02-23-2015, 08:26 AM | #1 |
Rep 144
HID Fitters?
I've ordered a HID off ebay the seller has sent me loads of proof of it been fitted and working on F10s and has said that if it doesn't work I can send it back for a full refund. With that in mind I would like to get somebody to fit the kit and mount the ballasts correctly.. I'm looking for someone in Gloucestershire/West Midlands area. I will pay for the work carried out I just can't do it as it would be fiddly as hell to do it through the wheel arch with out a ramp and the wheel off any garages or suggestions of people who fit these?
02-23-2015, 08:48 AM | #2 |
Rep 510
DO NOT! I repeat, DO NOT! install this kit into your car if you are equipped with Halogen headlights. All you will do is blind other drivers. You will need to change the headlight housing to projector headlights. The projector needs to concentrate and cut the light at a certain level or it will blind other drivers and just spread the light everywhere like a high beam.
If you do this, it will literally look like you're driving with High Beam on to other drivers. Except your high beam will is 3x brighter than halogen high beams. There's only a few cars with Halogen lights and can take HID retrofit kits. 2 of them are Mitsubishi 3000GT and Infiniti M35/37. The BMW does not have the same housing for halogen as HIDs. |
02-23-2015, 01:05 PM | #3 | |
Rep 144
Its to me as annoying as people who drive around with there fogs on thinking they look cool when actually they look like stupid idiots who don't know the meaning of 'FOG' in the word fog lights. When I see fog lights or HIDs in relflectors. I think CHAV incoming My car has halogen projectors, with the clear cut off the same as HID systems. Only difference is mine has crappy dull yellow halogen light. I've tried upgrading to white vision bulbs and theres slight improvements but I'm just going HID 5000k. |
02-23-2015, 02:25 PM | #4 |
Rep 510
Are there no Audio shops near you? Those guys should be able to do it easily as it's basically the same type of wiring and retrofit. IMO, it's much easier than doing audio mods.
BTW most of the problems with retrofit HID kits are the ballasts being low quality. Make sure you find some info on your hardware first before you end up with unreliable headlights. |
02-23-2015, 02:25 PM | #5 | |
Rep 2,323
02-23-2015, 02:45 PM | #6 | |
Rep 510
Seriously, all the automakers are coming up with new designs for LED DRLs on an annual basis instead of fixing the functional problems with the vehicle. Sales > safety. |
02-23-2015, 02:52 PM | #7 | |
Rep 2,323
02-23-2015, 03:00 PM | #8 | |
Rep 144
But when people use there fog lights at night along with there dipped beam when its not foggy its blinding.. the fog lights are not angled like headlights are, there spherical nature means that the light pattern just goes in all directions so that people can be made more visible in the fog. During the day theres not real difference, but if people want to drive around with them on and look like idiots I couldn't care less. But I drive loads at nights and in the dark (hence the HID fitting) and when I get idiots driving with their fog lights and low beams on I flash them. Its too much 4 x 50w halogen bulbs staring you in the face on a clear night. In England we are becoming so tolerate to all these idiots at night, its actually illegal to drive around with your fogs on. And its illegal for a reason. I could go on forever about people stupidity when driving at night, like not turning there full beams off until they've already dazzled you. But doesn't anybody know any HID fitters in my area? I've currently got one coming to me, and the garage I nominated to fit it is saying they can only do it in the week and no courtesy car. Thats no good for me I use the car for work everyday. HELP?? |
02-23-2015, 03:03 PM | #9 |
Rep 510
If you have really bright fog lights and use it as supplemental lighting, then you can blind other drivers because it is aimed across rather than down. It is not supposed to be used that way.
