2010 2011 BMW 5 Series Forum F10 BMW F10 Coding DIY (and other Fxx models) |
11-01-2018, 08:52 AM | #356 |
Rep 418
11-02-2018, 12:03 AM | #357 | |
Rep 8,364
You will have no problem reading files and VO coding. But, you will not be able to edit or push changes to vehicle without token. So, reading on MAC will not be an issue nor modifying on Windows Machine. But, when you transfer back to Mac, you will not be able to push to vehicle. |
11-02-2018, 08:40 PM | #358 | |
Rep 418
11-02-2018, 09:32 PM | #359 | |
Rep 8,364
VO Coding: Can be done on Mac with VM. Eg, Enhanced Bluetooth FDL Coding: Can be done on Mac with Bootcamp, but not VM. Ex, removing startup legal disclaimers. |
11-04-2018, 12:26 AM | #360 |
Rep 418
FDL coding is what I am interested in, so it looks like it is a no go using a VM on Mac
11-04-2018, 04:32 AM | #361 |
Rep 8,364
11-05-2018, 12:03 PM | #363 |
Rep 40,789
Drives: 2018 Alpina B6 650ix GC
PM sent.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
11-11-2018, 01:08 PM | #364 |
Rep 7
bmw apps on CIC
Hi,
I've spent countless hours on forums, cant find the answer. I have a CIC system with combobox, can I get bmw apps? Do I need connected drive for it? Another question, I think I had basic traffic information on the car that worked once when tethering from a phone. After trying to code RTTI, I can't get any traffic reports. How Do I go back to basic? Unless it's possible to get RTTI? Hope someone can help. |
11-11-2018, 02:39 PM | #365 | |
Rep 40,789
You cannot have RTTI, which is cellular based. You would need NBT head unit and a Subscription service for RTTI. For TMC (Traffic Message Channel), which is FM Radio based, you need to VO Code HU_CIC and CMB_MEDIA for 6UH.
12-02-2018, 10:08 AM | #366 | ||
Rep 15
Thanks the this great tips.
But it can work with BT Shared network (from a mobile) right? Quote:
EDIT: Forget it... found this later Last edited by aplinhares; 12-02-2018 at 10:28 AM.. |
12-02-2018, 12:01 PM | #367 | |
Rep 40,789
WIFI HOTSPOT in NBT was killed off by BMW AG many years ago.
12-14-2018, 11:22 AM | #368 |
Rep 107
I have newest 003.013.001 software and i cant code my car anymore.I tried with several laptops and program and every time i get some error codes.Btw last time i try to connect my car with laptop,does not reveal any connection?I tries with esys 3.27 an 3.30 in my bmw workshop.What i need to do?
12-14-2018, 12:12 PM | #369 |
Rep 9
I'm not sure I'm in the correct field/value for what I want.
My car has Xenon and the rings (don't know the name for those besides angel eyes) are not at full brightness as I've seen in other cars. To make them full brightness when headlights are off, am I in the correct field? FRM => 3050 => HELLIGKEIT_DRL => wert_01__100% When headlights are on what will the brightness, 100% as well or it can be coded? If so, can I get a tip? |
12-14-2018, 01:34 PM | #370 | |
Rep 40,789
12-15-2018, 05:05 AM | #372 | |
Rep 8,364
01-04-2019, 06:26 AM | #373 |
Rep 166
Drives: 2016 535I
shawnsheridan I'm not sure where or if this has been discussed and I have not been able to find a real writeup on the subject. Do you or anyone else here have a good writeup on doing a full I-Step upgrade? I have a 2013 535i with NBT HU. last 7 of the VIN is c828892 if that helps any.
01-04-2019, 07:26 AM | #374 | |
Rep 40,789
E-Sys - Flashing ECU Guide v.1.0.1.pdf: https://mega.nz/#!VwIzGJJY!oHCQrh-ax...syn-9eEytBH1qo
