2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications BMW Carly Coding software ROCKS
      03-11-2017, 02:08 PM   #23
MavRick
MavRick's Avatar
688
Drives: My Wife's M
registered the new battery like a BAWSE. easy peasy. thanx to everyone for the help. i've tried to set up some parameters to monitor but they arent going as well for me. im assuming absolute manifold pressure is our 'boost gauge' but it only works sporadically. and, even at that, you have to convert hPa to psi.
      03-11-2017, 10:15 PM   #24
NV GUNS
NV GUNS's Avatar
Drives: 19' M2C
2023 M550  [6.75]
2019 M2 Competition  [0.00]
2002 330ci  [0.00]
Originally Posted by AmooManiak
Had the same exact experience as XXXEsq. Mine was actually related to the seatbelt and airbag malfunction. They also told me "this never happens."
Good thing we have a friendly forum member who was able to fix it via real coding. There's definitely a risk involved and I would be hesitant to use it if you don't have a backup option of reversing it via something other than the app itself.
Yeah that was pretty bad. air bags most likely
would not have gone off if you got in a crash. I think we can fix the TPMS the same way we fixed the original problem.
      03-14-2017, 05:42 AM   #25
5eries619
Drives: 528i x drive
Does anyone know or anyone using a non Carly OBD 2 wireless ? Does it work or is this software going to bug out unless you are using their adapter?
      03-15-2017, 03:45 PM   #26
MavRick
MavRick's Avatar
688
Drives: My Wife's M
the non-Carly adapter didnt work for me. wouldnt let me do a thing. recognized it but no functions...
      03-27-2017, 12:35 AM   #27
TTG
TTG's Avatar
Drives: M340
So, I did some coding today on a F10 and F31 using Carly WiFi 2nd Gen for IOS.
What worked for F10:
-Comfort Close Windows via / Fob
-Comfort Close Trunk via / Fob
-Digital Speed on cluster
-Cancel window roll up/down if door is opened
-Cancelled drivers side seatbelt warning
What did NOT work on F10 are:
-Door LEDs on when in reverse
-M Logo on cluster (when this option is selected mine shows M550d?????)
-I could not get rid of any of the legal disclaimers since their latest drive module is not updated yet
What worked on F31
-Comfort close windows via Fob
-Cancel seatbelt warning on drivers side
-Turn signals set to 5 flashes (F10 did not offer this option)
-Door Leds on when reverse is engaged
What did NOT work on F31
-No option to close the power trunk via fob
There are several other things that I wanted to code which is not an option at the moment
-Reduce the speed to 10mph to activate blind spot monitoring
-Allow fog lights to come on without headlights (F31)
-Activate rear fog lights (F31)
-Allow fogs to stay on with brights
-DRLs 100% when headlights are on
I guess I am going to have to have one of the local coders to do the rest.
Overall, Carly is an ok product that allows you to do some basic stuff.
2020 G20 M340 xDrive - Portimao Blue - ZDA|ZPP|ZPX|1CR|1PE|6NW|6WD
2016 F10 535i xDrive - AW - Retired
2011 E92 M3 - AW……………....ED April 29th, 2010 - Retired
2007 E92 335i -Space Gray.....ED Oct 19th, 2006 - Retired
      03-27-2017, 04:17 AM   #28
AWF87M2
AWF87M2's Avatar
827
FYI, the non Carly adapters used to work for all the functions but after the recent updates it will work for all the functions except coding. If you were to click on the coding section this menu would appear. Battery registration, parameters, diagnostics, service reset and etc still works.
      03-27-2017, 11:18 AM   #29
Bmw doubles
Dream crusher
Bmw doubles's Avatar
Drives: Fast
2011 535  [0.00]
ELM327 wifi has worked for me. Costs about 10 bucks. It won't allow for coding on F series but you can use it to clear codes and errors. On my e90 it worked for coding everything. If you get it password is usually 0123456789
IG: @bmwdoubles
      03-27-2017, 01:33 PM   #30
5eries619
I bough into this app in hopes of getting DVD in motion working so I can keep my kids entertained but after emailing Carly they have pulled it off the list temporarily bec they have received reports of issues. They said it should be back in the next few weeks.
There are also a few pieces options in the coding that doesn't seem to work properly. By any means the program isn't perfect but we are all humans.
Would definitely still recommend it. Great app for the price. I think there wifi adapter is on the pricey end for sure.
      05-13-2017, 06:19 AM   #31
bogdan20
Romania
Drives: 2012 F30 320D
Hi, for those who want to buy Carly adapter can use voucher code QYRAHB.
This code can be entered on www.ivini-tech.de/en directly in the shopping cart and 5€ will be deducted from the shopping cart value right away.
Users that wish to order through Amazon Japan, UK, US or Canada to contact Carly regarding voucher code before the adapter purchase via trainer@mycarly.com. This mail should clearly state whether they want a substitute code for Amazon Japan, UK, US or Canada.
      02-12-2018, 09:32 PM   #32
xjonnyviciousx
Drives: 2011 BMW 550i
Coding with ICarly - fault code
I got the fault code ECU: VIN Wrong - 800A23. It has to do with the ECU KAFAS. This issue caused the lane departure feature to malfunction. Could someone please help me fix this problem.
Thanks
      03-18-2018, 07:49 PM   #33
wrecked2001
Drives: 2013 535i Msport/Imperial Blue
Carly has updated the software recently. I did have to reconfigure my phone to get ot to connect, but once connected I was able to retract the rear brake calipers, this is a new addition. It works as advertised.
      03-18-2018, 08:52 PM   #34
Proimport
Drives: 2014 BMW 535i
My buddy coded my 2014 535i with his Carly pretty simple he did it straight from his Carly app on his phone about 30mins in total.
      07-17-2018, 07:10 AM   #35
davejack
davejack's Avatar
Drives: F22
thank you for the experience of bmw carly,and i also want to share below collection about bmw carly collection:
https://www.car-auto-repair.com/tag/carly-bmw/
      08-11-2018, 11:48 AM   #36
wotan77
Drives: F11
Carly app not working
Hi all,
I just bought the carly app (full, new version) + adapter (the small one, second generation) and connected to car (F11, 2013, 2.0 d, NBT)
It shows me 10 ECU to be able to change but once trying to code it says 'it cannot be coded. Nothing has been changed' It says also, try during running of engine (which is crazy because it is plugged and cannot recognize that the engine IS running) and to try with slow speed coding (I did, same issue)
Any recommendation?
Update: Issue solved. Try not use Carly with Samsung A6. Coding won't work.
      08-11-2018, 04:45 PM   #37
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
Recommendations would be turn off your motor when flashing. I killed my LPFP accidentally. Grant it was weak already, and got a free one under recall, but still a PITA
IG: @bmwdoubles
      08-16-2018, 07:23 AM   #38
wotan77
Drives: F11
It's back now!
      08-22-2018, 07:41 AM   #39
Jamrockbwoy
Drives: 2015 550i xDrive
not worth it unless you're just not confident following instructions and navigating computer software. I bought app and tried using a bluetooth adapter I had but later discovered I had to use there adapter to do any actual coding or perform most of the app functions.
I just installed windows bootcamp and my Macbook Pro and followed the instructions to install E-sys and the cheatcodes. I coding majority of the things i needed in less than 30mins.
Instagram @_gr8dane
2015 550xi - current
2015 428xi - retired
2010 328xi LCI retired
