2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding BMW F10 Coding DIY (and other Fxx models)
      07-12-2016, 01:06 AM   #133
shawnsheridan
shawnsheridan's Avatar
Drives: 2018 Alpina B6 650ix GC
Originally Posted by tsameti View Post
Guys, I'm trying to deactivate Idrive warning however I cant find those options in Esys
I took a screenshot of the menu, can someone point out what do I do wrong?
I follow instruction but it seems not to work for me.
You are in CAS module. iDrive Disclaimer is in your Head Unit module (e.g. HU_xxx).
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      07-12-2016, 07:25 PM   #134
tsameti
Drives: BMW F10 535i
Thank you so much, for some reason I thought everything was in CAS module.
I did edit it and it worked perfect.
I activated LDW but it doesn't even come up as active on a dashboard. I can see there's a camera on the windscreen.
      07-12-2016, 07:41 PM   #135
shawnsheridan
I did edit it and it worked perfect...
...I activated LDW but it doesn't even come up as active on a dashboard. I can see there's a camera on the windscreen.
Does car have the minimum hardware for LDW, as in KAFAS Camera?
      07-13-2016, 01:48 PM   #136
NV GUNS
NV GUNS's Avatar
Drives: 19' M2C
2023 M550  [6.75]
2019 M2 Competition  [0.00]
2002 330ci  [0.00]
dealer
I just got my car back (F10) from the dealer for service and I am trying to edit HU-NBT and I get an error (CAFD_00000DED_003_15_028 Fehler:
File for "cafd_00000ded-003_015_028" not found! [C012]) Did the dealer delete a file, I can edit KOMBI just not HU-HBT. Because it worked before I brought it to the dealer. Has anyone had this problem?
Thanks!
      07-13-2016, 01:50 PM   #137
shawnsheridan
Thanks!
You need to update. PM sent.
      07-13-2016, 07:26 PM   #138
NV GUNS
NV GUNS's Avatar
Drives: 19' M2C
2023 M550  [6.75]
2002 330ci  [0.00]
Can some one please remind they way to program for the volume being displayed on idrive when you change it?
Thanks
      07-13-2016, 07:59 PM   #139
shawnsheridan
Thanks
HU_NBT => VOLUME_POPUP_DISPLAY = aktiv
NV GUNS57.50
      07-13-2016, 08:03 PM   #140
Thanks
Only works with NBT....
HU_NBT 3000 VOLUME_POPUP_DISPLAY aktiv nicht_aktiv Show volume level on screen when adjusting
NV GUNS57.50
      07-13-2016, 08:05 PM   #141
NV GUNS
NV GUNS's Avatar
Drives: 19' M2C
2023 M550  [6.75]
2002 330ci  [0.00]
Thank you!
      07-14-2016, 08:55 AM   #142
suitepee
Drives: 2013 528i
Hey Shawn,
If still available, could you PM the details of the software?
Thank you
      07-14-2016, 08:59 AM   #143
shawnsheridan
Originally Posted by suitepee View Post
Hey Shawn,
Thank you
PM sent.
      07-14-2016, 09:55 AM   #144
Carlos528i
Drives: 2013 528i
2013 BMW 528i  [0.00]
What battery charger do you guys recommend in the under $150 range ?
      07-14-2016, 10:50 PM   #145
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
You might find MAAS SPS-II 50 for around that. Otherwise, if you would have to go the DIY route.
      07-14-2016, 11:43 PM   #146
I bought this one...
      07-15-2016, 07:16 AM   #147
shawnsheridan
For the sake of clarity, this is a Batter Tender, which is a Trickle Charger with added circuitry that monitors the battery and charges only when the voltage has dropped below a preset level, thus preventing overcharging and damage.
It is capable of only 1.25 Amps. It may be fine for Coding, for those who do not want to run their motors, but in no way is it fine for Programming (Flashing), where you really need at least 50.0 Amps.
      07-15-2016, 08:36 AM   #148
Carlos528i
Drives: 2013 528i
Yes, I am looking at flashing, most of the 30A+ i've seen are in the $350 plus range.
I might just rent one for the weekend.
      07-15-2016, 09:41 AM   #149
shawnsheridan
You can always just Jump car being programmed to the running motor of another car. All it costs is a few gallons of gas.
      07-16-2016, 11:26 AM   #150
Carlos528i
Drives: 2013 528i
...and that is how I did it. Thanks for the tip.
So this morning I flashed HU_NBT (from 13-03 to 16-07) with no issues, took about 30 mins. Th flash updated the Media and Telephone version from 1.x.x to 3..x.x
I also flashed the KOMBI, and HU that took about 5 mins but left me with a check engine light on.
Can E-SYS read the error code? I read in some thread that this could be expected, just clear and it should not return.
Thanks.
      07-16-2016, 11:30 AM   #151
shawnsheridan
Thanks.
Clear Fault Codes:
With E-Sys:
Click "External Applications" in the left menu.
Click "External Application"
Double-click "Transmitter"
Scroll to the bottom and click "14 FF FF FF,31 01 0F 06,31 01 40 00 00,31 01 40 00 05,31 01 40 00 01;Clear all DTCs (clear DTC,clear Infospeicher,ZFS – DM_Lock,clear ZFS – DM_Clear,ZFS – DM_Unlock)"
Click Connect
Click Send
      07-17-2016, 08:51 AM   #152
Carlos528i
Drives: 2013 528i
Turns out it was not needed, I started the car right after the last update and the engine light was on. Drove to the gas station and stopped the engine while refueling and it didn't come back after starting it.
Thanks again for all the guidance.
Clear Fault Codes:
With E-Sys:
Click Connect
Click Send
      07-19-2016, 07:32 AM   #153
paul223
paul223's Avatar
Drives: F10
Need latest data files please.
      07-21-2016, 10:29 AM   #154
Carlos528i
Drives: 2013 528i
Can anyone provide a link to the most recent GRACENOTE database?
Thanks
Carlos
