09-24-2015, 10:01 AM | #1 |
Rep 687
Rotor question
I noticed that the Original brake rotors have some rivet things around the hub. Do OEM brands like Zimmerman have the same? or does anyone have any experience yet with other rotors on their F10 550?
09-24-2015, 11:39 PM | #2 |
Rep 1,407
http://f10.5post.com/forums/showthread.php?t=1170250
Check it out. I have swapped my rotors on my 550i already. |
09-25-2015, 12:37 AM | #3 | |
Rep 687
09-25-2015, 01:57 AM | #4 |
Rep 1,407
If not a fan check out rockauto. They have blank rotors for great prices. They aren't rivets more like raised dimples and really serve no purpose from what I have seen swapping out my rotors.
09-25-2015, 10:03 AM | #5 | |
Rep 54
The rotors Simple3 is trying to sell you on are of an inferior design. They are 1-piece rotors with iron center sections. They are heavier than stock, and don't have the thermal expansion characteristic and performance of the stock units. Basically low-performance aftermarket pieces vs high-performance factory pieces. |
09-25-2015, 10:07 AM | #6 | |
Rep 687
Thanks again! |
09-25-2015, 10:31 PM | #7 | |
I am groot
25
Rep 149
By the way all my rotors warped and there are threads about the stock rotors warping, even on the m5. Do a search unless your lazy, but I'm sure you won't be lazy about coming back with a lame response to prove your worth.
2011 550i M SPORT
CF kidney grills, rear diffuser, rear spoiler, bmw emblems, Megan Racing mufflers, H&R Sport Springs, Forgestar F14's Front 20x9/275/30r20 Rear 20x11 305/25r20, AQ3500d, Audio Control LC2, custom ascendant audio 12" chaos/mayhem's 4th order Last edited by Autobuffoonery; 09-25-2015 at 10:42 PM.. |
09-26-2015, 01:11 PM | #8 | |
Rep 1,407
I have been using slotted/drilled rotors on my e36 and e90 335i. I have never seen these kind of cracks on that set-up with ceramic pads. |
09-26-2015, 01:45 PM | #9 | |
I am groot
25
Rep 149
2011 550i M SPORT
CF kidney grills, rear diffuser, rear spoiler, bmw emblems, Megan Racing mufflers, H&R Sport Springs, Forgestar F14's Front 20x9/275/30r20 Rear 20x11 305/25r20, AQ3500d, Audio Control LC2, custom ascendant audio 12" chaos/mayhem's 4th order Last edited by Autobuffoonery; 09-26-2015 at 01:55 PM.. |
09-27-2015, 07:04 PM | #11 |
I am groot
25
Rep 149
His attitude was all wrong and the info he posted was his exaggerated opinion based on nothing factual. Please don't jump on the troll band wagon.
2011 550i M SPORT
CF kidney grills, rear diffuser, rear spoiler, bmw emblems, Megan Racing mufflers, H&R Sport Springs, Forgestar F14's Front 20x9/275/30r20 Rear 20x11 305/25r20, AQ3500d, Audio Control LC2, custom ascendant audio 12" chaos/mayhem's 4th order |
09-27-2015, 07:43 PM | #12 | |
Rep 243
Although the link Simple3 posted was a great deal, there is a difference between that set and OEM. NickG was simply pointing that difference out. I agree with you about our cars not needing floating rotors but you don't need to be a dick about it. |
09-29-2015, 11:37 AM | #13 |
Rep 687
wow didn't mean to start any trouble!
But regarding the post with the pads. on my e46, only used Stock Rotors and pads (textar) for the 300,000 miles i put on it over 13 years. They never warped, pads never had cracks in them. I was basing my F10 550i on that quality, now this is a much heavier and faster car with different dynamics. So I may need to try out the Zimmerman, etc and see how they work out. Going to do some more searches on the Warping issue with 550's as you say. I don't have that issue now. Mine are just rusty and grooved in. so the next set of pads will need some front rotors. I have just never seen crossed drilled rotors work on heavy cars, unless they were the real BBK ones that are like 600$ + each. I always hear about warping and cracking. I've seen a bunch my self as i do small work on other cars for friends. |
09-29-2015, 04:16 PM | #14 | |
Rep 97
Drives: 2016 640i xDr GC MSport
The cross-drilled holes and grooves on rotors were originally developed to vent gasses which some now-obsolete racing pad formulations produced at very high temperatures. The holes and slots have continued in production solely for looks. In fact, because the holes and grooves reduce the friction surface area under the pad, they reduce stopping power. They also accelerate pad wear and cause more black dust. They are the brake equivalent of 21 inch wheels -- a performance step-back but they do look important. |
10-01-2015, 12:18 PM | #15 |
ZEROdoubleZERO
228
Rep 659
I changed all my rotors to cross drilled and ceramic pads within the last 6 months, and I have zero brake dust and didn't seem to notice any loss of brake perfomance. I did however only change from stock to cross drilled for aesthetic reasons, but all my stock rotors were warped and the stock pads gave me terrible brake dust. I think I'm going to find out my stock 60-0 braking distance and do my own test to see if I lost any performance in braking by switching to cross drilled rotors and ceramic pads, it will be interesting to see for myself if the rumors about cross drilled rotors are true or bs. I'll post back with an honest account of my findings.
10-01-2015, 12:55 PM | #16 | |
Rep 54
As far as research goes, maybe you should do some research yourself on what cars BMW uses floating rotors on, and which ones get one-piece rotors. And as far as my qualifications go, I'll let you do a little research on me and figure out my involvement in the BMW aftermarket industry, and what records and knowledge I possess. Continue your trolling and name calling, and further showing your lack of understanding of our vehicles and their dynamics. Last edited by NickG_TechniqueTuning; 10-01-2015 at 01:01 PM.. |
10-01-2015, 03:02 PM | #17 | |
Rep 687
10-01-2015, 03:36 PM | #18 |
ZEROdoubleZERO
228
Rep 659
I installed "centric" brand rotors and akebono ceramic pads. There's one thing people are forgetting to mention, brake rotors are a wearable item on your car and are not ment to last forever so I didn't see the need to buy overpriced expensive stock rotors because they will be replaced again in a few years anyway. The centric brand is not a eBay cheapo China rotor, they are designed and machined in America by Americans but they are cast in China by strict standards imposed by centric. I have them and they are good quality, the stock rotors still warped even with the fancy 2 piece design.
10-01-2015, 03:52 PM | #19 |
Rep 687
Here's the funny thing I have noticed. I'm my 550i I've gone through 2 sets of rear pads before my fronts. They are still in good condition ? I heard my car brakes more in the rear in stop and go traffic, hence why I get a lot of dust in the rear.
10-02-2015, 07:37 AM | #20 |
Rep 97
Is it possible you're using different pad compounds front and back? I can't think of anything else that would explain your reversal of the normal wear pattern.
10-02-2015, 08:02 AM | #21 |
Rep 54
My 2011 550i has the exact same behavior with the stock rotors and pads (rear pads worn before front).
10-02-2015, 08:03 AM | #22 |
Rep 687