When fog lights were halogen, it wasn't a problem. Now some people have really bright fog lights and it blinds me all the time on the highway when there's no median blocking the light. |
02-24-2015, 09:55 AM | #10 | |
Rep 2,323
If you really are that concern about blinding other drivers, you should stay with halogen bulbs. Even though you have projector, they are halogen projector and have a wider cone, you will still blind other drivers somewhat. Halogen projectors also do not have a squirrel cage. Along with that, you do not have self leveling headlight which means that you will blind other drivers if you are on a hill or have passengers in the back. I also assume you do not have headlight washers which mean that if your headlight are dirty, the stray light will cause problems with oncoming traffic. All these are much more serious problem than driving with fog lights on. That is why it is illegal in the US to retrofit HID kits in cars that do not come with it from the factory. |
02-24-2015, 11:31 AM | #11 | |
Rep 144
That's not true about Halogen projectors... I admit they're designed for Halogen bulbs so the cone is smaller and not as wide as HID projectors, but in reality all that actually means is the beam outlay in front of the car is narrower than HID, simply because halogens aren't as powerful as HID and use a filament not an ark like HID, If you take a look at the link below the cut off is exactly the same as a HID projector so as long as the lights are aligned correctly drivers going the other way will not suffer. As for washers I have them weirdly my car has them and halogen lights dumb I know and agreed if you don't have washers and don't clean your headlights then you'll blind people. But then again washers don't do a brilliant job so I end up cleaning my headlights anyway for optimum light output. Self levelling headlights its a funny one as most systems in the cars of today are really laggy and I get blinded all the time by halogen and HID cars going over hills this is simply because the system is actually more rag and bow than you think, If you had a front infared camera beaming out on the road in front anticipating hills then yes it would work but thats to expensive in costs for car companies. Granted with self levelling is better than without but its not a necessity. The HID law I can understand but thats purely because 90% of the morons buying these kits stick them in reflector housings and it is blinding to oncoming vehicles. In the UK or in the part I live in anyway, we have massive problems with people driving around with headlights which are poorly adjusted blinding people, people driving with fogs and dipped beam on blinding people, people with HID kits in reflectors blinding people, HIDs (with self levelling) going over hills and blinding people, people dazzling people buy not turning off there high beam until the very last millisecond on which it is to late. On a night 50% of the cars I pass on the hilly windy roads where I live dazzle me. My mates say the same also. Just like the law in England which makes it illegal to drive with your fog lights on unless there is fog. But trust me in England I'm not gonna worry about oncoming vehicles being effected by my lights, just as nobody worries about blinding me. I've been PM'd and I've got somebody to fit them now so rant over and problem solved Link : http://goo.gl/Gd8KkF |
02-25-2015, 02:35 PM | #12 |
Rep 2,323
youknowluke, basically, any poorly aim light will blind other drivers, rather if it is fog lights or xenon lights in a halogen projector. Properly design factory xenon lights and fog lights are the way to go, it is design to minimize blinding on coming traffic.
02-25-2015, 04:29 PM | #13 | |
Rep 144
02-25-2015, 09:16 PM | #14 |
Rep 14,522
Any reason why the factory fogs are more of a dull white? I don't drive with them but when they are on they just don't match the headlights.
02-25-2015, 09:23 PM | #15 |
Rep 510
02-26-2015, 02:58 PM | #16 | |
Rep 2,323
02-26-2015, 04:04 PM | #17 | |
Rep 144
02-26-2015, 04:06 PM | #18 |
Rep 144
02-27-2015, 07:52 AM | #19 |
Rep 510
Fog lights are not aimed low, they are aimed higher than your low beam. Their PLACEMENT is low because it's supposed to be under the fog. Hence why fog lights, especially w/ HID or LED fogs, used improperly will blind other drivers.
02-28-2015, 10:17 AM | #20 | ||
Rep 2,323
http://www.ecstuning.com/ES2711818/?...FXJp7Aodyx0AjQ Quote:
03-01-2015, 03:08 PM | #21 | |
Rep 510
The reflector concentrate the beam because LED produces lights in all directions and lots of it. The divider helps cut some of the light off from directly going out at too high of angle. But some of those lights will reflect on the lower part of the housing and bounce out at an angle above the divider anyways. Since fogs are aimed at a higher angle due to their lower placement, it will blind some oncoming drivers. I don't think you understand how all this work that well. There's a reason why BMW and many other cars leave th fogs off by default. There's a reason why different lights have different angles, reflectors, housing, dividers, etc... Things are not as concrete as you see it. |
03-02-2015, 05:25 PM | #22 | |
Rep 2,323
