2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Needs suggestions on suspension upgrade
      09-25-2013, 08:59 PM   #1
SonicEndeavor
Drives: 2014 535i MSport
I'd like to upgrade the suspension on my 2014 535i RWD sedan with the following in mind:
1) Sharper handling and flatter when cornering
2) Lower the ride height about 1 inch (wheel gap is currently 2 1/4" front, 1 7/8" rear), ground clearance is currently 6 3/4" front
3) Maintain the current ride quality as much as possible.
I have no plans to do any seriously aggressive driving, but want the car to be less floaty and stay a little flatter in the corners.
The BMW M Sport suspension is pretty close to what I want, but are there aftermarket solutions that might be better, such as KW V1's or Street Comfort coilovers or another recommended setup? I'll probably want to change the stabilizer bars as well to whatever will match up well the new springs/struts.
Any advice would be greatly appreciated.
Thanks
2014 LCI 535i /// M-Sport - SAT, Premium package, HK Audio, Drivers Assistance, Top/Side/Rear cameras, multi-contour seats.
Mods: V2 coilovers, Michelin PS4S, Opticoat Pro, Quad black chrome exhaust tips.
      09-26-2013, 09:22 AM   #2
lmaleke
Hong Kong
13
Drives: shifting priorities for now...
In that case, you might want to check out either eibach or ACS springs
      09-26-2013, 09:40 AM   #3
SonicEndeavor
Thanks. ACS is on the list but I also want to replace the struts to ensure the suspension components are designed to work together, as well as the stabilizer bars.
      09-29-2013, 06:16 AM   #4
lmaleke
Hong Kong
13
Lightbulb
No problem.. It seems that the ACS springs were designed to work well with stock struts/dampers..
