2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Acceleration Cut out at 2900RPM
      02-08-2019, 02:00 PM   #1
DanielBJJ420
GorillaBjj420
Romania
Drives: BMW 535iX
Hello everybody
I`m having another problem with my N55 f10 535ix, on the highway when i do and medium acceleraation not full power , in some gears at 2800 -2900 Rpm it cuts the acceleration for 1 second then it accelerates normal.
It happens everytime at 2800 -2900 Rpm and the most in the 5 gear like a limp mode with no error.
I had an error on the blow off valve and i replaced but the car do the same with no error.
      02-08-2019, 04:57 PM   #2
ziekxq
Drives: 2011 535i xDrive
What mods do you have on the car? Mileage and when did younlast change spark plugs if high mileage?
      02-09-2019, 08:36 AM   #3
DanielBJJ420
GorillaBjj420
Romania
Drives: BMW 535iX
The car has Stage 1 software to 370hp and 83.000 miles . I buyed the car at 72.000 km and i didnt changed the spark plugs and i think the prevorious owner also didnt . This could be the problem?
      02-09-2019, 01:54 PM   #4
ziekxq
Recommended change is 50k miles. I was having bunch of problems until I replaced sparkplugs. Could be a boost leak as well.
      02-09-2019, 05:42 PM   #5
ziekxq
I forgot to mention... and now that I think of it, this issue could be related to throttle body/chargepipe.
My G35 did this and both throttlebodies were the issue.
      02-12-2019, 03:39 PM   #6
DanielBJJ420
GorillaBjj420
Romania
Drives: BMW 535iX
not solved
i have changed the sparks and the throttle body today and its the same ,it stop the acceleration for 1-2 seconds at 2800-3000RPM in 4 or 5 gear ...please if can somebody help me because i have no error and i checked all the things.
Could this be from the gearbox?
      02-12-2019, 04:35 PM   #7
ziekxq
Thats why I said to just do sparkplug only first :P. Check your intake filter make sure it is not dirty. It is like 5 screws I believe, so you can check your self. The intake filter should have been changed at 50k with oil change.
Tags
acceleration, cutout, n55, turbo
