2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions Blower Motor working / not working
      10-08-2023, 10:05 PM   #1
skysurfer2000
Drives: 2013 BMW 528i
The blower motor of my 2013 BMW 528i doesn't work, sometimes it starts and it shut off.
My friend told me the check the fuse box.
I personally believe is the regulator or FSU but just in case I would like to know which one is the fuse / relay for the Blower Motor.
      10-09-2023, 07:20 AM   #2
SWFLf10
SWFLf10's Avatar
If it works soemtimes then it’s not the fuse. The fuse either is fine and allows power, or is blown and allows no power
I’m going through the same issue and will be swapping my regulator and blower motor tomorrow in hopes of correcting the issue. I live in SW FL so I run the AC pretty much all the time. My car has 176,000 miles so I figure even if it’s just the regulator, the blower motor may not be far behind. I’ve heard the brushes on the motor are a failure point as well at higher mileage.
      10-29-2023, 03:13 AM   #3
Jamesv
Drives: 2011 535i havana metallic
New blower motor solved my issues. Just around 100k and it went out slowly by doing the same thing. Then eventually stopped all together.
