2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum 2011bmw 528i misfire
      09-09-2023, 08:05 PM   #1
F10qimon
Drives: 2012 bmw 528i
I’m having a misfire 5&6 issues I replaced the spark plugs and ignition coils but the car still has little jerks when in idle can anyone help?
      09-09-2023, 08:36 PM   #2
ChiltiCoatl89
ChiltiCoatl89's Avatar
Drives: 2016 F10 BMW 535i M Sport
Check your Air hoses and connections, start simple, was the misfire resolved after you replaced the Plugs and the Coils? How many miles does your 5er have?
      09-09-2023, 08:42 PM   #3
F10qimon
I have a 2011 bmw 528i 160k miles The first code that popped up was misfire cylinder 3 and a catalyst fuel trim system too lean bank 1 .
After changing spark plugs and coils I reset codes then misfire cylinder 5 popped up not sure if I have the coils to loose or tight but coming to the conclusion I think it’s my fuel injector misfiring maybe ??
      09-09-2023, 08:45 PM   #4
F10qimon
Codes.
      09-09-2023, 09:13 PM   #5
ChiltiCoatl89
I would definitely inspect the injector particularly because your O2 Sensor is throwing a lean code. Please Double check and make sure your plugs and coils are torqued to spec.
