2010 2011 BMW 5 Series Forum F10 Cold Air Intake - 2016 550xi (N63TU) - CEL (of course!) |
11-05-2020, 07:07 PM | #1 |
Rep 131
Spent the better part of last weekend installing this cold air intake. Didn't have a lot of idea what I was doing, but got it done.
Let me start with a request for any ideas on the resulting CEL? The codes are 1) P00BC (Mass or Volume Air Flow A Circuit Range/Performance - Air Flow Too Low), and 2) P0172 (System Too Rich Bank 1). I knew this might happen, but I was hoping to avoid it... I went out of my way to find intake piping that accommodated the mass air flow sensors (MAFS). Also, I tightened the clamps to [try to] ensure a good seal everywhere. Any ideas? Beside that, my results are: 1. Engine growls under load. 2. Front end feels lighter (probably imaging this, but...) During the install I learned: 1. You have to take the front fascia / bumper off to take out those fixed, horizontal shutters / louvres from behind the kidney grills. PITA. Photo 3 & 4. 2. Speaking of the kidney grills, I found more than one YouTuber who said to just yank them straight out to remove them. "It'll feel like you're going to break them, but you won't." Well, I did break them - the bottom clips of the kidney grills all broke off (photo 2). 3. I was following an install from a YouTuber who said he used 3" pipe for the whole thing. However, when you fit your last piece of silicone tubing on the pipe - I'm talking about the last silicone elbow that ultimately sticks out behind the kidney grilles and onto which you attach the air filter. Anyway, that piece of pipe with the silicone tubing fitted on it is too fat to squeeze through the channel below the hood latch mechanism brackets. So, I had to use the bendable Spectre Performance intake tubing (got that idea from CReynolds - thanks!). You can see the black tubing in photo 5 continuing down from the red silicone elbow, sorta out of view, and then towards the front of the car and into the space behind the kidney grills. Thanks for reading, appreciate y'all and any ideas/feedback you have. BR
Current Fling: 2016 Jet Black F10 550i xDrive | ARM Motorsports Cat-less DPs | 19" Style 351 M Double-spoke Wheels & Vredestein Quatrac Pro XLs | 35% tint
Lost love: 2011 Space Gray E92 335i |
11-06-2020, 11:36 AM | #2 |
Rep 2,595
Make sure the MAF's aren't backwards. They're directional. Also make sure your filters are up to snuff and can actually ingest the required amount of air. Those filters look a tad small tbh
2015 BMW 535xi
Ben Richards28.00 |
11-06-2020, 05:56 PM | #3 |
Rep 131
Right on - that is pretty outstanding advice. I will check both.
I'm gonna just try to flip them around one at a time, but in the meantime, any idea which way is the correct way to orient the MAFSs? I see a yellow-blue-red wire sequence - yellow or red towards the front of the vehicle? Thanks, BR
11-06-2020, 06:37 PM | #4 |
Rep 131
FIXED
Big ups to Unspec - I reinstalled one of the MAFSs backwards/upside down. The correct sequence of wires to look for, from vehicle back to front, is red-blue-yellow.
CEL is gone - I'll go for a test drive tomorrow. Unspec, truly appreciate it . Thank you very much! BR
Unspec1311.50 |
11-06-2020, 07:36 PM | #5 | |
Rep 5,408
11-06-2020, 09:09 PM | #6 |
Rep 131
With the OEM intake ducting, yes. But I replaced all of that and used this beauty to accommodate the MAFS in my new intake piping scheme. As you can see, I could have installed it correctly ...or backwards/upside down ...
11-09-2020, 10:43 AM | #7 | |
Rep 2,595
2015 BMW 535xi
04-16-2024, 06:55 PM | #8 | |
Rep 170
1.) since your cold air intake filters are in front of the grill , during heavy rain dont you think water and dust will be sucked into the airbox directly cause only one filter is available in front , it might get soak, and filled with dirts. 2.) even though you have cold intakes the MAS job is to measure the amt of air going inside based on the mixture so no matter you have tons of oxygen going inside the mas will measure how much the engine needs and only allow that fuel mixture inside from fuel injection. so it should not make any difference.. |
04-17-2024, 03:34 AM | #9 |
Rep 81
I recently, January, purchased and installed a CAI from n63intake... I live in Melbourne, Australia and its fairly wet here and when I asked Sergei about that very concern of ingress, he said he lives in NY and has never had any ingress and to date, neither have I and I driven through some heavy down pours doin over 100/kmh.
The induction noise is worth it alone.. sounds like a jet engine when cold start happens and with mine being an n63 (non TU), I also get to hear the BOV sound |
04-17-2024, 07:25 AM | #10 | |
Rep 52
Drives: '15 535i xDrive M-Sport, E30
These will massively reduce the chance of water getting to the filter plus act as a pre-filter. |
04-24-2024, 06:45 PM | #11 | |
Rep 170
05-03-2024, 08:54 PM | #12 | |
Rep 170
