2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Sports Display modification for non NBT F10's
      04-25-2016, 09:32 PM   #23
Originally Posted by Simple3 View Post
It's only read in nM and kW? Also if they perfect it for the 550i will they be able to remotely install?
Nope. You can select hp/ftlb in the iDrive, IIRC...
      04-25-2016, 10:14 PM   #24
MWPos
MWPos's Avatar
Drives: 2013 535i
2013 535i  [0.00]
Here's the coding sequence for Sport Display, and how to change Ft Lbs. and HP:
- Enable Sports Display (Power* & Torque* Meters) in the Vehicle Info screen.
(For N55 only. For N63 cars the gauges appear, but do not function)
2011-12 (CIC)
HU_CIC => EFF_DYN_SPORT_CID => aktiv
HU_CIC => EFF_DYN_SPORT_UNIT => aktiv
2012-13 (NBT)
HU_NBT => EFF_DYN_SPORT_CID => aktiv
HU_NBT => EFF_DYN_SPORT_UNIT => aktiv
2014 LCI
Already in iDrive
* To change units displayed to be ft lb and hp
KOMBI => DREHMOMENT => lb_ft (displays ft lb)
KOMBI => LEISTUNG => ps (displays hp)
Regards,
MWPos
      04-25-2016, 11:22 PM   #25
PJinCA
USAF Pararescue Veteran
Drives: F10 535
Ok, any chance of getting something like this for NBT cars?
      04-26-2016, 12:20 AM   #26
Bmw doubles
Dream crusher
Bmw doubles's Avatar
Drives: Fast
2011 535  [0.00]
Yup NBT sports display is available. The challenge was for non NBT like me
IG: @bmwdoubles
      04-26-2016, 09:52 AM   #27
808_F10
Drives: F10 535i M Sport
2011-12 (CIC)
2012-13 (NBT)
2014 LCI
Already in iDrive
I didn't bother coded Kombi because I was able to select HP/Ft-Lb thru my options menu. However, maybe doing the coding will help with what seems to be an inaccurate display even though the screen shows HP. I had the thought that perhaps although the screen shows HP/Ft-Lb the computer is actually reading in KW/N-m, and maybe coding Kombi gets them in sync to HP/Ft-Lb.
      04-25-2020, 10:29 PM   #28
M-I-Kostin
Drives: X5 e53
Originally Posted by Bmw doubles View Post
Mission Performance is killing it on many levels of modding. The Burble flash, remapping torque management and now the Sport Display for non NBT F10's. It needs some final tweaking, but will be complete soon. MissionPerformance
Hello. I'm trying to run a sports display on my X5 E53, with CIC installed. Can you share information about the data package that the CIC needs to get in order for the indicators to work? I will be glad of any information.
      04-25-2020, 10:32 PM   #29
M-I-Kostin
Drives: X5 e53
Maybe you have information like this:
ID 381 ELKTR_M_OEL_MESS (2 Datenbytes)
byte 0 FLLV_EOI fluid-level_engine-oil (8 Bit, Enum (Byte 0, Bit 0...Byte 0, Bit 7))
12 State below MIN
25 MIN state
38 State between MIN and OK display: 1/4
53 OK status display: 1/2
69 Status between OK and MAX display: 3/4
85 MAX condition
95 State crowded....
