2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum What is breaking In? Someone help me plzzz
      11-08-2012, 02:40 PM   #1
slownfast
Drives: 2013 528i Xdrive
I'm still confused about breaking in?
Can someone explain that?
I'm newbie here
      11-08-2012, 03:05 PM   #2
The X Men
Drives: 2013 X3 35i
Its a period of time on new cars that you are suppose to take it easy on.
      11-08-2012, 07:13 PM   #3
slownfast
how many miles for breaking in? what happen after breaking in done?
      11-08-2012, 07:54 PM   #4
m6pwr
m6pwr's Avatar
38
Drives: '14 335i M sport
Here's a rather long discussion of the topic - http://www.myturbodiesel.com/1000q/engine-break-in.htm.
The most salient advice in the article is, "My suggestion is to follow the owner's manual written by the people who made your car."
Look in the index to your owner's manual to find break-in procedures.
'14 328d, '13 M3 ZCP, '12 535i, '11 335d, '09 Z4 DINAN Stage II, '05 330i ZHP, '05 M3 ZCP, '02 M3, '91 328i, '90 535i, '88 528e, '88 M5, '87 M6, '95 Z3, 95 M3, '93 M5, '87 325e, '89 535i, '86 635i, '73 Bavaria.
      11-08-2012, 09:10 PM   #5
JNoSol
JNoSol's Avatar
Drives: 750 MSPORT & E90M3
I'm newbie here
The first few hundred miles of the car's life, just take it easy. No hard acceleration and braking. All the car's moving parts take a few hundred city equivalent miles to mate (wear) evenly and appropriately (i.e. gears, clutch, brakes, engine rings, etc.).
After 5k miles, get an oil change from BMW then you can drive it as hard as you like.
I know it isn't required to change the oil between the recommended intervals, I do it anyways. It's cheap insurance against engine wear.
      11-08-2012, 09:53 PM   #6
dunderhi
dunderhi's Avatar
Drives: 2015 M6
During my BMW factory tour, the guide stated BMW does not dyno each engine, nor do they even run the engine prior to installation. To save money all they do is a simple pressure test, so I have some doubts about the accuracy of the linked article. If the engines were dyno'd at the factory, then I would consider following the break-in procedure. Since BMW doesn't do this initial step, I break in my engines under load, which normally means 150mph on the Autobahn. I know it goes against BMW's recommendation in the manual, but I do what works for me. BTW, burning oil should not be considered normal for a BMW.
2015 M6 Drophead Coupé
2015 328xd Estate
2013 X5M Sport Utility Vehicle
      11-09-2012, 12:26 AM   #7
F11-Diesel
Drives: F11 530 D
There is no modern evidence that an oil change before the BMW indicated one (after 30k kms) is any better for the engine. These hypotheses are based on old school motor maintenance. Taken the car through his first thousand kms without needless overstraining of any moving parts makes the engine parts adjust at the proper way, ie without unwanted wear. A fully warmed up new BMW motor will stand up to a stretch of autobahn on max speed, but what works for d, is not a recommendation by BMW. Or any other engine builder I know of. Some new cars burn a little oil the first thou kms, so check your levels and replenish if asked for. Most BMWs do not keep burning oil, if any, after they are run in.
      11-09-2012, 12:33 AM   #8
F11-Diesel
Drives: F11 530 D
To d, man you are right, when doing ED.
Ofcourse you will want to test the new baby fully.
So if the 150Mph autobahn test fails, lets say you blow the engine with it, you leave the wreck in Bavaria instead of hauling over a useless pile of rubbish to the States.
Everybody should do it this way!
      11-09-2012, 12:43 AM   #9
slownfast
Si I cannot beat my car during breaking in? How many miles for breaking in? 5000 miles?
      11-09-2012, 12:51 AM   #10
F11-Diesel
Drives: F11 530 D
It is just like a new girlfriend, when you will start the relation by taking the stick to her from the beginning you will end up very soon with an ugly bitch.
