2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Plasti-Dip Wheels
      11-14-2013, 09:58 PM   #1
MOTODAVEO
MOTODAVEO's Avatar
Drives: 2014 BMW Z4 sDrive28i
Plasti-Dip Wheels
I plasti-diped the wheels I use in the winter. I was actually pretty impressed with the results so I figured I'd post them here in case anyone else was looking for a little reassurance that it actually works.
My winter wheels are from my old 335xi coupe. They are just cheap Rials I think so I wasn't too worried if this all went wrong. They are 17" and I couldn't believe they fit the 550. They did look ridiculously small. My hope was the black would mask the small diameter and make the wheels look bigger. I think it does. So I'm happy with it.
I read a few posts on the subject and still forgot a few things and disagree with another. But I generally followed the process I saw on the forum...
Clean the wheels first and then wipe down with rubbing alcohol or simple green or something similar. I used simple green and then wiped them dry. Clean dry wheels are a must. Wet or greasy spots cause the bubbling.
Spray multiple thin coats. Cover too much and it will run.
The part I forgot - put quarters in the lugholes and remove after each coat. This is so there is no Plasti dip where the lug nut touches the wheel. People have said the nut tears the plasti dip and then starts a loose edge where it peels off the rim. I just bolted them on and see no issues. When I take them off we will see what happens. If I had it to do over, I would put quarters in the holes and remove them after each spray so there is a clean surface.
I did probably 6 coats of black and then 3 coats of the "Glossifier" The glossifier lets you choose how shiney you want by how much you spray. The 3 coats I did left a nice satin look.
The part I disagree with: You don't have to cover the tire. I saw the videos of guys spraying right on the tire and peeling it off later. Mine did not peel. I left it on for a long time though. There just wasnt anything to peel. It looked like I had tire shine on part of the rubber but it wont peel. Again, I don't know why it didn't come right off but if I was doing it again, I'd stick the 3x5 notecards around the edge and keep the tire clean. As it is, I dressed the tire and they look fine. Now I have incentive to keep tire dressing up I guess.
I did scrape a little off on the side in a few of the lug holes when I torqued the wheels. So be slow and carefull with that socket!
It seems pretty durable. I have run it through the car wash and power washed them a couple times with no problems so far.
They say it peels right off if you want it back to original but I haven't had to try that. I like the look. It was better than I hoped it would come out. And it cost about $40 to do. So if you are on the fence, try it! It was a good result for the effort. People honestly just think they are originally black wheels.
Current BMWs: 2014 Z4 sDrive28i, 2013 550i
Previous: 2011 Z4 sDrive35is, 2010 335xi coupe (manual)
      11-14-2013, 10:19 PM   #2
Grover432
Drives: 2013 535 XDrive
How do you like the Rial wheels? Are they standing up? Staying "true"?
2013 535 X Drive, Alpine White/M Sport/Executive/Apps/Black Dakota/Fineline Anthracite
      11-14-2013, 10:38 PM   #3
WarReady
WarReady's Avatar
Drives: 2013 BMW 550ix M-SPORT
Looks nice great job!!!
      11-15-2013, 01:44 AM   #4
dblock2151
Drives: '11 550i Msport DG
You're the man!! Do you happen to know the offsets of the Rial's you have? Didn't have to use any spacers?
My brother has a set of the same Rial's in black already off his E60 550i. He sold the car and the wheels are still around so I'd love to re-use them if possible. Glad to know they fit over our calipers (barely wow).
Thanks again.
      11-15-2013, 07:02 AM   #5
Grover432
Thanks again.
According to The Tire Rack the Rial "Salerno" the OP has have an offset of 30mm matching the OEM wheels. I just got a set with Dunlop Wintersport SPs. The tread isn't as aggressive as the Blizzaks the OP has, hopefully they will live up to the reviews on snow.
      11-15-2013, 11:23 AM   #6
MOTODAVEO
MOTODAVEO's Avatar
Yeah, the wheels have been fine. I went through 4 winters with them now between the 3 series and the 5 series.
We'll see how the black dip holds up in Iowa winter.
      11-15-2013, 11:24 AM   #7
MOTODAVEO
MOTODAVEO's Avatar
No spacers.
      11-15-2013, 11:46 AM   #8
LACSTER
Drives: Hybrid
      11-15-2013, 05:03 PM   #9
IM2C
IM2C's Avatar
2067
Drives: ∞ Improbability Drive
Looks good.
///| g87 | f87 Comp | g29 M40i | f97 Comp | f80 Comp | f80 | f30 | e92 | tt | S5 | e92 | 350z | e90 |
      11-16-2013, 02:22 AM   #10
fung0001
Drives: f10 2013 520i Hartge Tuning
Honestly
Suprising
Good job
