' the encoder to encode with those dimensions - playback on the HU is still bordered by the black bars (if not worse).
Would love to have the zoom function available (ala DVD playback), but I can seem to find the sweet-spot for encoding.
      04-01-2014, 03:10 PM   #3
bimmertaxi
Norway
Drives: F10 525d
2014 BMW 530d  [0.00]
2010 BMW 525d  [0.00]
You also need to crop the video to 24:9 aspect ratio. The pixel aspect ratio should be 1:1
1280x480 or 1920x720 should then work.
Avidemux should be able to do the job.
      04-03-2014, 11:08 AM   #4
AlpineWhiteM3
Drives: 2011 m3
doesnt seem to work any more detailed help?
      01-03-2016, 03:55 PM   #5
ImpetuousRacer
ImpetuousRacer's Avatar
Drives: 2017 Tesla Model X P100D
2013 BMW M5  [0.00]
I have Windows 10, and I'm no Video guru.
Here is what I did (after piecing together info from various forums) and it seems to work...
Download and Install Xilisoft Video Converter Ultimate
It costs $38 but you can find it cheaper online
1. Select your Profile as > Playstation > H.264/MPEG4-AVC
2. In the upper right corner, select the arrow popout to bring up advanced settings
3. In the advanced settings:
Under Video Stream > Change the following:
Video Size > Type in 1920x720 (not available in dropdown)
Zoom > Change 'Letter Box' to 'Full' in the dropdown
Aspect Ratio > Type in 24:9 (not available in dropdown)
4. Under Profile settings you can change the Video and Audio Quality to your liking.
5. Select your destination folder then press Start
The issue you are having I believe is that letterbox format creates the border and you need to change that zoom setting to Full.
The above is what I used and it fits the full BMW screen without borders on my 2013 M5.
Good luck.
      12-14-2019, 04:40 PM   #6
teknodogg
Drives: BMW 535i F10
could you explain what exactly you have to do in the software??
or post some screen shots?please TIA