In the manual you'll find the run in time, it is less than 5k.
My F11 was run in and driven freeely after 2k kms.
      11-09-2012, 01:03 AM   #11
slownfast
I just saw the manual, it says 1200 miles
Now it is 660 miles
I just beat my car last week coz I was in hurry
Will it be okay? I'm afraid it will be worse
One more question, I get 17-18 mpg in city and will it be better after breaking period done?
      11-09-2012, 01:12 AM   #12
F11-Diesel
Drives: F11 530 D
Mpg is depending on driving style, normally fuell efficiency rises a bit after the engine is driven somewhat longer. I would not worry about your engine, or did you get any alarms whilst flocking it around last week? If not forget it all together and enjoy your new car.
Rtfm, you'll learn a lot of things to enjoy your car even more.
      11-09-2012, 01:29 AM   #13
slownfast
No, i didn't get it. I'm really enjoy my car, really love f10!!!!
I get 17-18 mpg in city because there are so many hills in Seattle, am I right?
I get 16mpg today , so sad
      11-09-2012, 10:23 AM   #14
dunderhi
dunderhi's Avatar
Drives: 2015 M6
I broke in my last three cars on the Autobahn. If the motor is not ready for the Autobahn, then it's not ready for me. The good part is that if there was a major failure, I wouldn't need to wait for the parts to be shipped from Germany.
2015 328xd Estate
      11-09-2012, 11:37 AM   #15
m6pwr
m6pwr's Avatar
38
Back in the good old days, BMW 2002's used to come from Germany with a large outward-facing decal on the rear window saying "Running-In" - - presumably to alert lead-foots behind not to run over the pussy-foots in front. Then for a long while, BMW had break-in instructions (basically the same as now) on a decal in the upper left hand corner of the windshield for the edification of the driver. Now BMW has the procedure buried in the Owner's Manual (which practically no one reads). This gradual devolution of the break-in procedure is probably a reflection of the greatly improved manufacturing and machining processes of today that minimize the need for careful break-in.
FWIW, the link I gave was to an article on a VW diesel forum. VW makes the TDI diesel at its Wolfsburg factory not only for all the variants of VW diesels cars, but for Audi's, Skoda's, and Seats, as well. I don't know total production numbers, but it would be impracticable for VW to break-in all these engines at the factory. I've been told by someone that visited the factory, that they only run the US-bound diesels on a dyno - - out of deference to our speed and traffic safety laws which would prohibit breaking-in the diesels here at Autobahn speeds. They run the US diesels at wide open throttle until blue smoke starts to pour out of every orifice and pore, at which point the engine is said to be broken-in.
      11-09-2012, 02:07 PM   #16
slownfast
one more question, what happen after breaking period done? i want to know how my friend gets 20 MPG in city with 2012 535i xrive but i get 17 MPG in city with 2013 528i xrive (just bough it a month ago)? we have the same driving style
      11-09-2012, 02:16 PM   #17
dunderhi
dunderhi's Avatar
Drives: 2015 M6
How about swapping cars for a week and see if you actually have the same driving style.
2015 328xd Estate
      11-09-2012, 02:37 PM   #18
Richard Cranium
Drives: It's a truck
The most salient advice in the article is, "My suggestion is to NOT follow the owner's manual written by the LAWYERS representing the people who made your car."
Fixed it for ya.
To the OP. I'd drive it the same way you intend to drive the car past the "magical" break in period.
If not following break in procedures found in the manual actually caused damage to your car the world would be littered with broken cars on the side of the road because most owners don't know what break in even means, let alone read their owners manual.
      11-09-2012, 02:42 PM   #19
slownfast
yeah, that is what i'm planning. am i right if i get worst MPG because 528i is heavier than 535i and it also has smaller HP than 535i?
      11-09-2012, 02:47 PM   #20
Mac B
England
Drives: 520D SE saloon (G30)
I'm newbie here
In English English it's called "Running-in"
      11-09-2012, 02:58 PM   #21
slownfast
Sorry my English is bad
