2010 2011 BMW 5 Series Forum F10 Difference between S mode and Sport mode |
09-24-2010, 10:28 AM | #1 |
Rep 2,340
Drives: 650GC/E93M3/Lexus LS600HL
Here's another mind boggling question.
In a sport auto F10, What's the difference between moving the shift lever to S mode vs switching DDC to Sport mode (at standard settings), pertaining only to transmission? Does it make a difference if I switch the shift lever to S when DDC is already in sport/sport+ mode regarding shift speed and transmission programming? I just wish that BMW would make it clear what the differences are between those......
F06 650i Gran Coupe Ruby Black/Dakota Cinamon- 2012-10-12 Adaptive Drive/IAS/Surround View/Adaptive LED/Comfort Seats/BMW 356 Liquid Black/Michelin PSS 245/35R20-285/30R20
E93 M3 Cabriolet Satin Pearl White/CR - 2012/03/12 Bilstein PSS10/ Michelin PSS 245/35R19-265/35R19 Brembo GT 2011 F10 550i M Sport - Retired |
09-24-2010, 11:30 AM | #4 | |
Rep 15,858
Obviously the sport auto will feel different, depending on the i-Drive configurations made. HighlandPete |
09-24-2010, 11:38 AM | #5 | |
Rep 15,858
HighlandPete |
09-24-2010, 11:52 AM | #6 |
Rep 2,003
hi guys
i just found out how to use the manual 'S' mode .. it holds the gear and doesnt change unless u tell it to! (at least up to 3-4k on 1st as i tried) b4 i was using sport/sport+ and changing with paddles, it holds the gear somewhat, but only for a few to tens of seconds of no use, then it goes back to 'D' by itself so the S mode is kinda like Manual, wearas in 'D" with sport/sport+ u have to downshift once or twice with the paddles before it goes to 'M5/6/7' on the display ie. temporary manual mode |
09-24-2010, 12:06 PM | #7 | |
Rep 15,858
HighlandPete |
09-24-2010, 12:19 PM | #8 |
Rep 2,003
this is good, so u keep it in sport/sport+ for the stiffer ride (sorry for calling it that) but not have to worry about the shifting, then when u want to shift yourself you got to 'S' from 'D' in on top of your sport/sport+ mode
09-24-2010, 08:07 PM | #9 | |
Rep 78
Another option is to configure via i-Drive the SPORT switch to chasis-only to engage only the stiffer steering (and save gas), and if you want the full enchilada, just move the shifter to S. At that point, if you use the paddles, it will remain in manual-only shifting. Going to D and back to S will revert to full-auto mode.
2012 535i | Built 8/25˜9/07 2011 | Delivered 10-15-2011 | Carbon Black | Oyster Black Dakota Leather | M-Sport Pkg | Luxury Seating Pkg | Premium Pkg | Premium Sound Pkg | Technology Pkg | Sport Auto Trans. | Split Fold-Down Seats | Heated Seats | Side & Top View Cameras | Heads-Up Display | BMW Apps | Black Panel Display | Trunk Lip Spoiler | Hardwire V1 | Kitchen Sink Pkg...
09-24-2010, 08:35 PM | #10 | |
Rep 2,340
09-25-2010, 02:45 AM | #11 |
Rep 229
I read in CAR Magazine that switching off DTC completely makes the car go into expert mode. This gives you normal dampers, normal accelerator response, normal shifting but stiffer steering.
Current: 2014 F11 lci 520xd Touring, Imperial Blue
09-28-2010, 04:22 AM | #12 |
Rep 2,340
Spoken to my service tech about this. And they checked with BMW engineers. Here's the difference:
Transmission in S mode means that only transmission programs are altered. Essentially, the shift points are delayed so engine will rev higher before shifting up. And also, gears are limited to 1-6. Switching to Sport mode from normal means: 1) Transmission will be in S mode. 2) Accelerator response will be enhanced (faster response) 3) Steering will be tightened. They claim to be more responsive instead of just being heavier. 4) For vehicles with IAS (mine), steering will be further enhanced (some IAS params also changed) In short, switching the gear lever to S mode is NOT equivalent to standard settings in SPORT mode (missing the enhanced accelerator response).
EL Jeffe 5611.50 |
09-28-2010, 05:17 AM | #13 | |
Rep 15,858
HighlandPete |
09-28-2010, 06:14 AM | #15 |
Rep 2,340
That's correct. The tech researched the info based on my F10 which has the Sport Auto as standard.
09-28-2010, 07:26 AM | #16 |
Rep 61
It gets more complicated – remember there’s 3 settings to mess around with and not all of the settings go together. We have:
Traction & Stability: DSC off – DTC - Standard, Transmission: M – S - D, Dynamic Damper Control: Sport+ - Sport Standard - Sport Chassis only - Sport Drivetrain only – Normal - Comfort Bizarrely you cannot combine” DSC off” and Sport or Sport + suspension settings. As soon as DSC is off (press down DSC button for 5 seconds) the chassis setting diverts back to Normal. It would be neat to see a bulletin explaining exactly what combinations are possible and what exactly they modify. Found this little screen today. As you can see there's a further 14 pages but unfortunately no really interesting details. If you're stuck in a traffic jam have a read on the I-Drive manual about the pedestrian friendly bonnet. Didn't know it was such a sophisticated piece of kit. Learnt it activates between 20 km/h and 55 km/h ... or if you hit a snow drift... |
09-28-2010, 09:11 AM | #17 | |
Rep 2,003
thats another good way to use it, i think that would suit my driving style, in sport (chassis only) with S mode manual |
09-28-2010, 09:15 AM | #18 | |
Rep 2,003
yup but i shifted through all 8 gears in S mode, in the display and i could feel them .. dunno, u try ar |
10-13-2010, 01:20 PM | #19 |
Rep 47
I would also like to know if that's possible. I have not found any option for selecting default mode in the I-drive, however, so perhaps it is not possible to set Sport mode as default.
10-15-2010, 07:18 AM | #20 |
Rep 4
[QUOTE=ctm3;8154141]I would also like to know if that's possible. I have not found any option for selecting default mode in the I-drive, however, so perhaps it is not possible to set Sport mode as default.[/QUOT
I am interested too in this topic... does anyone know how to set default mode to S? |
01-08-2018, 07:59 AM | #21 | |
Rep 478
This is very good to know...I was struggling to understand the difference!! so switching the gear lever to S mode is NOT equivalent to standard settings in SPORT mode and the best way to explore the car's performance is to use M/S Sport Mode!!! |
01-08-2018, 09:43 AM | #22 |
Rep 878
Too many choices. We just need Sport and Comfort, where Sport includes all things sporty. And if you have an M-car, it should be sporty all the time.
-WJV
