2010 2011 BMW 5 Series Forum F10 Photodon F10 Nav and Cluster Screen Protector |
07-18-2016, 05:49 AM | #1 |
Rep 1,085
Drives: 2013 BMW F10 550 Xdrive Msport
Posting this as a request for people in another thread. I worked with a company Called: Photodon LLC 2682 Garfield Rd N Ste 21 Traverse City, MI 49686 www.photodon.com 847-377-1185 Pricing depends on what you order, but I used the MXO on the NAV screen and MXC film was used on the Gauge Cluster (For maximum Flexibility). I Literally sent them a Gauge cluster for fitment, so you are ENSURED this will fit your F10 PERFECTLY! https://www.photodon.com/c/Custom-Sc...rotectors.html http://www.photodon.com/Photodon-Scr...tion-Sheet.pdf The Engineer I worked with for the Custom Cluster Protector was: Don Basch @ Photodon donb@photodon.com (But please only send Technical requests to him, use the main page for orders) The Nav Screen MXO protector is 9.72 x 6.10 (247 x 155mm) from the factory, BUT, i had mine cut to: 10.25 x 9.75 (260.4 x 95.3 mm). This requires you removing the Nav unit from the car, removing 3 screws from the housing holding the LCD screen and then installing the Protector, BUT, it gives enough coverage on the LCD screen so once the Housing is installed, there are no protector Lines showing. MUCH cleaner install and looks factory this way. |
