04-05-2014, 07:37 AM | #1 |
Rep 137
Sport+ mode missing
Does anyone know what happened with the Sport+ mode from 2014 onwards? At present i have Eco-Pro, Normal and Sport modes but in my previous car i had Normal, Sport and Sport+.
Does this mean i just turn off traction control to get Sport+? |
04-05-2014, 08:25 AM | #2 |
Rep 618
Someone mentioned this a few months back. Do you have the Sports Auto? Do you have 4 or 6 cylinder? My LCI with the 30d engine, and sports auto has sport+
04-05-2014, 03:18 PM | #4 | |
Rep 15,858
I guess you'll be missing the subtleties of the Sport+ mode compared to when we have other options and configuration choices. For example, when I check the chassis only and move from Sport to Sport+ mode, besides enabling DTC, the sport auto gearbox program is activated (as it would be if configured for Sport mode, "the half-way" function) even though not used by the Sport mode due to my choice of configuration. Do you have the configuration options for chassis and/or drivetrain, or is that menu missing from iDrive as well? If so, then I suppose you get the sport auto program as you toggle to Sport mode. I sense you then have to flick the stick to M/S (as well as the brief press of the DTC/DSC button) to mimic Sport+. Both for the full sport gearbox program and to get DTC activated. An F30 320d ED auto I hired worked that way in Sport mode, that didn't have Sport+. HighlandPete |
04-06-2014, 11:41 AM | #5 |
Rep 137
4 cylinder M Sport 2.0d, i have the shift paddles etc so i guess its a Sports Auto?
I don't have any drivetrain options etc.... So does this mean i don't have this facility? |
04-06-2014, 12:57 PM | #6 | |
Rep 29,202
04-06-2014, 02:03 PM | #8 | |
Rep 15,858
Therefore the limited modes and no Sport+. HighlandPete |
04-06-2014, 04:28 PM | #9 |
Rep 9
The LCI 520D SE Auto I have has the Drive Dynamic Control settings for Eco Pro, Comfort and Sport; these serve only to make the loud pedal more sensitive and in Sport mode I haven't been able to convince the gearbox of the 8th speed.
The gear area is identical to the image labelled 2TB above.
520D LCI SE Auto - Cashmere Silver 63 plate 2nd Sept
~~1956/80 Land Rover Series 1&3; 1963 Lotus Seven; 1988 Yugo 45A Convertible; 1992 VW Scirocco Scala; 1996 Mercedes E320 Sportline Cabriolet; 2011 Range Rover Vogue TDV8 ~~ |
04-06-2014, 04:38 PM | #10 |
Rep 15,858
04-07-2014, 02:02 AM | #11 |
Rep 619
I guess you refer to the LCI F10? I have a 2012 F10 520D that does have Sports Auto with Paddles and I have Sport+
Sunset Orange G20 330e xDrive M Sport Pro - Tech/Pro Pack, Park Assist Plus
Bluestone G30 M Sport - Gone to Stud Alpine White F10 M Sport - Gone to Stud |
04-07-2014, 02:40 AM | #12 |
Rep 15,858
04-07-2014, 03:52 AM | #13 | |
Rep 619
The LCI 520d has the gear lever on left, whereas the pre LCI 520d with sports auto had the gearlever on the right LCI 520d should have the gearlever on the left with optional paddles and the buttons below ( which I did'nt know when I ordered mine either!) PS - As a result, no sport+
2017 F10 535d MSport Auto - Mineral Grey - Oyster leather - 19" 351M's - Pro Media - Enhanced bluetooth - MSport rear spoiler - Sun protection glass - Harman Kardon Hifi - Multi Function Display - Ambient Lighting - Folding mirrors - Sunroof - LED adaptive headlights
04-07-2014, 01:05 PM | #14 | |
Rep 9
~~1956/80 Land Rover Series 1&3; 1963 Lotus Seven; 1988 Yugo 45A Convertible; 1992 VW Scirocco Scala; 1996 Mercedes E320 Sportline Cabriolet; 2011 Range Rover Vogue TDV8 ~~ Last edited by YYB129; 04-07-2014 at 01:10 PM.. |
04-07-2014, 02:05 PM | #15 | |
Rep 619
04-07-2014, 02:15 PM | #16 |
Rep 142
Drives: BMW 535d Touring
I have the Sport Automatic Transmission but I don't get Sport + as an option as I used to on my 2010 530d F11.
BMW 535d M Sport Touring, Ariel Atom 245
BMW K1300S HP, BMW HP2 Sport High Performance Club - www.hpc.org.uk www.bbot.co.uk |
04-08-2014, 10:33 AM | #17 |
Rep 29,202
On what car, sounds weird though?
04-08-2014, 01:46 PM | #18 |
Rep 142
In fact today I found that the switch must be slightly faulty. When you push the Sport button the screen comes up with Sport Mode and pushing it again has no effect although the display shows Sport+ as an option. I found that the second push to activate Sport+ only operates intermittently so it looks like a faulty switch.
04-08-2014, 03:11 PM | #19 | |
Rep 619
04-09-2014, 06:38 AM | #20 |
Rep 329
Drives: BMW 520D Touring 2012
Well, I have never seen any meaning of using Sport+ at all. It's Eco Pro, Comfort or DSTC off for me. There are simply too many variations coupled with the Sports mode on the Auto box.
On my 520D I can have 10 different variations of Modes. Totally silly. |
04-09-2014, 11:42 AM | #21 | |
Rep 15,858
BMW protect us while using DSC OFF, don't want us going through a hedge backwards with sensitive throttle modulation. HighlandPete |
